[SoB] hitparade van 4 oktober Vorige deel Overzicht Volgende deel Laatste deel
  • 152 views sinds 30-01-2008
  • Pyrus
  • Laatst online: 16-11 20:32
Pyrus
Hardknock life
Woei, 4 mijlpalen en een plaatsje daily gestegen \o/ :)
SoB user daily stats (4 October 2004)
Flushing users: 59 / 245 = 24%
posdaily (k)usertotal (k)overalltests
1.(2)548997783[DPC]NGS209982998710(1)1
2.()432411509Joh14vers617670864630(12)0
3.(2)315710113fsfikke7011446825(29)0
4.()288216558[DPC]Ben47448113077(4)0
5.(17)274477990neOx5674305190(33)0
6.(1)205225211aKra28848373084(9)2
7.(5)186976245Los Alcoholicos40330794195(5)0
8.(2)180493992DPCDrastix7677498007(26)0
9.(2)167730295Loather10568392272(20)0
10.(1)143729537Warmachine6029382395(32)0
11.(1)127483224PinkwiN5162684818(37)0
12.(4)126957732LaSerDance11533899576(17)1
13.(2)121738062Team_Aggression17274525896(13)0
14.(2)91239073almkeij4294899801(40)0
15.(2)89742837redeye5218511342(35)0
more
total:3997049(m)
SoB user overall stats (4 October 2004)
postotal (k)userdaily (k)dailytests
1.()209982998710[DPC]NGS548997783(1)957
2.()128988964833[DPC] Team_RC41495809(19)630
3.()63782760235Randy480(-)562
4.()47448113077[DPC]Ben288216558(4)171
5.()40330794195Los Alcoholicos186976245(7)273
6.()35986030589[DPC]DoetMaarWat22496969(26)168
7.()35881752804[DPC]LKBN8999095(41)157
8.()31357001461The Anarchist0(-)110
9.()28848373084aKra205225211(6)95
10.()22368664760DukeBox31746155(23)168
more
total:1044498372(m)
SoB team daily stats (4 October 2004)
Flushing teams: 90 / 326 = 28%
posdaily (m)teamtotal (m)overalltests
2.(1)7168222US-Distributed871320643(6)28
3.(1)7026085Anandtech3223057351(2)25
4.()5975927DarksideDC1158886882(4)20
5.()4529633Busty_Seventeen460954576(8)14
6.(1)4045672TeamRetro1410936061(3)15
7.(1)3997049Dutch_Power_Cows989295843(5)5
8.(2)3478603AMD_Users185444365(16)4
9.(4)1799530Russia269030053(13)9
10.(1)1489471Team_Norway80044660(22)1
11.(1)1328859TeamTNT262101857(14)1
more
total:72160(g)
SoB team overall stats (4 October 2004)
postotal (m)teamdaily (m)dailytests
1.()3866899764TeamPrimeRib18674431(1)39334
2.()3223057351Anandtech7026085(3)28149
3.()1410936061TeamRetro4045672(6)14056
4.()1158886882DarksideDC5975927(4)5873
5.()989295843Dutch_Power_Cows3997049(7)4888
6.()871320643US-Distributed7168222(2)5013
7.()580036041ORU42749(60)9322
8.()460954576Busty_Seventeen4529633(5)1623
9.()404053024Team_Ninja398882(23)2911
total:17681176(g)
SoB team When do they get you stats (4 October 2004)
Based on weekly average of 3.718.700 k cEMs per day
teamday(s)average output (k)
US-Distributed54,965.865.168 cEMs
Busty_Seventeen1.250,884.141.075 cEMs
SoB user Milestones and targets (4 October 2004)
Ordered by size
usermilestone (k)next target (k)
fsfikke7.000.000.000 cEMs8.000.000.000 cEMs
Warmachine6.000.000.000 cEMs7.000.000.000 cEMs
DPCquatar100.000.000 cEMs200.000.000 cEMs
iets10.000.000 cEMs20.000.000 cEMs
SoB user Megaflush top 5 (4 October 2004)
Updated once a day (the highest flushs per user is counted)
posuserdateoutput (k)
1.[DPC]NGS(2004-09-10)31.934.704.681 cEMs
2.[DPC] Team_RC(2004-05-27)5.960.399.602 cEMs
3.The Anarchist(2004-07-11)4.631.907.414 cEMs
4.Sunnyboy(2004-08-05)1.802.259.549 cEMs
5.Stephan202(2003-12-16)1.136.926.801 cEMs
more
SoB Links
- SoB Homepage
- QiK SoB stats
- SoB Stats FAQ
- Official FAQ
- Official Stats
- Official forum
- SoB news
- SoB DPC Manual
GoT SoBstats engine 3.2 by Dukebox. Subteam stats hosted by QiK.nl
LinkedIn
  • Mobster
  • Laatst online: 07-06-2016
Mobster
Los Alcoholicos
Een plaatsje gestegen, maar daar is alles dan ook mee gezegd. DPC hoort toch minimaal op een vijfde plek daily. :/
Door het toevoegen van MarcyDarcy begint Los Alcoholicos ook een beetje op stoom te komen. Eens kijken hoe dit in de loop van de week gaat evolueren :) [DPC]Ben here we come.
En samen op weg naar Randy natuurlijk :)
Toch maar eens een andere sig bedenken :P
  • DPCquatar
  • Laatst online: 03-12-2024
DPCquatar
Kwaak
Het lukt mij hier niet om een test op te halen, ik moet via een proxyserver.
Is er een manier op te sneakernetten?
Cruncht tegenwoordig meestal vault projects
DPCquatar schreef op 05 oktober 2004 @ 13:54:
Zoek eens op Httport op /5.
Dan kom je er vast wel uit. ;)
Heb je sbqueue al geprobeerd met als remote server : sbp.pns.net:80 ;)
  • DPCquatar
DPCquatar
Kwaak
sbqueue heb ik wel bekeken, ik heb alleen geen idee hoe het werkt.
Ik ben volledig java-noob, dus als iemand me er door heern kan leiden.........
[ Voor 38% gewijzigd door DPCquatar op 05-10-2004 15:57 ]
DPCquatar schreef op 05 oktober 2004 @ 14:44:
neem aan dat je al java 2 (jre) geinstalleerd hebt ? zoniet, even doen dan.
open het .jar bestand met javaw en je kan hem configgen :P
  • DPCquatar
DPCquatar
Kwaak
Verwijderd schreef op 05 oktober 2004 @ 16:10:
Ok, dat is gelukt.
Krijg nu de volgende melding met versie 0.19;
Error: No blocks found from user DPCquatar
Please complete a block before attempting to fetch :?
Versie 0.20 zeurt niet, maar krijgt geen testen binnen.
Wordt vervolgd...............
[ Voor 12% gewijzigd door DPCquatar op 05-10-2004 17:12 ]
  • joh14vers6
  • Laatst online: 13-06-2024
Originally posted by jjjjL
OK, I built a new v2 client for BeOS... however, I built in on a P3 so it can't run it.
I need help testing it to make sure it works.
1) Download http://www.seventeenorbust.com/download/sbv2beos
2) chmod +x sbv2beos
3) mv sbv2beos sb
4) edit sclient.conf and change username to "secret"
5) ./sb sclient.conf
6) Post result after first test finishes
7) See if I say "Good, it works!" or "Hold on, let me try again"
Cheers,
Louie
Draait hier iemand BEOS?
Het wordt tijd dat Louie de client v2.0 geschikt maakt voor niet SSE2 proc's. Hij kan niet eens zijn eigen gemaakte clients testen. 8)7
[ Voor 5% gewijzigd door joh14vers6 op 05-10-2004 23:04 ]
Systeem van Joh14vers6 Team Joh14vers6 Gear: Sony 550, HS3600, Minolta 50mm/1.7, Tamron 10-24mm, Minolta 24-105, Minolta 100-300 (D) Te koop: Sigma 10-20mm KM 18-70mm
  • Haranaka
  • Laatst online: 23-10 09:33
Ik had altijd op het forum op sob.com gelezen dat v3 de opvolger zou worden van v1 omdat ze een foute weg waren ingeslagen bij de ontwikkeling van v2 en hem toen maar v3 zijn gaan noemen toen ze weer opnieuw begonnen waren met coden. Hoe zit dit eigenlijk, is dit dan toch een voortvloeisel uit die 'foute' v2 code of is dit v3 die ze nou weer hebben omgedoopt tot v2 :?
  • fenrir
fenrir
dat is inderdaad iets wat onduidelijk is. zolang dit alleen een sse2 client is zal niet niet de v3 moeten kunnen zijn. ik verwacht dat er dus nog geheel nieuwe client komt waar niet alleen het sse2 gebeuren in zal zitten.
