• Brammel
  • Laatst online: 22:04
Een nieuwe mp3 spler van Cowon. Hij was in korea en zo al te verkrijgen, hier nu ook. Eerst ff wat pics:
Pics
Afbeeldingslocatie: http://eng.iaudio.com/zeroboard/new_img/product/iaudioU2/iaudioU2_03_big.jpg
Afbeeldingslocatie: http://eng.iaudio.com/zeroboard/new_img/product/iaudioU2/iaudioU2_02_big.jpg
Afbeeldingslocatie: http://eng.iaudio.com/zeroboard/new_img/product/iaudioU2/iaudioU2_21_big.jpg
Specs
MP3, MP2, WMA, ASF and WAV (Up to 44.1khz Stereo) Playback, Voice Recording, FM Radio, Listening and Recording, Direct MP3 Encoding, Removable Disk
Built-in Flash Memory (256MB / 512MB / 1GB)
4 Lines of Graphic LCD (Indigo Blue Backlight)
USB 2.0 Interface
Long Playback Time: Up to 20 hours (Based on company's self-test)
Multi - Multilingual Support
- iAUDIO U2 uses common fonts and over 40 thousand character to display languages from all over the world.
- Supports 4 lines of automatic Lyrics display.
Enhanced Integrated Navigator
Play/Pause/Play Intro, Stop/Power Off, Record
Next Track/Previous Track, Fast Forward/Fast Rewind
Infinite Loop
Supports Resume. Fade In, Auto Play
Search Speed & Skip Speed Setting
40 levels of digital volume control
Various EQ and sound field effects
- User adjustable 5-band Equalizer
- Normal, Rock, Pop, Jazz, Classic, Vocal, User
- Supports BBE, Mach3Bass, MP Enhance, 3D Surround
Resume, Auto Power Off
Hold
Backlight ON Time Control, Scroll Speed
Firmware & Logo Download
ID3V2, ID3V1, Filename Support
Product Info Display (Firmware version, Memory Capacity/Usage)
Software
- JetShell (File Transfer, MP3/WMA/WAV/Audio CD Play, MP3 Encoding)
- JetAudio (Integrated multimedia playing software)
Bit Rate MPEG 1/2/2.5 layer 3 (8Kbps ~ 320Kbps) (8kHz ~ 48kHz) and VBR
WMA (20Kbps ~ 192Kbps) (8kHz ~ 48kHz) and WAV (Up to 44.1Khz Stereo)
Memory 256MB/512MB/1GB
File Transfer Speed Max. 20Mbps (Upload 25Mbps)
Battery Built-in Rechargeable Lithium Polymer Battery
(Max. 20 Hours Continuous Playback)
Power AC adapter DC 5V, 1.5A ~ 3A
Charging Time Normal mode (2 hours), Slow mode ( 6 hours and 30 Min)
Buttons 7 buttons (Play, REC, Menu, FF, REW, VOL+, VOL-)
Switch Hold
Display 128 X 64 full graphic LCD
SNR 95 dB
Max Output 16 Ohm earphone : 13mW + 13mW
Frequency Range 20Hz ~ 20KHz
Size 73.8mm X 25.0mm X 18.0mm (H X W X D)
Weight 34g (Include Lithium Polymer battery)
Poll: Welk formaat Iaudio U2 koop jij?
• 256 MB
• 512 MB
• 1 GB
Afbeeldingslocatie: http://poll.dezeserver.nl/results.cgi?pid=21171&layout=2&sort=prc
Review
Hier is een uitgebreide review te vinden
Belangrijkste verschillen t.o.v. de Iaudio 4:
- Ingebouwde batterij (kan een voordeel en een nadeel zijn)
- USB 2.0
- Ogg vobis ondersteuning bij een nieuwe firmware
- Nog kleiner/lichter
- Geen scherm met verschillende achtergrondkleuren meer
Mijn belangrijkste vragen:
- Wanneer is die in Nederland te koop (heb mp3spelers.nl gemaild, maar die konden er nog niks over zeggen)
- Wat gaat die kosten (Hier is de U2 30 pond goedkoper dan de Iaudio 4)
Links
Egnelse Iaudio site
Nederlandse handleiding
Hier
Niewste firmware
Hier
MIJN REVIEW
Hier is ie dan, mijn review van de Iaudio U2 (512 mb). Heb hem vorige week dinsdag besteld, een donderdag kwam de koerier. Er was helaas niemand thuis, vandaar dat ik hem vandaag (maandaag 11 oktober) pas binnen heb gekregen. Heb hem pas net, maar zal toch een zo'n goed mogelijk review proberen te maken
Inhoudsopgave
Inhoudsopgave
1) Inhoud doos
2) Data-transfer
3) Afspelen muziek
4) Geluidskwaliteit
5) Instellingen
6) Bediening
7) Pics
1) Inhoud van de doos
* Adapter voor opladen op 230 volt (bij mmport.nl krijg je die er "gratis" bij)
* Oordoppen
* Cd met Software
* Koortje voor om je net
* Hoesje voor de speler
* Usb verloop stukje
* USB kabel
* Line in kabel
* nog iets vergeten? o ja de Iaudio U2 zelf natuurlijk nog
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20IMG_3300.JPG
2) Data transfer
De Iaudio U2 wordt automatisch herkent als externe harddisk, dus er is geen software nodig. De software die op de cd er bij staat is echter wel handig om mp3's over te zetten. Je ziet gewoon onder in beeld de iaudio U2 meteen staan, en kan bovenin door je hdd mappen bladeren en de mp3's meteen doorsturen naar je U2.
De snelheid heb ik even gemeten, hij deed 100 mb in 1 minuut, wat neerkomt op 1,66 mb per seconde. De speler staat dus vrij snel vol. De speler ondersteunt ook mappen, zodat het allemaal erg overzichtelijk blijft.
3) Afspelen van muziek
Dit gaat vrij makkelijk, als je hem aanzet begint ie meteen te spelen (als je dit hebt ingesteld). Dit duurt ongeveer 5 seconde. Je krijg eerst een bewegend logo van Iaudio, dat trouwens makkelijk te vervangen is, en dan begint de muziek meteen. Ideaal is de dynamic playlist, zodat je gewoon nummers toe kan voegen aan de playlist terwijl de muziek door speelt. Verder zit er natuurlijk radio op, line in recording en voice recording. Tussen 2 nummers zit trouwens vrij weinig stilte, iets van een halve seconde of zo. Ook als je snel door de nummer scrollt en je stopt om een nummer af te spelen begint de U2 eigenlijk meteen.
4) Geluidskwaliteit
Toen ik de eerste keer naar de U2 luisterde was ik enorm verbaast, wat een heerlijk geluid komt er uit. Ik heb helaas weinig vergelijkingsmateriaal, maar ik ben er in ieder geval enorm tevreden over. Nu ben ik niet echt zo'n enorme audiofiel, maar er komt in ieder geval een goede bass uit. Dit is trouwens nog allemaal in te stellen met de equalizer.
Het geluid van de radio heb ik even met 3fm getest, wat natuurlijk een goed ontvangst heeft. Radio 538 kan ik hier (Weert) niet met de U2 ontvangen, maar dat kon ik ook al niet met m'n gewone radio, dus denk dat het ontvangs hier gewoon heel slecht is.
Het geluid kan trouwens echt super hard, je kan hem instellen van 0 tot 40, en ik heb hem meestal zo rond de 13 staan. Zodra je hem boven de 25 zet is het echt niet meer te houden ;). Het geluid wordt dan ook wel slechter.
5) Instellingen
Ik heb het idee dat je vrij veel in kan stellen, goede equalizer met een aantal standaard presets, de bass kan je apart instellen, enz. Ook de opnamekwaliteit van de radio, line in en voice kan je allemaal in stellen. Het contrast van het lcd kan je instellen, echt vanalles.
6) Bediening
Wat me meteen opviel toen ik hem uitpakte, was dat hij erg klein is. Bovendien is hij echt super licht, weegte gewoon bijna niks.
In het begin had ik vrij veel moeite met de joystick, maar heb er nu een tijdje mee zitten spelen, en heb het idee dat hij nou wat soepeler is, en het een stuk beter werkt. Ook als hij in het beschermhoesje zit zijn alle knoppen nog goed te bedienen. Alleen de line in is dan afgesloten.
De eerste keer dat ik de speler op wou laden, hing ik hem aan de ac adapter. Volgens mij was dit de eerste keer niet de bedoeling, want toen ik hem loskoppelde was hij vastgelopen. Even resetten, en toen toch maar aan de pc gehangen. Dit ging meteen goed, en hij is daarna ook niet meer vastgelopen.
Het schermpje is trouwens echt goed te zien, mooi blauw licht, contrast dus instelbaar, dus altijd goed zicht. Moet het morgenoverdag nog wel even testen als de zon er vol op staat, maar volgens mij zit dat wel goed.
7) Pics
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20IMG_3318.JPG
De U2 en een zakmes
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20IMG_3319.JPG
Een diskette, de U2 en de ac adapter
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0043.JPG
Een deel van het opstart "filmpje". Heb die trouwens al veranderd
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0045.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0048.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0051.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0052.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0053.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0060.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0062.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0064.JPG
Afbeeldingslocatie: http://members.home.nl/bramderoos/Iaudio%20U2/Resize%20of%20PICT0065.JPG
[ Voor 84% gewijzigd door Brammel op 12-10-2004 21:23 ]
mp3spelers.nl heeft tegen mij gezegd eind september.
maar dat zal wel niet dus.
eindelijk iaudio flash met usb 2.0
vraag me af wat ie gaat kosten idd. :)
Kun je dan niet beter de CM Tech Live CA-F300 pakken ? die is nog kleiner (bijna de helft van de iaudio) , en nu al Ogg Vorbis , en veel verschillende kleuren achtergrond en ik denk ook wel iets goedkoper en ook Koreaans.
[ Voor 19% gewijzigd door Verwijderd op 29-09-2004 20:37 ]
Overigens was ogg ook bij de I4 beloofd via firmware, dus eerst zien, dan geloven..
  • Brammel
Verwijderd schreef op 29 september 2004 @ 20:36:
Vind hem zoiezo niet zo mooi eigenlijk, en bovendien vraag ik me af of die net zo'n goed geluid geeft als de iaudio's
  • hoodlum
hoodlum
prijzen in duitsland:
256 (rood): EUR 175,90
512 (blauw): EUR 239,90
1024 (zwart): EUR 359,90
http://www.cyberport.de/
versturen voor ~20 euro naar NL met vooruitbetaling of CC.
  • Ojjorz
Ojjorz
De oude man die alles kan
Brammel schreef op 29 september 2004 @ 22:57:
Tot nu toe is gebleken dat Iaudio heel wat betere mp3-spelers maakt dan andere koreaanse merken. Nu zal ik binnenkort een klein testje kunnen doen tussen de Iaudio4 en de Cmtech, dus dan zullen we zien.
  • Brammel
Op mmport.nl is de U2 nu ook aangekondigd voor 249 euro (512mb). Hij is leverbaar vanaf 5-10-2004. De AC reisadapter wordt standaard meegeleverd!
[ Voor 41% gewijzigd door Brammel op 30-09-2004 12:35 ]
Ja een vergelijk tussen de iaudio u2 en live ca-f300 lijkt me wel ok!
Het prijsverschil is in ieder geval duidelijk aanwezig.. B)
Ik vind hem we ERRUG klein hoor! (moet ik weer een leesbril kopen voor het display, en als ik op me duim geslagen heb, dan kan ik hem niet aanzetten om verz8tende muziek op te zetten)
alleen me eigen centen
  • Brammel
Morgen is ie te koop op mmport.nl. Ik denk dat als hij op de site staat als beschikbaar ik hem koop. Uiteraard volgt dan hier een review
edit: Ik heb hem besteld, er staat levertijd 1 a 2 dagen, dus hoop dat ik hem voor het weekend binnen heb
[ Voor 34% gewijzigd door Brammel op 05-10-2004 18:03 ]
[b]
Ik was zelf ook aan het kijken naar een mp3-speler. Was van plan de iRiver iFP-895 te kopen maar zag toen dat de iAudio U2 binnenkort zou uitkomen.
Heb je hem inmiddels binnen en hoe bevalt hij?
  • Brammel
Verwijderd schreef op 09 oktober 2004 @ 20:39:
Ja, was echt balen, donderdag is er iemand langs geweest, maar er was niemand thuis. Dus ik meteen vrijdagochtend om half 9 bellen om te vragen of ze vrijdag langs konden komen, maar nee hoor, de chauffeur was al weg. Krijg hem nu dus maandag. Ik kan niet meer wachten ;)
Brammel schreef op 09 oktober 2004 @ 20:58:
Jammer, ik heb in de tussentijd hier een eerste review gevonden:
http://eng.iaudio.com/zer...p?id=B05&no=23080&bmenu=B
Op deze Amerikaanse site verkopen ze de 1 Gb versie voor € 200,- (ex. verzendkosten).
http://www.jetaudio.com/products/iaudio/u2/
Er is wel een addertje onder het gras, bij het afsluiten van de bestelling kreeg ik deze melding:
Unfortunately we cannot accept orders from Netherlands for iAUDIO U2 1GB Platinum Black at this time.
Een e-mail gestuurd naar Jetaudio met de vraag of ze toch willen leveren naar Nederland, maar even afwachten of ze positief reageren.
Ik ben op zich hoopvol, er staat: 'at this time' en de website geeft de prijs in euro's en dollars.
  • Brammel
Verwijderd schreef op 09 oktober 2004 @ 22:55:
Die "eerste" review staat ook al in de startpost 8)7
200 euro voor de 1 gig versie is niet zo duur idd. Maar ja, als ie uit amerika moet komen, dan zullen er nog aardig wat kosten bij komen. Maar hou ons op de hoogte. (niet dat ik er nog iets aan heb ;))
Brammel schreef op 09 oktober 2004 @ 23:32:
Oops, niet gezien :o
  • Cruzer
  • Laatst online: 22-10 22:22
Ik ben van plan om deze U2 ook te kopen alleen zit ik te twijfelen of de 512 MB of de 1 GB. Het is namelijk een prijskwestie :?
Op dit moment biedt alleen http://www.mmport.nl/ de U2 aan in NL. Ik wacht nog ff totdat er meer winkels deze Iaudio U2 aanbieden in de hoop dat die goedkoper wordt maar ben bang van niet ;(
When the pink is snookered, Go for the brown
  • Ojjorz
Ojjorz
Cruzer schreef op 10 oktober 2004 @ 15:15:
Alle winkels maken volgens mij zoiezo prijsafspraken. De 2 grootste winkels hebben voor alle belangrijke spelers dezelfde prijs. Je maakt mij niet wijs dat ze het niet goedkoper kunnen, ze willen gewoon niet.
  • Cruzer
Hier alvast voor de startpost de NL Handleiding voor de Iaudio U2:
http://eng.iaudio.com/dow...UDIOU2/iAUDIOU2_Dutch.pdf
Misschien is deze link ook wel handig voor de startpost wat de laatste FIRMWARE is van de Iaudio U2: http://www.iaudiophile.net/viewtopic.php?id=22
[ Voor 35% gewijzigd door Cruzer op 10-10-2004 21:28 ]
  • Cruzer
• 256 MB
• 512 MB
• 1 GB
  • Brammel
Cruzer schreef op 10 oktober 2004 @ 21:24:
• 256 MB
• 512 MB
• 1 GB
Ik heb de poll even schaamteloos over genomen in de startpost
Morgen avond zal ik eerste ff een korte review geven, als ik hem dan 1 of 2 dagen heb gebruikt komt de uitgebreide review inclusief foto's.
Zijn er al meer tweakers die al een U2 hebben of besteld hebben?
[ Voor 29% gewijzigd door Brammel op 10-10-2004 23:02 ]
  • Cruzer
Brammel schreef op 10 oktober 2004 @ 22:45:
Geeft niks :) Ik kijk uit naar je review! Welke heb jij overigens besteld?
  • Brammel
Cruzer schreef op 11 oktober 2004 @ 13:49:
Hij is binnen, wordt nu opgeladen (geloof ik...) Heb de blauwe 512 mb versie.
Eerste indruk: Klein!!!!!!!!
[ Voor 6% gewijzigd door Brammel op 11-10-2004 17:42 ]
MP3speler zou de U2 deze week binnen krijgen maar wel een stuk goedkoper als 189,- en 249,- euro (volgens John Oostdijck van mp3speler) ben benieuwd wat hij daar gaat kosten dan....
[ Voor 3% gewijzigd door Verwijderd op 11-10-2004 19:35 ]
  • Brammel
Heb al ff de snelheid van de usb poort getest, 100 mb in 1 minuut, dus 1,66 mb per seconde
  • Brammel
Heb ff een review'tje aan de startpost toegevoegd. Als er specifieke vragen zijn, laat maar horen
  • Cruzer
Verwijderd schreef op 11 oktober 2004 @ 18:09:
De webwinkel www.mp3man.nl heeft exact dezelfde prijzen als www.mmport.nl :| Ik vind het verschil tussen USA en EUR erg groot met de prijzen, nu weet ik wel dat de USA Dollar laag staat maar toch....... We zullen wel zien wat de concurrenten gaan doen :?
  • Cruzer
Brammel schreef op 11 oktober 2004 @ 21:25:
Leuke start-review maar ik verwacht nog zeker een uitgebreide review :P . Wat was jou reden om de 512 MB te kopen en niet de 1GB? En is het al gelukt om jouw U2 te laden met de net-adapter?
  • Brammel
Cruzer schreef op 12 oktober 2004 @ 01:05:
Wat denk je van de prijs ;) En vond de blauwe wel wat mooier. Bovendien denk ik dat 512 wel voldoende is
  • Brammel
Heb een stuk betere foto's in de startpost gezet. Ben eigenlijk nog absoluut geen nadelen tegenkomen. Heb hem vandaag even als usb drive getest, wat natuurlijk ook super werkt. Kon vanmiddag trouwens niet de 98 drivers van de jetaudio site halen, dus dat is een klein minpuntje, neem aan dat ze binnekort weer online zijn. Het opstart filmpje is trouwens te skippen, waardoor de speler nog sneller muziek begint te spelen.
  • Erik1
Menu's enzo zien er allemaal wel een beetje het zelfde uit als op mijn Iaudio M3 20GB, zitten ook de zelfde dopjes bij :)
  • Cruzer
" Adapter voor opladen op 230 volt (bij mmport.nl krijg je die er "gratis" bij) "
Hoe zit het met Laden van de IAUDIO U2? Hoe lang duurt het met die Net-Adapter en zit die er overigens standaard bij? :?
  • Brammel
Cruzer schreef op 13 oktober 2004 @ 12:43:
Ja, zit er bij mmport standaard bij, maar hij zat niet in de iaudio doos, maar los er bij. Dus als je hem bij een andere winkel zou gaan kopen, moet je dat wel even goed nakijken.
Opladen duurt aan usb poort 2 uur, dus denk met de ac adapter ook 2 uur
Ik heb eens gemailt naar mp3spelers daar gaat de 1GB versie nog geen 289,- euro kosten, voor de rest konden ze nog geen prijzen geven maar het was in ieder geval voor de 512MB een stuk goedkoper als 249,- euro. Ben benieuwd wat de andere dan gaan doen.
[ Voor 27% gewijzigd door Verwijderd op 13-10-2004 14:09 ]
  • Cruzer
Brammel schreef op 13 oktober 2004 @ 12:52:
Ja idd dat is wel apart iig thanks!
  • Cruzer
Verwijderd schreef op 13 oktober 2004 @ 13:55:
Klopt ik heb ook een mailtje gehad van Heleen hij moet volgende week leverbaar zijn? Ik hoop dat die 1GB zo rond de € 249 wordt, liefst nog goedkoper natuurlijk :9 Maar de andere winkels zullen neem ik aan ook wel hun prijs aanpassen?
Maar we moeten nog ff weekje doorbijten :O
  • Brammel
Heb net ff de firmware geupgrade naar 1.10. Klokfunctie zit er nu bij, alarm, en betere bereikbaarheid van de files/menu. Het opstartlogo is weg, waardoor er nu binnen 2 seconden nadat je hem aan zet geluid uit komt.
  • Cruzer
Brammel schreef op 13 oktober 2004 @ 19:30:
Maar die Firmware is toch alleen bedoeld voor Korea? Of maakt dat niet uit? Op de internationale site van Iaudio vindt je namelijk ook niks over evt Firmware wel op de Koreaanse Site van Iaudio.
Maar iig werkt het dus prima?
Hier de changelog van de nwe Firmware V1.10
U2 Menu structure as in Firmware Version 1.10
Mode
Mp3 Player
FM Radio
Voice Recorder
Line-In Recorder
JetEffect
Equalizer
Normal (Flat EQ, can not be edited)
Rock
Jazz
Classical
Pop
Vocal
User
BBE (Levels 0-10)
Mach3Bass (Levels 0-10)
MP Enhance (On or Off)
3D Surrounds ( Levels 0-10)
Pan (20 left; 20 Right)
Play Mode
Boundary ( All, Folder, Playlist, Single File)
Repeat (On, Off)
Shuffle (On, Off)
Display
View Watch (On, Off)
Lyrics (On, Off)
Play Time (Elapse, Remain)
Song Title (ID3 Tag V2, ID3 Tag V1, File Name)
Scroll Speed (0-8)
Page Sliding ( Off, Fast, Normal, Smooth)
Language (Note: This only changes character support, not the languages in the menus)
Chinese (simplified)
Chinese (traditional)
English
Hangul (Korean)
Japanese
Russian
Contrast (1-9)
Backlight Time
Always Off
3 Seconds
5 Seconds
10 Seconds
30 Seconds
60 Seconds
Always On
Timer
Set Time
Wakeup mode
Off
Music Alarm
FM Alarm
FM Record
Wakeup Time
Music Alarm (Possibility of setting time, possibility of setting alarm to go off once only or daily, duration of alarm)
FM Alarm (Possibility of setting time, possibility of setting alarm to go off once only or daily, Possibility of selecting channel, duration of alarm)
FM Record (Possibility of setting time, possibility of setting alarm to go off once only or daily, Possibility of selecting channel, duration of alarm)
Sleep (this turns off the player after a given amount of time)
Off
10 Minutes
20 Minutes
30 Minutes
40 Minutes
50 Minutes
60 Minutes
90 Minutes
120 Minutes
180 Minutes
Auto Off (turns the player off when nothing is playing; saves battery)
Off
30 Seconds
1 Minute
5 Minutes
10 Minutes
30 Minutes
60 Minutes
General
Skip Length (what happens when you shortly tap FF or REW)
Track
2 Seconds
3 Seconds
4 Seconds
5 Seconds
10 Seconds
15 Seconds
20 Seconds
30 Seconds
Scan Speed (the speed you FF or REW through a track)
x1
x2
x4
x8
x16
Resume (On, Off)
Autoplay (On, Off)
Charge (Normal, Slow, Off)
Song Order
Download Time
File Name
File Time
Control
REC Long
Set Bookmark
Lyrics On / Off
Menu Button
Set short pressdown of Joystick to enter Navigator
Set short pressdown of Joystick to enter Menu
Recording
Linein bps (96, 112, 128 kbps)
Voice bps (96, 112, 128 kbps)
FM Radio bps (96, 112, 128 kbps)
Mic Volume (1-10)
Voice Active (0-10)
Line Volume (1-10)
Auto Sync (0-8)
FM Radio
Stereo (Mono, Stereo)
Auto Scan
Region (Chine, Europe, Japan, Russia, Korea, US)
Information (Firmware Version, Flash Memory capacity and Battery Voltage)
  • Brammel
Cruzer schreef op 13 oktober 2004 @ 19:52:
..knip..
Ja werkt gewoon, had het wel eerst ff op een forum nagevraagd of dat zomaar kan. Het enigste verschil met de "koreaanse" firmware is volgens mij dat de instellingen standaard op korea staan. (zoals taal en radio). Heb trouwens ook het idee dat je nu sneller door de menu's en file's kan bladeren.
De alarm functie begrijp ik niet helemaal, neem niet aan dat iemand het alarm insteld op b.v. 8 uur 's ochtends, en dan de hele nacht met de oordopjes in z'n oren gaat slapen?
[...]Maar ja, als ie uit amerika moet komen, dan zullen er nog aardig wat kosten bij komen. Maar hou ons op de hoogte. (niet dat ik er nog iets aan heb ;))
Ik zou jullie op de hoogte houden:
Kreeg dezelfde dag nog een e-mail terug dat mijn e-mail was geforward naar een ander e-mailadres. Blijkbaar staat op hun website een verkeerd sales e-mailadres.
Omdat ik daarna geen enkele reactie meer kreeg een tweede e-mail gestuurd. Daar tot nu toe ook geen reactie op ontvangen.
Wel hebben ze inmiddels hun website aangepast...
(er is nu selectbox toegevoegd waarbij je alleen de landen: USA en Canada kunt kiezen)
Er is overigens een oplossing voor bestellen bij Amerikaanse e-shops die alleen leveren in de USA.
http://www.myus.com/
Je krijgt een Amerikaans bezorgadres en zij forwarden de pakketten dan weer door naar Nederland. Het is alleen wel vrij prijzig. Nuttig voor mensen die veel bestellen in de USA.
Ik ga mijn U2 maar gewoon in Nederland kopen.
[ Voor 3% gewijzigd door Verwijderd op 14-10-2004 12:43 ]
  • Cruzer
Ik hoorde dat als je bv losse nummer op je U2 heb dat tijdens het overgaan naar het volgende nummer dat die dan kraakt/tik iig hij doet het niet geruisloos.
En... hoe doet de U2 het met Mix-CD's met een Cue file speelt die heel de CD af als 1 los nummer?
  • sunturion
  • Laatst online: 31-10 22:24
Mooie review, maar kan wel wat uitgebreider.
Ik zit er aan te denken in december een mp3 speler te halen en zit nog te twijfelen tussen de Iaudio U2 512 mb en de iRiver iFP 795 512 MB.
De vragen:
Kan je door middel van de klok/alarmfunctie nu ook opnames in programmeren net zoals dat mogelijk is met de iRiver iFP 795 512 MB ?
• Hoe is de kwaliteit van het beschermhoesje ?
• Hoe gaat de Iaudio U2 om met VBR mp3's?
• Kan de Iaudio U2 met die nieuwe firmware nu ook ogg vorbis aan?
• Hoe zit het met de body van de speler, komen er snel krassen op of is hij daar goed bestendig tegen?
• Voelt hij eigenlijk stevig aan?
• Tot welke bitrates kan je met de voice recorder en de line-in recorder opnemen?
• Hoe is de kwalitweit van de voice recorder? Zou je mischien samples online willen zetten?
• Hoe is de kwalitweit van de line in recorder? Zou je mischien samples online willen zetten?
• Kan je nog steeds gebruikmaken van de necklace als de speler in zijn beschermhoesje zit?
• Hoe zit het met de navigatie? In je review vermelde je dat je er vrij veel moeite mee had? Waarmee had je precies moeite ?
• Zorgt het navigeren door het menu tijdens het spelen voor problemen?
• Hoe lang gaat hij mee op een volle accu?
• Uit hoeveel nummer kan een playlist maximaal bestaan?
• Als de batterij bijna op is krijg je dan een melding of gaat hij gewoon uit?
• Heb je zelf nog bugs gevonden?
En zou je mischien wat meer pics kunnen plaatsen :)
In the name of God, impure souls of the living dead shall be banished into eternal damnation. Amen.
  • Cruzer
sunturion schreef op 17 oktober 2004 @ 03:54:
De vragen:
Misschien heb je hier wat aan?? Dit is een uitgebreide review:
  • Brammel
Ja, volgens mij is dat mogelijk ja
Goed, hij past precies om de speler, en alle knoppen zijn nog goed te bereiken. Alleen de line in ingang is afgesloten.
Geen idee (VBR mp3's???)
Nee volgens mij nog niet
Heb er nog geen krassen op, heb hem wel atlijd in het hoesje zitten, maar volgens mij is de speler wel krasbestendig
Ja zeker, er zit absoluut geen speling of zo in de behuizing
Line in: 96, 112 of 128 kbs
Voice: 96, 112 of 128 kbs
Sampels staan al ergens op de jetaudio site. Heb nu ff geen tijd om samples te maken
Misschien staan die ook wel op de jetaudio site
Ja, ook hiervoor zit er een gat in het hoesje, trouwens ook voor de microfoon
Het joystickje was ff wennen, maar als je het eenmaal onder de knie hebt werkt het heel goed
Nee, helemaal niet. Alleen bij het verwijderen van een file stopt de muziek ff
Geen idee, hij is nog niet leeg geweest.
Zal ik binnekort ff testen
Er zit een batterij indicator op, en je kan precies het voltage van de batterij uitlezen, bijvoorbeeld 4,04 volt of zo
Nee, alleen dat er tussen 2 nummer heel zacht een geluid ontstaat
Meer pics volgen misschien, heb je specifieke dingen die je wilt zien?
[ Voor 5% gewijzigd door Brammel op 17-10-2004 12:36 ]
  • Cruzer
VBR MP3's zijn MP3's waarvan de bitrate verspringt tijdens het afspelen van het afspelen van zo'n MP3. Dus dat die daar waar nodig van 320 naar 96 gaat of andersom.
Maar nog van me vraag over losse nummers dus toch dat je een hapering ofzo hoort... is dit erg irriterend?
En hoe doet de U2 het met Mix-cd's icm cue files? Of leest die geen cue-files?
Thanks,
Cruz
Ik hoop de mijne volgend weekend te mogen hebben.
  • Brammel
Cruzer schreef op 17 oktober 2004 @ 16:31:
Thanks,
Cruz
Aha, zou niet weten of ik ergens een vbr mp3 heb. Heb trouwens ook geen mix cd's icm cue file, dus ook dat kan ik je helaas niet vertellen. Over de geluid tussen 2 nummers, eerst hoorde ik het niet, hoorde het pas toen ik er hier in dit topic iets over las. Nu ik het echter weet hoor ik het bijna nooit tussen 2 nummers, je moet er echt op letten en zelfs dan hoor je het niet altijd
  • franktv
  • Laatst online: 10-05-2025
Zit er bij deze speler ook een armband voor het sporten? deze zit volgens mij wel bij de Iaudio 4.
  • Cruzer
Ik zie de U2 nu ook op de site staan van mp3spelers.nl . Alleen is die net als mp3man.nl nog niet leverbaar.
mp3spelers.nl is wel goedkoper dan mmport.nl en mp3man.nl
Ik ben bnwd wanneer mp3spelers ze gaat leveren?? En zijn er nog in NL nog winkels die de U2 goedkoper aanbieden dan mp3spelers.nl ??
Groet,
Cruzer
  • Brammel
Cruzer schreef op 19 oktober 2004 @ 13:33:
Groet,
Cruzer
Oef, gelukkig maar 12 euro goedkoper (512 mb) dan mmport.nl. Had het vervelend gevonden als hij opeens bijvoorbeeld 40 euro goedkoper zou zijn dan wat ik heb betaald. Er zit trouwens wel een beschermhoesje bij, maar geen armband voor het sporten. Aan het beschermhoesje zit wel een ding zodat je hem aan je riem kan maken.
Groet,
Cruzer
vrijdag denk ik
[ Voor 29% gewijzigd door Verwijderd op 20-10-2004 12:22 ]
Groet,
Cruzer
Ik heb net de 1 GB besteld, volgens mp3spelers is de leverdatum vrijdag of zaterdag.
Ik hoop vrijdag :)
  • Cruzer
produkt: aantal: prijs/stuk: totaal:
Cowon iAudio U2 1000 MB 1 € 288,99 € 288,99
Subtotaal: € 288,99
Transactiekosten: € 0,00
Verzendkosten: € 5.00
Totaal: € 293,99
De verzending geschied met TPG pakketdienst en zal binnen 1 tot 3 werkdagen bij u worden aangeboden (mits het product op voorraad is). Indien u op het moment van aflevering niet thuis bent dan laat de postbode een briefje achter en kunt uw alsnog de bestelling de volgende dag ophalen bij het postkantoor in uw woonplaats.
Met vriendelijke groet,
MP3spelers.nl
Ik hoop dat ik de mijne voor het weekend heb :P
[ Voor 15% gewijzigd door Cruzer op 20-10-2004 10:30 ]
  • Cruzer
Ik weet niet of het hier wel thuis hoort maar ik ben van plan om deze hoofdtelefoons te gebruiken: Sony MDR-EX71SL voor mijn Iaudio U2 die ik hoop dit weekend te mogen ontvangen :D
http://www.hermeselectron...30954_sony_mdrex71sl.html
Ik heb begrepen via veel forums dat deze super zijn!
Iemand ervaring met deze hoofdtelefoons en met de webwinkel www.hermeselectronics.nl ?
Thanks,
Cruzer
Cruzer schreef op 20 oktober 2004 @ 08:55:
Subtotaal: € 288,99
Totaal: € 293,99
MP3spelers.nl
Erg grappig Mp3spelers.nl zet de U2 speler op hun website (als laatste) en goedkoopste en heeft ze als eerste :) en die andere shops verlagen de volgende dag (vandaag) naar dezelfde prijs. .... :'(
[ Voor 3% gewijzigd door Verwijderd op 20-10-2004 12:20 ]
  • Cruzer
Verwijderd schreef op 20 oktober 2004 @ 12:19:
Ja idd ik kreeg vanochtend een mailtje van MP3man.nl dat ze niet meegaan met de prijs van mp3spelers.nl maar blijkaar toch wel. Maar het is idd wel zo dat mp3spelers ze wel kan aanbieden vanaf donderdag..... Heeft iemand overings goede ervaring met mp3spelers.nl? Qua levering&service,garantie?
  • Cruzer
mailtje van Mp3spelers.nl :
De laatste status van de importeur is dat wij ze morgen binnen krijgen , dit kan een dag vertragen als de douane in het pakket moet kijken. We kunnen dus morgen of vrijdag verzenden.
Service RMA
Holland Global
Postbus 298
5060 AB Oisterwijk
Nederland
Alleen zo verrekte jammer dat ik die OGG Vorbis-support dubieus vind -- maar dat zal wel te maken hebben met mijn iRivier verleden. Anders had ik wel even gewacht op deze in plaats van de IOPS.
mp3spelers.nl krijgt ze morgen (donderdag) binnen zie website
[ Voor 71% gewijzigd door Verwijderd op 20-10-2004 15:08 ]
  • Cruzer
Verwijderd schreef op 20 oktober 2004 @ 15:05:
Idd :P dus worden ze morgen verzonden en worden ze vrijdag geleverd door
TPG Pakketservice. Ik hoop dat mp3spelers.nl ook de TPG 3S barcode mailt zodat je via TPG Post track&trace online kan zien wat de status van de verzending is.
Groet,
Cruzer
  • Cruzer
[quote]Cruzer schreef op 20 oktober 2004 @ 15:26:
Geachte heer/mevrouw,
Hartelijk dank voor uw bestelling Helaas kunnen wij u morgen de track en trace code pas doormailen We ontvangen namelijk morgen pas de zending met de i-Audio U2 (zie ook info op onze website ) .We mailen u dan direct de track en trace code even door dat is natuurlijk geen enkel probleem.
Mocht u verder nog vragen hebben mailt u ons dan gerust We helpen u graag verder.
Fijne avond verder.
Heleen
Holland Global
M.Hobbemastraat 3
5062 LN Oisterwijk
Nederland
Fax: +31 (0)13 - 5230575
www.mp3spelers.nl
sales@mp3spelers.nl
Ik heb trouwens gelijk deze MP3 cd-speler voor mijn zusje gekocht:
iRiver iMP 450 Slim X
Heeft iemand ervaringen met deze speler.
Ik kan geen reviews vinden voor deze specifieke speler (Google).
  • Cruzer
Nieuwe FIRMWARE V1.20 BETA (Korean) is uit! Met Ogg-support!!
http://ihome.iaudio.com/i...C&desc=asc&no=152&bmenu=C
[ Voor 14% gewijzigd door Cruzer op 21-10-2004 01:25 ]
  • Brammel
Cruzer schreef op 21 oktober 2004 @ 01:24:
Mooi zo, zie wel alleen maar blokjes, dus kan niet verder lezen wat er is veranderd.
  • Cruzer
[quote]Cruzer schreef op 20 oktober 2004 @ 15:39:
Fijne avond verder.
Heleen
Holland Global
M.Hobbemastraat 3
5062 LN Oisterwijk
Nederland
www.mp3spelers.nl
sales@mp3spelers.nl
Ik krijg de mijne morgen! Ik heb ook de TPG barcode ontvangen!
:9~
Verwijderd schreef op 20 oktober 2004 @ 18:45:
Ik heb een keer een test gelezen en toen kwam de slim x 450 er als 2e beste uit (1e was een sony van 289,- euro) dus eerlijk was het niet want de imp 450 kost maar 129,- euro.
:9~
Lees net dat de mijne morgen wordt bezorgd :) 8)
[ Voor 3% gewijzigd door Verwijderd op 21-10-2004 14:28 ]
  • baldbelow
  • Laatst online: 22:03
De mijne wordt ook morgen waarschijnlijk bezorgd, vandaag de 1Gb besteld en barcode ontvangen, ben benieuwd!
baldbelow schreef op 21 oktober 2004 @ 19:23:
Volgens mij heeft iedereen de 1GB , niet zo raar want het prijsverschil is te klein met de 512MB en de 256MB vind ik weer iets te duur. Op deze foto kun je ook goed zien dat de oortelefoonaansluiting en line out uitgang van metaal is en niet van plastic (zoals veel van die goedkope krengen)
Afbeeldingslocatie: http://www.mp3spelers.nl/images/produkten/207_4.jpg
  • Cruzer
De mijne wordt zojuist verwerkt door mijn werkgever op de vestiging waar ik tevens ook werk. Ik mag de zending niet meenemen anders verstoort dit het distributieketen van TPG Pakketservice
De volgende gegevens zijn over uw zending gevonden:
Statusinformatie Datum Locatie
Zending geaccepteerd en gesorteerd door TPG Post 21-10-2004 Dordrecht-Pieter Zeemanwg , intern transport pakketten
  • baldbelow
Hmmm, bij mij vindt ie niks op mijn traceercode...
Er zijn geen zendingen gevonden voor deze combinatie.
Aaaah, als dat maar goed gaat!
edit: ze hadden per ongeluk de verkeerde code doorgegeven, heb nu wel de juiste en de zending is in de distributieroute, woohoo!
ontopic: dit moet wel gewoon een van de beste flashplayers van dit moment zijn, iaudio staat voor kwaliteit, kan niet wachten! :P
[ Voor 20% gewijzigd door baldbelow op 22-10-2004 11:23 ]
  • Cruzer
Ik heb de mijne gisteren (vrijdagmiddag) binnen gekregen!!! 8) Ik heb een aantal reviews gelezen en hij is idd echt klein!!!!!!!!!!!!!!!!!!! en superlicht 8)7
En een supergeluid komt er uit al hoewel dit mijn eerst MP3 portable is heb ik weinig ervaring daarmee maar het is echt top.
Ik heb de 1GB ik kom net van me werk dus ik ga er ff mee spelen!
Cruzer
  • Cruzer
vandaag ff met de U2 gespeeld en het is echt een top mp3speler. Ik heb wel echter een probleem met het afspelen van VBR MP3's hij speelt ze wel keurig af maar Rew en de FWD werken niet goed. De tijdbalk loopt niet goed mee. Ik heb V1.10 maar het probleem is niet opgelost! ;(
Ik hoop dat Iaudio daar wat aan doet!
Cruzer
Vrijdagmiddag bezorgd helaas pas vandaag tijd om ermee te spelen :)
Eerste zaken die opvallen:
  • Super licht en klein, ideaal voor sporten.
    Er zit geen draagarmband bij maar het draagtasje heeft wel een 'hengsel' waar er één doorheen kan.
  • USB aansluiting is lekker snel (nog niet precies gemeten hoe snel)
  • Draagtasje dat erbij zit is erg mooi, bij sommige spelers zitten soms tasjes die lijken op een plastic boterhamzakje ;)
Over de oordopjes ben ik nog niet uit. Misschien moet ik nog wennen maar mijn eerste indruk is dat ze iets te groot zijn. Geluid is wel goed.
Ik draai nu firmware 1.04 maar ga vanmiddag naar v1.10.
Er is ook een v1.20b (beta) uit met Ogg support, heeft iemand al ervaringen met deze versie?
En dan natuurlijk de foto's :)
Afbeeldingslocatie: http://www.orchid.demon.nl/pictures/iAudio_U2/iAudio_U2.JPG
Afbeeldingslocatie: http://www.orchid.demon.nl/pictures/iAudio_U2/iAudio_U2_with_pocket_knife_%5Bsmall%5D.JPG
Afbeeldingslocatie: http://www.orchid.demon.nl/pictures/iAudio_U2/iAudio_U2_with_carrying_case._%5Bsmall%5D.jpg
Afbeeldingslocatie: http://www.orchid.demon.nl/pictures/iAudio_U2/iAudio_U2_with_headphones_carrying_case_%5Bsmall%5D.jpg
mooie speler, ik ben er nog niet over uit of ik deze U2 ga kopen bij mp3spelers.nl of de mobiblu dah 1200 dat vind ik namelijk ook een hele mooie speler en ik vind 512mb wel genoeg.
[ Voor 16% gewijzigd door Verwijderd op 23-10-2004 16:37 ]
  • Cruzer
Ik heb V.1.20 Beta erop gezet en werkt goed ik zie geen verschillen alleen dat die nu perfect OGG afspeelt.
Waar ik wel van baal is dat die geen VBR goed vooruit en achteruit spoelt!
Ik neem aan dat iedereen hier last van heeft?
Als iedereen ook iaudio ff een mailtje stuurt met dit probleem, misschien passen ze het wel aan op de V1.20 Final
Cruz
  • sunturion
Cruzer schreef op 23 oktober 2004 @ 18:14:
Hopelijk word dit snel gefixed. Ik heb verdomd veel mp3's in vbr geript.
BTW
Is het met de V.1.20 Beta firmware al mogelijk om voice/radio in hogere bitrates te recorden?
  • Cruzer
sunturion schreef op 23 oktober 2004 @ 18:23:
BTW
Nee is niet mogelijk met V. 1.20 Beta, maar ik moet zeggen dat die 128Kbps opzich niet slecht is maar idd hoe hoger hoe beter ;)
Voor de VBR ja ik heb ook veel mp3's in VBR dit is het mailadres van Iaudio als iedereen nou ook ff een mailtje stuurt over de VBR en hogere Bitrates.
' iaudio@cowon.com '
Stuur het mailtje wel in het English :+
  • Brammel
Ik ben vandaag ff de batterijduur aan het testen. Heb hem vanochtend om 7 uur aangezet, kijken hoe lang hij het vol houd. Wat ik wel heb gemerkt dat als de batterij leeg is, hij de tijd vergeet. Deze moet je dand dus opnieuw instellen. Bovendien is het niet handig dat als je van de radio terug gaat naar de mp3 functie, hij dan op pauze staat. Dit is bij firmware 1.10 er bij gekomen. Hoop dat het hij bij 1.20 weer meteen begint met mp3's afspelen
  • Swatfireglide
  • Laatst online: 22:14
Heb hem ook sinds vandaag binnen. Echt super klein(en licht) en komt heerlijk geluid uit. Draai bios versie 1.10. Helaas heb ik eerste vastloper al wel gehad. Bij het overzetten van bestanden liep hij was en was enige mogelijk nog op de reset knop drukken. Het doorspoelen bij grote mixen (60min of meer) gaat wat traag vind ik persoonlijk. Verder kan ik tot nu toe alleen maar positief zijn over deze speler.
Dikke aanrader.
  • Brammel
Hij is bij mij nog steeds aan het spelen. Staat nu 11 uur aan, en heeft nog 1 batterij streepje. De 20 uur gaat ie dus nooit halen, denk eerder dat het ongeveer 13 uur zal worden. Gister was wel pas de eerste keer dat ie helemaal leeg was, dus kan best zijn de de batterij nog beter wordt als hij wat vaker op is geladen/leeg is
edit: Heb er trouwens niet de hele tijd oordopjes aan gehangen, neem niet aan dat dat uit maakt? Heb alleen maar mp3's afgespeelt, op volume 17 ongeveer. Verder af en toe van nummer geswitched, en de backlight staat op 5 seconde.
[ Voor 28% gewijzigd door Brammel op 25-10-2004 18:13 ]
  • Cruzer
Hebben jullie geen last van MP3 VBR files?? met het vooruit en achteruitspoelen en dat de tijdmeter niet meerloopt??
Gr,
Cruzer
  • Brammel
Hij staat nu 16 uur aan, en het batterij indicatortje knippert nu. Ik ga slapen, en wil morgen wel muziek luisteren, dus ga hem aan de lader hangen. Hij kan dus minimaal 16 uur muziek spelen, maar denk dat hij nog zeker een half uur door zou kunnen spelen. Lang zat dus!
Damn...iedereen die de U2 nog gaat bestellen goed opletten niet iedere MP3 shop geeft er die USB > 220v adapter bij (het staat er wel bij mij maar je krijgt niks) omdat het een extra is.
Afbeeldingslocatie: http://images.google.nl/images?q=tbn:rZHcVtI5BOwJ:http://www.futureweb.com.my/peripheral/usb.travel.ac%2520charger.adapt.jpg
  • Swatfireglide
Verwijderd schreef op 27 oktober 2004 @ 15:14:
Ik heb de mijne bij http://www.mmport.nl/ gekocht. Hierbij kreeg ik deze adapter WEL mee geleverd tot mijn verbazing. Scheelt me weer geld :)
  • Cruzer
Swatfireglide schreef op 27 oktober 2004 @ 15:29:
mp3spelers.nl kreeg ik de 220V usb adapter er ook apart bij
Cruzer schreef op 28 oktober 2004 @ 00:50:
Het is erg rustig op dit forum. De speler zal wel iedereen bevallen.
[ Voor 12% gewijzigd door Verwijderd op 29-10-2004 00:53 ]
  • Cruzer
Verwijderd schreef op 29 oktober 2004 @ 00:51:
Ja idd echter hoor ik weinig reacties van anderen over het feit dat mp3 VBR bestanden niet goed vooruit en achteruit worden gespoeld evenals dat die tijdbalk niet goed meeloopt zowel bij het afspelen en spoelen!
Het afspelen van een MP3 VBR doet die verder wel perfect
Mooie speler.. Hij ziete r echter wel wat dik uit. Valt dit in de praktijk mee? Want ik wil em ook in mijn broekzak kunnen proppen :)
Ik wou eerst voor de Iops 512 mb gaan, maar daar hoor ik zoveel klachten over - het lijkt wel alsof iedereen dat ding meerdere keren terug moet sturen als ik het forum lees.. :(
Jammer alleen dat deze geen gewone ingebouwde usb-stick heeft, moet ik dat tussenstukkie meeslepen. Maar als ie kwalitatief beter is is dat het overwegen waard..... Wat denken jullie?
Verwijderd schreef op 29 oktober 2004 @ 15:40:
Mooie speler.. Hij ziet er echter wel wat dik uit. Valt dit in de praktijk mee? Want ik wil em ook in mijn broekzak kunnen proppen :)
De speler is plat genoeg, hij zit in mijn broekzak en ik merk het niet eens (wat soms ook erg onhandig kan zijn...).
Perfekt geluid, en de ingebouwde usb aansluiting mis ik niet.
Met een ingebouwde USB aansluiting was hij waarschijnlijk groter geworden en dan kies ik persoonlijk liever voor een kleiner apparaat. Size does matter >:)
Het vooruit- en terugspoelen met VBR MP3 bestanden werkt inderdaad niet goed maar wanneer gebruik je die functie? Meestal wil je een liedje skippen en niet spoelen, dat is tenminste bij mij de praktijk.
Daarnaast is iAudio vrij vlot met firmware updates (zie Vorbis Ogg support) dus waarschijnlijk wordt dat probleem snel gefixed.
[ Voor 10% gewijzigd door Verwijderd op 29-10-2004 22:11 ]
  • Snoop
volgens gizmodo.com komen er (naast de in december uitkomende M5) in november (Korea) weer 2 nieuwe spelers van iAudio uit; de 5 en de G3 :)
Neither is quite as exciting as the iAudio M5, but we should also mention that Cowon also has a couple of other new MP3 players on the way, the iAudio 5 and the iAudio G3. Both are flash-based players and will probably come in the usual array of storage capacities (i.e. from 128MB up to 512MB or 1GB or something like that), and are supposed to be similar to the iAudio U2, with the iAudio 5 running off of a single AAA battery and the iAudio G3 running off a AA battery and getting up to 50 hours of playing time. Both should be out by November.
Afbeeldingslocatie: http://plappert.org/images/iAUDIOphilenet_small.jpg
meer foto's van de G3:
http://mp3.iaudio.com/product/product_G3_photo_pop.php?id=1
[ Voor 6% gewijzigd door Snoop op 31-10-2004 13:28 ]
Heeft iemand ervaringen wat betreft de voicerecorder? Ik zit op de School voor Journalistiek in Utrecht en het lijkt me ook wel handig als ik em dus voor interviews ofzo kan gaan gebruiken.. Klinkt het een beetje goed qua geluidskwaliteit en neemt het niet het halve geheugen in?
Ik hoop snel iets van iemand te horen, want als het antwoord positief is wil ik em wel bestellen denk ik! :)
Trowuens, ben ook wel benieuwd of die FM ontvangst nou echt zo slecht is als in somige reviews omschreven staat? Vang je er amper een zender mee of valt het wel mee, maar klinkt het alleen relatief slecht als je je stereo op de kabel gewend bent van thuis? ;)
  • Brammel
Verwijderd schreef op zondag 05 december 2004 @ 14:23:
Geluid opnemen vind ik echt goede kwaliteit, en ja, de radio is niet geweldig.
  • Cruzer
Helaas, :'(
mijn U2 1 GB werkt het display niet goed meer, de tekst kan ik niet meer lezen. Het app werkt verder wel goed, maar je hebt er weinig aan als je de tekst van display niet kan lezen. De test is erg vaag lijkt net dat je contrast niet goed staat. :'(
Ik heb van alles geprobeerd
- nwste Fw er opgezet 1.30 b1
- Contrast instellen
-Resetten
niks helpt dus maar opsturen naar mp3spelers.nl . Iemand meer info hoe dit kan gebeuren of meer mensen met dit probleem?? Op sommige forums heb ik meer van dit probleem gelezen bij gebruikers van de U2
  • Oyster
Oyster
Prince
Is er al wat meer bekend over de iAudio 5? 8)
  • NrG_82
Een topic kicken voor een vraag die je [url=ttp://www.iriver.com/html/support/forum/sufr_list.asp?categoryIdx=9]ergens anders[/] ook al hebt gesteld, wordt niet zo op prijs gesteld. Daarnaast gaat dit topic over de U2 en niet over de iAudio 5.
