ECS EZ-Buddie D3V7-2 goedkope barebone?
  • 102 views sinds 30-01-2008
  • Skimmer
  • Laatst online: 16-10 15:42
Skimmer
Inter Arma Enim Silent Leges
Ik kon nog geen topic vinden, dus bij deze:
EZ-Buddie D3V7-2
Afbeeldingslocatie: http://www.ecs.com.tw/ECSWeb/images/logo.gif
Plaatjes
Afbeeldingslocatie: http://www.ecs.com.tw/ECSWeb/images/products/small/d3_s.jpg Afbeeldingslocatie: http://www.ecs.com.tw/ECSWeb/images/products/large/ezd3_180.jpg
Praatje
You don't hide your stereo system, DVD player or VCD under your desk, so why 'exile' your new PC to a dark, dusty, hard-to-reach comer? With stylish, elegant design and a very compact footprint, there's plenty of space for a great new EZ-Buddie on even the most crowded desk. Bring your Desktop PC back to the desktop means convenient access to optical device drive, card reader, EZ-Watcher gauges and speed turner button - all without bending and twisting.
Specs
Power & CaseBezel
  • D3
Power Supply
  • AC adaptor input 110~240V
  • 50~60Hz universal
Dimensions(mm)
  • 262 x 162 x 310mm
Speedometer EZ-Watcher
Case material
  • Aluminum
Front Panel
  • Earphone x1
  • Mic x1
  • USB x1
  • IEEE1394 x1
Rear Panel
  • PS2 x2
  • RS232 x1
  • Parallel x1
  • VGA connector x1
  • USB x4
  • RJ45 LAN x1
  • IEEE1394 x 1
  • Line in/ Line out/ Mic x1
Card Reader
  • Supports CF I
  • CF II
  • MD
  • SMC
  • SD/MMC
  • MS cards
Device Bay
  • 1 x 5.25"
  • 1 x 3.5"
Mainboard
Model
  • V7-2
Dimension
  • 244 x 205mm
Processor
  • Supports AMD Socket-A Athlon
  • Athlon XP
  • Duron processor with 333/266/133 MHz system bus
Core Logic
  • VIA 8378(KM400) + 8235
  • ACPI v1.0b
  • AGP v3.0
  • 3.3V PCI v2.2 compliant
Video & Graphics
  • Built-in graphic core and AGP 8X
  • High Performance 2D/3D graphics engine
  • Shared 64MB DDR frame buffer
System Memory
  • Supports 2DIMM DDR SDRAM 333/266/200MHz
  • up to 2GB
Audio
  • Compliant with AC'97 v2.3
  • 18 bits stereo full-duplex CODEC and 6 channel
Communications
  • On-board full duplex 10/100 base-T Ethernet
  • MAC built-in VIA 8235
Power Management
  • ACPI 1.0b compliant
BIOS
  • Award 2Mb Flash BIOS
  • Supports password Plug & Play
  • ACPI
  • DMI
  • Smart Fans
IDE Connector
  • Two 40pins IDE low profile headers
  • support up to 4 IDE device
  • Support PIO mode
  • ATA 133/100/66
USB Connector
  • USB2.0 compliant, up to 480Mbps
  • 4 ports USB on rear panel
  • 2 ports USB on headers
IEEE1394
  • 1394a v2.0 compliant, up to 400Mbps
  • rear: 1 por
  • header:1 port
Rear I/O
  • PS2 x2
  • RS232 x1
  • Parallel x1
  • VGA connector x1
  • USB x4
  • LAN port x1
  • IEEE1394 x1
  • Line in/Line out/Mic. x1
On board slot
  • AGP x1
  • PCI x1
  • CNR x1(shared with PCI slot)
Accessories
  • Cooling fan
  • Assembly manual
  • power cord
  • External Adapter
  • Supported CD
  • Two IDE cables
Systems Compliance
  • Windows XP
  • Windows 2000 Professional
Prijs en info:
Prijs: ~ 125 euro
linkjes:
In mijn optiek een zeer mooi systeem, met meer functionaliteit dan mijn huidige systeem, voor een fractie van het bedrag dat ik kwijt ben als ik nu van alles ga vervangen. Enige is, dat ik de prijs wat erg aan de lage kant vind, maar dat kan aan mij liggen.
Ervaringen iemand?
:9~ _/-\o_ of :r 8)7 ?
ps. ik heb een beetje geleend uit een ander topic (plaatje) hoop niet dat het een probleem is
[ Voor 9% gewijzigd door Skimmer op 21-09-2004 11:26 . Reden: Tabel breder Plaatje nu genaaid, maar vooruit... ]
In times of war the law falls silent
  • Skimmer
Skimmer
Niemand een mening?
Ik heb de buddie nu een week of 3 en hij bevalt goed.
De problemen waar ik tegenaan ben gelopen:
- CPU (xp2400) gaat richting 60 graden idle
- ATI 9800pro werkt niet ivm de gebrekkige stroomvoorziening.
De temps heb ik naar beneden gekregen door het kastje hoger te plaatsen en een softwarecooler te installeren (s2kctl)
Qua prijs kwaliteit is dit apparaat top; klein, redelijk stil en ziet er goed uit.
  • Skimmer
Skimmer
Verwijderd schreef op 21 september 2004 @ 16:10:
Heb je de mogelijkheid foto's te maken? ik ben namelijk wel benieuwd hoe het er allemaal uitziet als dat ding vol met hardware zit...
Hoeveel harde schijven kan je feitelijk kwijt in dat ding?
De buddie heeft:
- 1 x 3,5 inch slede
- 1 x 5,25 inch bay
Ik heb er een 160 Gb HD, een DVD brander en een Ti4200 128 Mb met Zalman HP80C cooler inzitten en met 2 molexen en een 200 W externe voeding ga je dan al aardig richting max qua ruimte en verbruik !!!
  • itsalex
Ik heb een Easybuddy staan van ECS. Model D1V7-2. Een keer en nooit meer. Sorry leuk dat ding. computer is stil inderdaad maar die adapter erbij. CDromspeler die opgaat en geluid gaat even uit. leuk maar niet voor mij. Geen PIO mode maar UDMA.
Frontside bus kan je leuk opvoeren maar voor de rest nee die KM400 is zooooo bagger en draai je teveel dan houdt die ermee op. Ik had een Seagete 40gb 7200 RPM Barracuda geloof ik. Ik draaide met een Athlon 2000XP+ maar met Windows SP2 hield die het voor het gezien. Voor de 135 euro inkoop koop ik liever de Asus T2P voor dezelfde.
I hit the CTRL key, but I'm still not in control!
  • WiLLoW_TieN
  • Laatst online: 22:51
Hiero staat een review over de versie met het P4 mobo maar kast is hetzelfde dacht ik.
  • Skimmer
Skimmer
itsalex schreef op 22 september 2004 @ 22:42:
Niet dat ik het niet leuk vind om moeilijk te doen... Die Asus is inderdaad erg mooi, en waarschijnlijk een stuk practischer...
Maar... dat is een kastje voor een P4... dan valt er voor mij met mijn AMD weinig om te prikken, en wordt het ineens een veel duurder geintje...
Des al niet te min ben ik blij met je reactie, en ik zal mijn aanschaf nog eens ernstig in overweging nemen.
  • Neus
  • Laatst online: 15-10 11:21
Ik heb deze uitvoering. Erg leuk ding. Mijn (ex) 9600XT werkte er helaas niet in wegens het missen van een molex. Heb er nu een 9800 Pro in zitten en die werkt als een tierelier. Compact systeem, stabiel, stil en mooi. Heb er een 160GB Maxtor schijf, 2x 512 Twinmos, 16x DVD fikker met DL 2.4 en een Athlon 2800+ inzitten. Temperatuur is laag, CPU 51 graden, systeem zelf 31. Ik was erg verrast over de compleetheid van dit systeem, mis er helemaal niets aan. Alles werkt goed en kan zelfs van een Compact Flash kaart booten.
Heb er hier in Italie € 99 ex 20% BTW voor betaald.
[ Voor 3% gewijzigd door Neus op 25-09-2004 22:32 . Reden: DVD brander vergeten. ]
Very funny, Scotty... Now beam down my clothes !
  • itsalex
Ik zou heel persoonlijk niet gaan voor ECS behalve als je het geld niet ervoor hebt ok logisch maar ik mis:
Floppydrive aansluiting
Stevigere materialen
Downloaden van drivers voor cardreader die niet goed wordt herkend in een keer
Cdromspeler laat geluid even stoppen en gaat daarna weer door(DMA staat aan)
Externe adapter maakt naar mijn mening teveel lawaai
Wordt vrij warm van binnen(ja is normaal maar bij deze iets meer en zeker met mijn TI4800SE)
Aansluiten extra cdromspeler of wat dan ook
molexaansluiting(knip je door dan heb je niets meer)
Draadadapter>computer te kort
Voor de rest leuke kast en werkt ook niet onaardig maar er zijn voor mij teveel punten om deze te verkopen en morgen zal ik roepen verkocht!!
Idd tis een leuke barebone voor als je geen geld hebt.
Zo heb ik hem dus aangeschaft aangezien ik een goed servertje nodig had.
Dus had hem staan met een proc die ik nog over had.
Een AMD Athlon 2600+ FSB 333FSB.
Maar tjonge, wat werdt dat heet onder de kap.
met of zonder kast maak geen verschil, idle temp 58 Graden.
Dus ben ik met het project bezig om mijn server te koelen met water.
Miss een beetje overkill maar het werkt wel...
Afbeeldingslocatie: http://home.planet.nl/~lamei071/323fclubforum/newserver1.jpg
Afbeeldingslocatie: http://home.planet.nl/~lamei071/323fclubforum/newserver2.jpg
