[gentoo]no screens found
ok ff opnieuw proberen ik krijg mn kde niet aan de praat als ik hem opstart met X krijg ik:
X Protocol Version 11, Revision 0, Release 6.7
Build Operating System: Linux 2.4.26 i686 [ELF]
Current Operating System: Linux mymachine 2.6.7-gentoo-r11 #1 Wed Sep 29 13:32:38 CEST 2004 i686
Build Date: 14 July 2004
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 29 22:33:31 2004
(==) Using config file: "/root/xorg.conf"
Parse error on line 50 of section Monitor in file /root/xorg.conf
The HorizSync keyword must be followed by a list of numbers or ranges.
(EE) Problem parsing the config file
(EE) Error parsing the config file
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.X.Org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
en mijn conf file ziet er als volgt uit:
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/TTF/"
FontPath "/usr/share/fonts/Speedo/"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/share/fonts/CID/"
FontPath "/usr/share/fonts/75dpi/"
FontPath "/usr/share/fonts/100dpi/"
EndSection
Section "Module"
Load "extmod"
Load "dri"
Load "dbe"
Load "record"
Load "xtrap"
Load "glx"
Load "speedo"
Load "type1"
Load "freetype"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/mouse"
EndSection
Section "Monitor"
#DisplaySize 310 230 # mm
Identifier "Monitor0"
VendorName "IVM"
ModelName "BX3814UT"
HorizSync 28.0 - 64.0
HorizSync 12592.0 - 0.0
VertRefresh 48.0 - 0.0
Option "DPMS"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "Dac6Bit" # [<bool>]
#Option "Dac8Bit" # [<bool>]
#Option "ForcePCIMode" # [<bool>]
#Option "BusType" # [<str>]
#Option "CPPIOMode" # [<bool>]
#Option "CPusecTimeout" # <i>
#Option "AGPMode" # <i>
#Option "AGPFastWrite" # [<bool>]
#Option "AGPSize" # <i>
#Option "GARTSize" # <i>
#Option "RingSize" # <i>
#Option "BufferSize" # <i>
#Option "EnableDepthMoves" # [<bool>]
#Option "EnablePageFlip" # [<bool>]
#Option "NoBackBuffer" # [<bool>]
#Option "DRIReinit" # [<bool>]
#Option "PanelOff" # [<bool>]
#Option "DDCMode" # [<bool>]
#Option "MonitorLayout" # [<str>]
#Option "IgnoreEDID" # [<bool>]
#Option "OverlayOnCRTC2" # [<bool>]
#Option "CloneMode" # [<str>]
#Option "CloneHSync" # [<str>]
#Option "CloneVRefresh" # [<str>]
#Option "UseFBDev" # [<bool>]
#Option "VideoKey" # <i>
#Option "DisplayPriority" # [<str>]
#Option "PanelSize" # [<str>]
#Option "ForceMinDotClock" # <freq>
Identifier "Card0"
Driver "ati"
VendorName "ATI Technologies Inc"
BoardName "Radeon RV200 QW [Radeon 7500]"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
mij pc specs:
monitor: iiyama bx3814ut 1024*768
videokaart: all-in-wonder radeon 7500
moederbord: Gigabyte 845PE, P4 Titan 667
processor: p4 2.4ghz
als je naar de error file kijkt zegt ie dat de fout in regel 50 zit dat is: HorizSync 12592.0 - 0.0 regel als ik deze comment geeft ie de zelfde error
[ Voor 32% gewijzigd door Verwijderd op 29-09-2004 23:53 ]
  • Zwerver
Tja het spijt me zeer, maar je zult toch eerst even met Wilke moeten mailen voordat je weer een nieuwe opent. Ik maak iig niet uit je topicstart op dat je dat gedaan hebt, en zomaar een nieuw topic openen is niet de bedoeling.
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • Wilke
  • Laatst online: 22:58
Dat klopt, maar ik had in mijn sluitmessage aangegeven wat hij moest doen, en dat zie ik hierboven bijna allemaal wel staan, dus van mij mag hij weer open :)
Moet je opletten hoeveel het helpt als alle informatie er staat:
Er gaat duidelijk iets mis met het detecteren van het beeldscherm. De fouten zitten in regel 50 en 51. Daarom gaat het ook mis als je regel 50 wist, want dan wordt regel 51 regel 50, en daar zit dan weer een fout in:
Als je even in het boekje van je beeldscherm kijkt, zul je wel zien dat dit geen geldige 'ranges' zijn voor refresh rates. Als Xorg -configure serieus *dit* heeft gegenereerd, dan is dat een bug. Wat de refresh ranges voor jouw type monitor wel moeten zijn zou je kunnen opzoeken op het internet, of achterin het boekje (als je dat nog hebt), bij de technische specs.
Doordat je nu genoemd hebt welk type scherm je hebt, heb ik de specs in 10 seconden met google kunnen vinden: IIyama bx3814ut.pdf. Een lastig detail is wel dat deze in het bulgaars is ;) , maar gelukkig zijn de cijfers wel hetzelfde, dus kun je er in terugvinden dat dit er zou moeten staan:
HorizSync 30.0 - 60.0
VertRefresh 55.0 - 70.0
Door regel 50+51 daardoor te vervangen moet het lukken. Trouwens, ik zie dat op regel 49 ook een HorizSync spec staat: "HorizSync 28.0 - 64.0". Haal die dan ook maar weg, ik weet niet of het kwaad kan als er dingen dubbel staan, maar helpen zal het in ieder geval ook niet.
Is volgens mij idd een bug ofzo, ik had het gisteren ook met Xorg -configure. "HorizSync groot getal" - 0.0, VertRefresh stond goed, en er kwam nog een HorizSync statement achteraan kakken met 0.0 - 0.0, voor zover ik het me kan herinneren.
Ah; http://freedesktop.org/bugzilla/show_bug.cgi?id=1198 :)
[ Voor 66% gewijzigd door Verwijderd op 30-09-2004 12:19 ]
  • Wilke
Hmm...
Nog zo een.
Conclusie: Xorg -configure zuigt nogal :?
Of ligt het aan Gentoo? Dat lijkt me toch sterk, want er zijn geen patches ofzo (bij mijn weten) op de standaard code van X.org.
[ Voor 35% gewijzigd door Wilke op 30-09-2004 13:57 ]
  • zAo
  • Laatst online: 17-08 08:51
zAo
GPLv2 Fanboy
Als je fglrxconfig opnieuw draait en de h-sync en v-sync uit je boekje haalt, daarna XF86Config renamen naar xorg.conf, werkt het dan wel? Ik denk namelijk dat je sync niet goed staat :?
het was idd de horizsync en de vert... maar nu ik deze anders heb ingesteld maar krijg ik eeen zwartscherm met een error van me monitor me"t:
out of range
H: +60.0 KHz
V: +60.0 Hz
Range
H: 30-65 KHz
V: 55-75 KHz
max: 1024*768
nu heb ik geprobeerd 60 erbij op te tellen en eraf te trekken maar het lukt niet
60-60 bij hriz en vert heb ik ook geprobeerd
[ Voor 8% gewijzigd door Verwijderd op 01-10-2004 21:23 ]
  • silentsnake
  • Laatst online: 17-06 05:34
Wilke schreef op 30 september 2004 @ 13:56:
Nah, dat denk ik niet hoor. Ik heb het op drie machines gebruikt (een AMD64 en twee x86's) en daar ging het in één keer zonder problemen.
@TS
Je hebt je refreshrates te hoog ingesteld, anders geeft je monitor dat niet aan. Wees blij dat ie dat doet, want je kan flink je monitor om zeep helpen op die manier ;)
Hmm...
Nog zo een.
xorgconfig is gewoon een geporte xfree configure tool. Het is werkelijk allemaal hetzelfde. Ik zou ff anders de bug opgeven in gentoo bugs program...mocht die er nog niet staan
  • smokalot
  • Laatst online: 15-01 22:00
smokalot
titel onder
Verwijderd schreef op 02 oktober 2004 @ 00:17:
xorgconfig is iets anders dan X -configure.
It sounds like it could be either bad hardware or software
als je in het pdf bestandje kijkt zie je dat voor 1024-786 de minimale vert range 60 hz is en niet 55.
Verwijderd schreef op 02 oktober 2004 @ 09:03:
Heb ik ook al gebrobeerd
iik heb geprobeerd de twee ranges gewoon aleebei te commenten maar dan pakt hij zlef twee ranges en geeft daar weer dezelfde error op (out of range)
hmmmmm topic een beetje dood :(
  • smokalot
smokalot
titel onder
Verwijderd schreef op 04 oktober 2004 @ 11:32:
tja, wij kunnen ook niet zoveel voor je betekenen, je moet op de een of andere manier correcte refreshrates voor je monitor weten te bemachtigen. dat kan met google, met xorgconfig (en dan gewoon standaard-monitor kiezen bijvoorbeeld), met knoppix (die heeft een eigen script wat een config aanmaakt volgens mij).
Dus, je moet een juiste monitor-sectie zien te krijgen, en die dan kopieren naar de config die X -configure heeft gemaakt.
  • marrekau117
  • Laatst online: 16-08 21:57
Heb je de ati drivers al geinstaleerd??? Als je xorgconfigur helemaal door loopt moet je ook gewoon netjes de refresh rate van je scherm enzo in kunnen stellen. Dan heb je iig een goede basis waar je vanuit kan werken.
  • Tuxie
  • Laatst online: 22:41
Tuxie
En WeL nU!
Je kunt toch gewoon de standaard VGA syncrates proberen? Werkt altijd, in de configuratiefile worden deze als het goed is ook gegeven.
zet je driver eens op VGA ipv ATI
ik neem aan dat het in de ati driver zit, heb zelf ook wat problemen mee gehad.
als ik thuis kom zal ik even in mijn logs kijken wat ik er toen aan gedaan had
als de driver : vga wel werkt (
Identifier "Card0"
Driver "vga"
weet je iig waar je verder moet zoeken.
NB.
ik neem aan dat je dit al hebt gedaan:
# emerge ati-drivers (of media-video/ati-gatos [ Masked ])
# opengl-update ati
[ Voor 20% gewijzigd door Verwijderd op 06-10-2004 12:21 ]
