cabinet file cannot be trusted ( directx 9.0c)
  • 68 views sinds 30-01-2008
Elke keer als ik directx 9.0c probeer te installeren, krijg ik de melding: a cibinet file nessasary for installation cannot be trusted.
nou was mijn vraag, hoe kom ik hier in hemelsnaam vanaf, want ik ben het nou wel eens zat!!!
iedereen die helpt, I love you!!!!!!!!!!!!!! :*)
(ik ben namelijk niet zo goed met computers zie je.. }:O )
ik weet dat het een beetje erg veel is, maar dit zei dxdiag erover:
System Information
Time of this report: 9/19/2004, 15:01:15
Machine name: DING
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: Dell Computer Corporation
System Model: Dimension 4600i
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
Processor: Intel(R) Pentium(R) 4 CPU 2.66GHz
Memory: 510MB RAM
Page File: 274MB used, 975MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file P16X.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the service provider 'DirectPlay8 TCP/IP Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 IPX Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Modem Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Serial Service Provider' is missing or damaged. You should reinstall DirectX. You should reinstall DirectX to get the latest version.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5200
Manufacturer: NVIDIA
Chip type: GeForce FX 5200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_01B910DE&REV_A1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.4501 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/30/2003 09:05:52, 3335916 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/30/2003 09:06:00, 1330172 bytes
Device Identifier: {D7B71E3E-4062-11CF-FB62-B32100C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0322
SubSys ID: 0x01B910DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Creative SB Live! Series
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: P16X.sys
Driver Version: 5.12.0001.0129 (English)
WHQL Logo'd: No
Date and Size: 8/14/2003 11:58:12, 1296384 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 96000
Static/Strm HW Mix Bufs: 64, 63
Static/Strm HW 3D Bufs: 64, 63
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative SB Live! Series, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SB Live! Synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SB Live! External MIDI [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SB Live! External MIDI [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D2
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/3/2003 18:52:58, 53120 bytes
| Driver: usbd.sys, 8/29/2002 06:00:00, 4736 bytes
Gameport Devices
+ Intel(R) 82801EB PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/29/2002 02:09:12, 62976 bytes
+-+ Game Port for SB Live! Series
| | Matching Device ID: pci\ven_1102&dev_7004&subsys_10031102
| | Service: gameenum
| | Driver: gameenum.sys, 8/29/2002 02:32:44, 9856 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 06:00:00, 51072 bytes
| Driver: kbdclass.sys, 8/29/2002 02:27:02, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 04:46:42, 38024 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC016
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 14:48:00, 12160 bytes
| Driver: mouclass.sys, 8/29/2002 02:27:02, 22016 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 TCP/IP Service Provider - Registry: Error, File: ()
DirectPlay8 IPX Service Provider - Registry: Error, File: ()
DirectPlay8 Modem Service Provider - Registry: Error, File: ()
DirectPlay8 Serial Service Provider - Registry: Error, File: ()
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Failed gracefully
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 65.2 GB
Total Space: 76.2 GB
File System: NTFS
Model: WDC WD800BB-75FRA0
Drive: D:
Model: HL-DT-ST DVD-ROM GDR8162B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 06:00:00, 47488 bytes
Drive: E:
Model: HL-DT-ST CD-RW GCE-8481B
System Devices
Name: Intel(R) 82865G\PE\P Processor to AGP Controller - 2571
Device ID: PCI\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\3&172E68DD&0&08
Driver: C:\WINDOWS\System32\DRIVERS\AGP440.SYS, 5.01.2600.0000 (English), 8/17/2001 14:58:00, 25472 bytes
Name: Intel(R) 82865G\PE\P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&172E68DD&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_01741028&REV_02\3&172E68DD&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1243 (English), 7/3/2003 18:51:46, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1243 (English), 7/3/2003 18:49:30, 138752 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1243 (English), 7/3/2003 18:52:58, 53120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_01741028&REV_02\3&172E68DD&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1243 (English), 7/3/2003 18:50:46, 25216 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1243 (English), 7/3/2003 18:50:12, 5632 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_01741028&REV_02\3&172E68DD&0&F9
Driver: C:\WINDOWS\System32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 14:51:52, 3328 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1164 (English), 1/31/2003 16:43:30, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.1211 (English), 4/23/2003 10:29:54, 87296 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_01741028&REV_02\3&172E68DD&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_01741028&REV_02\3&172E68DD&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_01741028&REV_02\3&172E68DD&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_01741028&REV_02\3&172E68DD&0&E8
Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_01741028&REV_02\3&172E68DD&0&FA
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&172E68DD&0&F8
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 14:58:02, 35840 bytes
Name: Intel(R) 82801EB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&172E68DD&0&F0
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.1106 (English), 8/29/2002 02:09:12, 62976 bytes
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1050&SUBSYS_01741028&REV_02\4&1C660DD6&0&40F0
Driver: C:\WINDOWS\System32\DRIVERS\e100b325.sys, 7.00.0026.0000 (English), 3/4/2003 13:56:26, 145408 bytes
Driver: C:\WINDOWS\System32\Prounstl.exe, 7.00.0005.0000 (English), 7/11/2003 13:15:48, 118784 bytes
Driver: C:\WINDOWS\System32\e100b325.din, 6/27/2002 07:53:38, 5110 bytes
Driver: C:\WINDOWS\System32\IntelNic.dll, 2.04.0000.0000 (English), 12/29/2002 06:00:02, 24064 bytes
Driver: C:\WINDOWS\System32\e100bmsg.dll, 2/3/2003 07:26:18, 12288 bytes
Name: Game Port for SB Live! Series
Device ID: PCI\VEN_1102&DEV_7004&SUBSYS_10031102&REV_00\4&1C660DD6&0&01F0
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.1106 (English), 8/29/2002 02:32:44, 9856 bytes
Name: Creative SB Live! Series (WDM)
Device ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00\4&1C660DD6&0&00F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/29/2002 02:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/29/2002 03:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (English), 12/12/2002 01:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/29/2002 06:00:00, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 01:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\P16X.sys, 5.12.0001.0129 (English), 8/14/2003 11:58:12, 1296384 bytes
Driver: C:\WINDOWS\System32\P16Xres.dll, 5.12.0001.0104 (English), 6/30/2003 13:35:18, 34304 bytes
Driver: C:\WINDOWS\System32\P16X.dll, 1.00.0000.0015 (English), 7/8/2003 15:41:48, 47616 bytes
Driver: C:\WINDOWS\System32\A3d.dll, 80.00.0000.0003 (English), 4/11/2002 02:41:00, 65536 bytes
Driver: C:\WINDOWS\Live.ico, 8/15/2001 11:24:00, 4398 bytes
Driver: C:\WINDOWS\Live.bmp, 8/17/2001 10:36:00, 3126 bytes
Driver: C:\WINDOWS\system32\drivers\eapci2m.ecw, 1/21/1999 17:31:00, 2259070 bytes
Name: NVIDIA GeForce FX 5200
Device ID: PCI\VEN_10DE&DEV_0322&SUBSYS_01B910DE&REV_A1\4&1246FE7B&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.4501 (English), 10/30/2003 09:06:00, 1330172 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.4501 (English), 10/30/2003 09:06:00, 126976 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.4501 (English), 10/30/2003 09:06:02, 73728 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.4501 (English), 10/30/2003 09:05:52, 3335916 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.4501 (English), 10/30/2003 09:06:00, 3837952 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.4501 (English), 10/30/2003 09:06:00, 4800512 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.4501 (English), 10/30/2003 09:06:00, 49152 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/30/2003 09:06:00, 52951 bytes
Driver: C:\WINDOWS\System32\nvrsda.dll, 6.14.0010.4501 (Danish), 10/30/2003 09:06:00, 266240 bytes
Driver: C:\WINDOWS\System32\nvwrsda.dll, 6.14.0010.4501 (Danish), 10/30/2003 09:06:02, 159744 bytes
Driver: C:\WINDOWS\System32\nvrsde.dll, 6.14.0010.4501 (German), 10/30/2003 09:06:00, 274432 bytes
Driver: C:\WINDOWS\System32\nvwrsde.dll, 6.14.0010.4501 (German), 10/30/2003 09:06:02, 176128 bytes
Driver: C:\WINDOWS\System32\nvrses.dll, 6.14.0010.4501 (Spanish), 10/30/2003 09:06:00, 274432 bytes
Driver: C:\WINDOWS\System32\nvwrses.dll, 6.14.0010.4501 (Spanish), 10/30/2003 09:06:02, 17612
sorry, ik heb/had het 2x gestuurd.. :)
[ Voor 100% gewijzigd door Verwijderd op 19-09-2004 16:09 ]
  • Crash
  • Laatst online: 22:43
Naast dat je topic in het verkeerde subforum staat, direcxt is namelijk software en niet een spel ;) voldoet je topicstart niet aan de eisen. Zie de faqs van de betreffende subfora om te lezen waaraan een topic moet voldoen. Daarnaast is het handig als je de error letterlijk overneemt ipv hier neer zet in gebrekkig Engels, het is namelijk "a cabinet file necessary for installation cannot be trusted". Als je hier op zoekt met google kom je er bij uit dat er waarschijnlijk een bestandje corrupt is. Dit kan gebeurd zijn tijdens het downloaden, of het kan zijn dat de cd beschadigd is. Download het bestand dus opnieuw of neem een andere cd met directx er op :)
Verder heeft het geen nut om een ellenlange post met behulp van knip en plak werk hier neer te dumpen zonder te kijken of het wel nuttig is om te vermelden. Je kunt dan beter alleen de code/tekst hier neer zetten waarvan jij weet dat die er toe doet, dat scheelt weer onnodig leeswerk :P
Dit topic gaat dicht omdat je zelf niet voldoende gezocht hebt, en met bovenstaande suggestie zou je het probleem moeten kunnen verhelpen. Kom je na mijn tips er nog steeds niet uit en blijft het probleem zich voor doen, dan kan je alsnog een topic in het juiste subforum openen met een goede topicstart :)
[ Voor 15% gewijzigd door Crash op 19-09-2004 18:07 ]
