[C] Portserver embedded linux device *
Ik ben bezig met het schrijven van een portserver voor een embedded linux device (motorola coldfire MCF5280). Ik heb echter problemen met het versturen van data tussen de seriele poort en de tcp poort.
dit is mijn code tot nu toe :
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
                          main.c  -  description
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <sys/stat.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
#include <fcntl.h>
#include <termios.h>
#include "port_server.h"
#define BAUDRATE B115200
#define MODEMDEVICE "/dev/ttyS0"
#define _POSIX_SOURCE 1 /* POSIX compliant source */
#define FALSE 0
#define TRUE 1
int port=1500;
int serialfd;
int sock_descriptor;
int temp_sock_descriptor;
struct sockaddr_in sin;
struct sockaddr_in pin;
void process_serial_data(void)
        char buf[16384];
    char *bufptr;
        char *str;
        int pos = 0 ;
    int bytes;
    bufptr = buf;
    printf("serial data received \n");
        while (read(serialfd,bufptr,1) != 0) {
              pos++;
        str = buf;
    if (send(temp_sock_descriptor, str, strlen(str), 0) == -1) {
                exit(1);
        } else {
        printf("tcp data send \n");
void process_tcp_data(void)
        int bytesrecv, n ;
        char buf[16384];
    printf("tcp data received \n");
    bytesrecv = recv(temp_sock_descriptor, buf, 16384,MSG_PEEK);
        if (recv(temp_sock_descriptor, buf , bytesrecv,0) == -1) {
                exit(1);
    n = write(serialfd, buf, bytesrecv);
    if (n < 0) {
       exit(1);
        } else {
       printf("serial data send \n");
void openTCPConnection(void)
        sock_descriptor = socket(AF_INET, SOCK_STREAM,0);
        if (sock_descriptor == -1) {
                exit(1);
        bzero(&sin, sizeof(sin));
        sin.sin_family = AF_INET;
        sin.sin_addr.s_addr = INADDR_ANY;
        sin.sin_port = htons(port);
        if (bind(sock_descriptor, (struct sockaddr *)&sin, sizeof(sin)) == -1) {
                exit(1);
        if (listen(sock_descriptor, 20) == -1) {
                exit(1);
void openSerialDevice (void)
        struct termios oldtio,newtio;
    int n;
        serialfd = open(MODEMDEVICE, O_RDWR | O_NOCTTY| O_NDELAY );
        if (serialfd <0) {
                exit(EXIT_FAILURE);
        newtio.c_cflag = BAUDRATE | ~CRTSCTS | CLOCAL | CREAD;
        newtio.c_iflag = ~IGNCR ;
    newtio.c_iflag |= ~(IXON | IXOFF | IXANY);
        newtio.c_lflag = ~ICANON | CS8;
        tcflush(serialfd, TCIFLUSH);
        tcgetattr(serialfd,&oldtio); /* save current serial port settings */
        tcsetattr(serialfd,TCSAFLUSH,&newtio);
        //fcntl (serialfd, F_SETFL, FNDELAY);
        bzero(&newtio, sizeof(newtio)); /* clear struct for new port settings */
    n = write(serialfd, "hallo", 5);
void background(void)
        pid_t pid,sid;
        pid = fork();
        if (pid < 0) {
                exit(EXIT_FAILURE);
        if (pid > 0) {
                exit(EXIT_SUCCESS);
        /* als we zo ver komen zitten we in het juiste process. */
        if ((sid = setsid()) < 0) {
                exit(EXIT_FAILURE);
        if ((chdir("/")) < 0) {
                exit(EXIT_FAILURE);
        umask(0);
int main(void)
        int address_size;
        fd_set readfs;    /* file descriptor set */
        int    maxfd;     /* maximum file desciptor used */
        int    loop=1;    /* loop while TRUE */
    printf("open serial device \n");
        openSerialDevice();
    printf("open TCP Socket  \n");
        openTCPConnection();
//        background();
        while(1) {
                temp_sock_descriptor = accept(sock_descriptor, (struct sockaddr *)&pin, &address_size);
                if (temp_sock_descriptor == -1) {
                        exit(1);
                FD_ZERO(&readfs);
                FD_SET(serialfd, &readfs);  /* set testing for Serial device */
                FD_SET(temp_sock_descriptor, &readfs);  /* set testing for TCP port */
                maxfd = (temp_sock_descriptor > serialfd ? temp_sock_descriptor : serialfd) + 1;
                while (loop) {
                        select(maxfd, &readfs, NULL, NULL, NULL);
                        if (FD_ISSET(serialfd,&readfs)) {
                                process_serial_data();
                        if (FD_ISSET(temp_sock_descriptor,&readfs)) {
                                process_tcp_data();
        close(temp_sock_descriptor);
Nou het probleem:
Telkens als ik ook maar 1 character naar de seriele poort stuur dan blijft het programma herhalen :
Serial data recieved
TCP data send
Het lijkt wel of de buffer niet leeg gehaald wordt.
Het linux kastje ondersteund geen soft en/of hardware flow. En de snelheid en pariteit enzo zijn goed ingesteld.
ziet iemand hier nog iets vreemds aan want ik zie het niet meer 8)7
  • eghie
eghie
Spoken words!
Volgens mij geeft hij hier de hele tijd true terug:
C++:
           process_tcp_data();
Ik weet niet wat voor apparaat het is en hoe het werkt, maar je hebt gewoon een loopje draaien waarbij FD_ISSET bij beide gewoon true blijven geven. Dus hier moet je eens naar kijken.
[ Voor 21% gewijzigd door eghie op 20-09-2004 16:58 ]
  • Sjaaky
  • Laatst online: 11-10 16:37
Je moet voor elke aanroep van select je readfs schoonmaken en opnieuw opbouwen.
[ Voor 9% gewijzigd door Sjaaky op 20-09-2004 19:03 ]
  • drm
  • Laatst online: 09-06-2025
drm
f0pc0dert
Verzoeke de volgende keer even een prefix in je topictitel te zetten :)
Music is the pleasure the human mind experiences from counting without being aware that it is counting
~ Gottfried Leibniz
  • igmar
  • Laatst online: 26-09 18:37
igmar
ISO20022
Verwijderd schreef op 20 september 2004 @ 16:39:
<snip 300 regels code>
Nou het probleem:
TCP data send
Gewoonweg debuggen ? Een stukje uit de manual van select() :
On exit, the sets are modified in place to indicate which descriptors actually changed status.
MAW : je moet voor elke loop van select() je sets opnieuw intialiseren. Verder : Lees in een een blok data in, en niet 1 byte per keer. Extreem inefficient, en in maar weinig gevallen nodig.
  • farlane
  • Laatst online: 19-10 19:24
        char buf[16384];
Tjee, wat voor een device is dat eigenlijk ? Of hebben wij een andere opvatting van embedded ? :)
Somniferous whisperings of scarlet fields. Sleep calling me and in my dreams i wander. My reality is abandoned (I traverse afar). Not a care if I never everwake.
Debuggen is heel lastig op dat kastje.
Helaas heb ik alleen 's-maandags beschikking over het kastje maar dan kom ik er op terug ..
Alvast bedankt voor de reacties.
