uploaden naar hetnet
  • 119 views sinds 30-01-2008
  • hilbren
  • Laatst online: 11-08 15:27
Ik kan met geen enkele mogelijkheid uploaden naar het net, ik heb al een subacount aangemaakt en daar het username en pass. van geprobeerd maar ook geen resultaat. ik krijg de hele tijd de melding:
USER ########
331 Password required for ########
PASS (not shown)
530 User ######## cannot log in.
Not logged in.
het gaat hier om een adsl abo. van hetnet...
en die site van hetnet bevat eindeloos veel loops, je vind nooit een juist antwoord.
  • r0b
  • Laatst online: 11-08 08:11
r0b
[google=ftp error 530]
deze link bijvoorbeeld.
Question/Problem: When I try to connect to a remote site I receive an error, "530 user access denied". What does this mean and what do I need to do?
Answer/Solution: The error "530 user access denied" or "530 login incorrect" are FTP Server Return Code messages from the remote FTP server you are trying to connect to. These indicate that you are not properly logged on to the server.
Please make sure the host information in your Site/Session Properties is correct. Common problems are spaces, case sensitive entries, incorrect user name and/or password, etc.
If you are unsure of what to enter into the provided fields please click the Help button in Session Properties and/or contact the server administrator of the server you want to connect to (if a user name and password are required).
If you have to have an actual account on the FTP server, for example, a web site you are trying to connect to, then you will need to obtain from the server administrator the Hostname of the server, a User ID and a Password. These need to be entered correctly into your Site configuration in WS_FTP in order to connect. Please see the Help Files in WS_FTP for "configuring a site profile" using the login information you obtained FROM your hosting company.
If you are unable to connect and login, contact your web hosting company to verify your login information. Let them know you are using an FTP client to login, as your method of logging into the server may affect the format of your login information.
See also: WS_FTP Pro 8.0 User's Guide - "User access denied"
Document #: Revision Date:
WS-19980508-BK03 06/14/04
[ Voor 78% gewijzigd door r0b op 24-09-2004 00:15 ]
  • bemeall
  • Laatst online: 10:20
bemeall
Down Under!
Lijkt me toch een fout in username/password.
Misschien moet de domain-name achter username oid?
In het verleden behaalde resultaten bieden geen garantie voor de toekomst...
Case Sensitive login?
  • LaterGast.nl
  • Laatst online: 08-02-2024
LaterGast.nl
Doe je dat.
Zit jij wel via de ADSL verbinding van het net?
Bij sommige providers moet je op hun netwerk zijn ingelogd om te kunnen inloggen
Taking PORN off the internet is trying to get pee out of a swimming pool!!!
  • _BladE2k_
  • Laatst online: 09-09 20:05
Gebruikersnaam zonder @adsl-surfen gebruiken!
Direct uit de help van het net:
Een FTP-programma gebruiken
Heeft u éénmaal een FTP-programma gedownload en geïnstalleerd, dan gaat u als volgt te werk:
Start het FTP-programma en klik op Verbinden (connect)
Vul bij Hostname (remote) in: home.hetnet.nl
Vul bij User ID in: uw gebruikersnaam
Vul bij Password in: uw wachtwoord
Maak nu verbinding door op OK of op Verbinden te klikken
Er wordt nu een verbinding tot stand gebracht tussen uw eigen computer (Local) en de server (Remote)
Zoek in uw eigen computer (Local) naar de homepage-bestanden die u wilt uploaden
Zet de transfer mode op ASCII indien u tekst wilt uploaden en op Binary indien u plaatjes wilt uploaden. Of zet deze - als dat mogelijk is - op automatisch (de instelling automatisch is bij de meeste FTP-programma's standaard)
Selecteer de bestanden die u wilt uploaden, en hernoem (Rename) indien nodig de bestanden. De standaardnaam voor de openingspagina van uw homepage moet zijn 'home.html of index.html
Alle andere html-bestanden (pagina's) die aan uw homepage gekoppeld zijn mogen anders heten. Wel moeten alle bestanden de extensie .htm of .html hebben
P.s. deze dingen staan onder andere op http://home.hetnet.nl/default.htm
[ Voor 4% gewijzigd door _BladE2k_ op 24-09-2004 00:39 ]
Een standaard GoTter ;)
  • Reptile209
  • Laatst online: 16:52
Reptile209
- gers -
En niet vergeten om eerst op http://home.hetnet.nl/default.htm de homepage van je account te activeren, anders krijg je tot in lengte van jaren acces denied :+.
Edit: Hier dus om precies te zijn ;).
[ Voor 23% gewijzigd door Reptile209 op 24-09-2004 00:41 ]
Zo scherp als een voetbal!
  • hilbren
alles wat boven Reptile209 staat had ik al lang geprobeert, niks nieuw voor mij.
maar activeren :? daar heb ik nergens iets over gelezen, en op de link die je zojuist ga kan ik ook niks vinden over het activeren van de homepage...
ik zie het al:
daar is ook niks over verteld, in de help staat alleen "heeft u al een website gebruik dan een ftp prog om te uploaden" dat heb ik toen maar gedaan.
je moet dus inloggen op het linkje hierboven en dan gaat de rest vanzelf.
stom stom stom, ook stom van hetnet dat ze dat niet even duidelijker zeggen in de help, even een opsomming maken van alle stappen die uitgevoerd moeten worden is toch niet zoveel werk?
[ Voor 51% gewijzigd door hilbren op 24-09-2004 08:58 ]
