iosdt.exe en andere worms/trojans verwijderen
Sinds nieuwe install loopt de pc constant vast,
volgens mij is één van de daders het proces iosdt.exe , als ik dit proces beeindig dan is het weer goed, maar bij nieuwe opstart weer terug.
Maar volgens mij zit er nog meer rommel tussen?
Logfile of HijackThis v1.97.7
Scan saved at 10:54:21, on 19-9-2004
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\WINDOWS\system32\iosdt\iosdt.exe
C:\Program Files\Norton SystemWorks\Norton Antivirus\navapsvc.exe
C:\PROGRA~1\NORTON~1\NORTON~2\NPROTECT.EXE
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Norton SystemWorks\Norton Antivirus\SAVScan.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\PROGRA~1\NORTON~1\NORTON~2\SPEEDD~1\NOPDB.EXE
C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\WINDOWS\system32\taskmgr.exe
C:\Program Files\Microsoft ActiveSync\WCESCOMM.EXE
C:\Program Files\totalcmd\TOTALCMD.EXE
C:\WINDOWS\system32\wuauclt.exe
F:\INTERNET Apps\HijackThis.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\WINDOWS\system32\devldr32.exe
C:\Program Files\Messenger\msmsgs.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.tweakers.net/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koppelingen
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: Web assistant - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton SystemWorks\Norton Antivirus\NavShExt.dll
O2 - BHO: TGTSoft Explorer Toolbar Changer - {C333CF63-767F-4831-94AC-E683D962C63C} - C:\Program Files\TGTSoft\StyleXP\TGT_BHO.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton SystemWorks\Norton Antivirus\NavShExt.dll
O3 - Toolbar: Web assistant - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [AnyDVD] C:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
O4 - HKLM\..\Run: [PinnacleDriverCheck] C:\WINDOWS\system32\PSDrvCheck.exe -CheckReg
O4 - HKCU\..\Run: [STYLEXP] C:\Program Files\TGTSoft\StyleXP\StyleXP.exe -Hide
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\WCESCOMM.EXE"
O4 - HKCU\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe
O8 - Extra context menu item: &Google Search - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Gelijkwaardige pagina's - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Koppelingspagina's - res://C:\Program Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Opgeslagen momentopname van de pagina - res://C:\Program Files\Google\GoogleToolbar1.dll/cmcache.html
O9 - Extra button: Toevoegen aan Mobiele favorieten (HKLM)
O9 - Extra 'Tools' menuitem: Toevoegen aan Mobiele favorieten... (HKLM)
O9 - Extra button: Onderzoek (HKLM)
O9 - Extra button: Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Windows Messenger (HKLM)
O16 - DPF: {003FADA5-8FEE-11D6-AFB7-0004768F6183} (CryptoRSA Control) - https://www.p3.postbank.nl/sesam/CAX.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.m...eb_site.cab?1094760108203
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload.macrome...ve/cabs/flash/swflash.cab
Iosdt zou je zo moeten verwijderen:
Removing iosdt.exe:
This is a very sneaky infection. In order to find & remove the exe you need to:
1. Open Control Panel > Folder Options
2. Click the View tab.
3. Under Hidden Files & Folders click "Show Hidden Files and Folders"
4. Next uncheck "Hide protected operating system files"
5. Reboot in Safe Mode (in XP press F8 before windows begins loading)
6. Open C:\WINDOWS\system32
7. Delete the Folders & files with iosdt in the name (there should be 1 folder, iosdt, containing all the corrupt files) you may want to do a search for iosdt to make sure everything is removed.
8. Empty the Recycle Bin.
9. Reboot in Normal Mode.
Edit: deze ook ff fixxen:
Probeer eens Ad-aware od spybot the draaien, is in jouw geval waarschijnlijk handiger
[ Voor 12% gewijzigd door Verwijderd op 19-09-2004 11:09 ]
