[PHP] mail() wil niet met GMail en Hotmail?
  • 49 views sinds 30-01-2008
  • Grijze Vos
  • Laatst online: 21-02 23:50
Ik krijg het maar niet aan de gang met hotmail en gmail.
Dir komt uit de maillog:
Oct  3 17:10:37 bierenfriet sendmail[11694]: i93FAb6V011694: from=www, size=219, class=0, nrcpts=1, msgid=<200410031510.i93FAb6V011694@bierenfriet.nl>, relay=www@localhost
Oct  3 17:10:37 bierenfriet sendmail[11694]: i93FAb6V011694: to=gmailadres@gmail.com, ctladdr=www (80/80), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30205, relay=localhost.my.domain. [IPv6:::1], dsn=2.0.0, stat=Sent (i93FAbLA011695 Message accepted for delivery)
Oct  3 17:10:37 bierenfriet sendmail[11699]: i93FAbG9011699: from=www, size=217, class=0, nrcpts=1, msgid=<200410031510.i93FAbG9011699@bierenfriet.nl>, relay=www@localhost
Oct  3 17:10:37 bierenfriet sm-mta[11700]: i93FAbLA011700: from=<www@bierenfriet.nl>, size=470, class=0, nrcpts=1, msgid=<200410031510.i93FAbG9011699@bierenfriet.nl>, proto=ESMTP, daemon=IPv6, relay=localhost [IPv6:::1]
Oct  3 17:10:37 bierenfriet sendmail[11699]: i93FAbG9011699: to=ander@testadres.nl, ctladdr=www (80/80), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30203, relay=localhost.my.domain. [IPv6:::1], dsn=2.0.0, stat=Sent (i93FAbLA011700 Message accepted for delivery)
Oct  3 17:10:38 bierenfriet sm-mta[11702]: STARTTLS=client, relay=vaak.stack.nl., version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Oct  3 17:10:38 bierenfriet sm-mta[11702]: i93FAbLA011700: to=<ander@testadres.nl>, ctladdr=<www@bierenfriet.nl> (1721/100), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=30456, relay=vaak.stack.nl. [IPv6:2001:610:1108:5010:248:54ff:fe6b:2cec], dsn=2.0.0, stat=Sent (Ok: queued as 9174C1F057)
Heeft iemand ideeen, want ik word er gestoord van. 8)7
[edit]
Later in de logs komt dit tevoorschijn:
Oct  3 17:19:51 bierenfriet sm-mta[11811]: i93FAbLA011695: to=<gmailadres@gmail.com>, ctladdr=<www@bierenfriet.nl> (1721/100), delay=00:09:14, xdelay=00:00:00, mailer=esmtp, pri=120458, relay=gsmtp57.google.com., dsn=4.0.0, stat=Deferred: Operation timed out with gsmtp57.google.com.
Oct  3 17:19:51 bierenfriet sm-mta[11811]: i93F4jLA011526: to=<gmailadres@gmail.com>, ctladdr=<www@bierenfriet.nl> (1721/100), delay=00:15:06, xdelay=00:00:00, mailer=esmtp, pri=120458, relay=gsmtp57.google.com., dsn=4.0.0, stat=Deferred: Operation timed out with gsmtp57.google.com.
[ Voor 21% gewijzigd door Grijze Vos op 03-10-2004 17:23 ]
Op zoek naar een nieuwe collega, .NET webdev, voornamelijk productontwikkeling. DM voor meer info
  • chem
  • Laatst online: 27-08 13:53
chem
Reist de wereld rond
De relatie met PHP ontgaat me nogal.
Welke mailserver gebruik je?
move P&W -> NT
Klaar voor een nieuwe uitdaging.
  • elgringo
  • Laatst online: 01-09 18:17
PHP gebruikt de stanaard sendmail van linux (daar ga ik iig van uit) deze standaard sendmail instellen wordt veel geblokt (door oa hotmail ed.) Als je je maildeamon beter configureert moet het goed gaan.
if broken it is, fix it you should
  • Grijze Vos
Ja, ik heb idd eventjes via de shell gemailed, en daar werkt het ook niet. die [PHP] tag mag dus idd weg. ;)
  • Grijze Vos
elgringo schreef op 03 oktober 2004 @ 17:46:
Ik gebruik sendmail onder FreeBSD 5. Enige tips m.b.t. wat ik moet herconfigureren?
  • Grijze Vos
Hier nog wat interessants:
(greyfox@bierenfriet)/var/log $telnet mx1.hotmail.com 25
Trying 64.4.50.99...
^C
(greyfox@bierenfriet)/var/log $ping mx1.hotmail.com
PING mx1.hotmail.com (65.54.166.99): 56 data bytes
^C
(greyfox@bierenfriet)/var/log $traceroute mx1.hotmail.com
traceroute to mx1.hotmail.com (64.4.50.50), 64 hops max, 44 byte packets
 1  defaultrouter-230-pand37.tue.nl (131.155.230.1)  1.711 ms  3.013 ms  1.308 ms
18  ten8-1.bay-osr-b.ntwk.msn.net (64.4.63.113)  165.700 ms  165.626 ms  165.317 ms
19  gig1-2.bay-6np-hot-6b.ntwk.msn.net (64.4.42.45)  165.881 ms  165.498 ms  165.806 ms
20  * * *
21  * * *
3 verschillende IP's bij hotmail. :s
(greyfox@bierenfriet)/var/log $ping gsmtp57.google.com
PING gsmtp57.google.com (216.239.57.27): 56 data bytes
64 bytes from 216.239.57.27: icmp_seq=0 ttl=240 time=161.042 ms
(greyfox@bierenfriet)/var/log $telnet gsmtp57.google.com 25
Trying 216.239.57.27...
^C                     // doet niks verder
(greyfox@bierenfriet)/var/log $traceroute gsmtp57.google.com
traceroute to gsmtp57.google.com (216.239.57.27), 64 hops max, 44 byte packets
 1  defaultrouter-230-pand37.tue.nl (131.155.230.1)  1.561 ms  1.481 ms  1.243 ms
 7  64.215.195.210 (64.215.195.210)  4.241 ms  4.013 ms  4.182 ms
 8  * * *
3x hetzelfde IP bij gmail, de ping werkt wel, maar het telnetten direct naar hun poort werkt iig niet, en een traceroute wil ook niet heel ver komen.
Dit is echt frutrerend. Oh, btw wat speurwerk via google op 'sendmail timeout hotmail' leert me dat het waarschijnlijk toch niet aan mn sendmail config ligt. :s Grr, ik word echt gek. :(
[ Voor 43% gewijzigd door Grijze Vos op 03-10-2004 18:05 ]
  • Grijze Vos
Ik begin het gevoel te krijgen dat ik op dit netwerk met remote ports 25 niet kan connecten, ik dacht dat ze alleen local ports 25 hadden geblocked. :s
  • Koffie
  • Laatst online: 22:06
Koffie
Koffiebierbrouwer
Braaimeneer
Dicht op verzoek.
Braaikamer - Smoke&BBQ
