Soundstorm niet in Nforce 4
  • jona
  • Laatst online: 06-10 10:08
Afbeeldingslocatie: http://home.zonnet.nl/jos.aben/soundstorm.jpg
Op Tweaktown is een review verschenen van verschillende geluidskaarten en onboard-oplossingen. Naast een erg positieve review van de Nforce Soundstorm werd ook het volgende gezegd.
When nVidia released the mighty onboard SoundStorm APU (Audio Processing Unit) back with their nForce chipset for the Athlon XP platform, gamers and general PC enthusiasts around the world were thrilled and thought they were in for a change for the years ahead as far as cinematic quality computer audio goes. It seems like they were wrong though as nVidia basically confirmed at QuakeCon that the hardware powered SoundStorm APU which is the only sound solution capable of encoding Dolby Digital (or AC-3) on the fly would not be part of the upcoming nForce4 chipset. When nVidia let this news out to gamers in the crowd, it was clear that the group was thoroughly disappointed.
Not only was the nVidia SoundStorm APU the only sound solution capable of encoding Dolby Digital on the fly (which produces true and accurate 5.1 surround sound via either optical or digital coaxial cable to a set of computer speakers supporting these connections or to an external amplifier), it was also hardware accelerated meaning it does not chew up precise CPU cycles like other inferior onboard solutions which in turn reduces frames per second and do not have the ability to send separate digital signals to anymore than two channels. You’ll get 5.1 sound using three analog cables but this type of setup is nowhere near as impressive or realistic as what the SoundStorm produces.
De volgende generatie Nforce zal dus teleurstellend genoeg geen Soundstorm meer hebben! Ik heb het snel gecontroleerd en The Tech Report bevestigde deze uitspraak.
De reden die op Tweaktown wordt aangehaald is het volgende:
Why is this happening? The answer seems clear to us. Consumer demand – No company is going to produce something which is more expensive to mass manufacturer unless there is consumer demand for it, especially with the Chinese culture - which is only fair enough. And why is there no consumer demand? There is nowhere near enough mainstream coverage as to the benefits of impressive sound solutions such as nVidia SoundStorm. Most consumers seem happy with their “5.1 sound” but they are not experiencing the ultimate sound performance possible as demonstrated by SoundStorm. It’s going to be up to websites such as TweakTown, magazines around the world and consumers to make the change – there will need to be a clear and obvious push for better standards in computer audio for anything to happen.
If there is no push, the vast majority of companies will continue to produce the cheapest audio solutions they can to maximize profits but once the consumer awareness of the type of high quality sound solutions available increases, computer users will not mind spending some extra dollars on their new motherboard knowing full well they can expect to experience proper and true digital surround sound. All Microsoft Xbox games have full Dolby Digital support with the “Xbox Advanced AV Pack” since it uses the SoundStorm for processing so why shouldn’t we just expect the same standards for computer gaming?
Er schijnt dus niet genoeg vraag te zijn van de mainstreammarkt en daarom heeft Nvidia besloten om Soundstorm 'dood' te laten gaan.
Wat denken anderen hier over? En is de kans aanwezig dat bv een bedrijf als Creative in het gat zal springen dat hier ontstaat. Ik had zelf namelijk de Nforce 3 overgeslagen om de simpele reden dat er geen Soundstorm op zat.
  • itsgreen
  • Laatst online: 02-12-2025
itsgreen
Large and in charge
Vaag :S
Terwijl er onlangs nog een bericht op de Frontpage stond dat er zelfs een opvolger van Soundstorm geintegreerd zou zijn, Soundstorm 2.0...
  • itsme
Ik heb een ASUS A7N8X deluxe Rev 2.0 met het geroemde soundstorm, in het begin heb ik dit ook gebruikt, echter steeds met een zeer vervelend gekraak als ik scrollde met mijn muis. Als ik een SB Live gebruik heb ik dit niet. Soundstorm is bij mij dus uitgeschakeld en in mijn ogen voldoet het totaal niet aan de verwachtingen.
Ik heb dus niet het idee dat het iets is dat ik zal missen.
"If God wanted us to have unlimited free energy He would have put a giant fusion reactor in the sky"
Dood zonde dat ie eruit gaat .. kheb zelf de abit NF7-s met de soundstorm echt perfect geluíd eigelijk geen externe geluidskaart nodig. wat ik bij m'n vorige mobo wel moest met een AC'97 geluidzoo.. kaart
Tijd voor een Soundstrom Addon PCI(express) kaart?
  • jona
itsgreen schreef op 08 september 2004 @ 10:57:
Vaag :S
Klopt, deze nieuwsposting.
Maar het kwam van The Inquirer, dus hoe betrouwbaar dat nu was. Of ze hebben op een later moment besloten om Soundstorm te laten vallen en misschien de prijs lager te houden.
Ik vond Soundstorm echt fantastisch, vooral de Dolby Digital ICE encoder. Een kabeltje naar je versterker en je had vijf kanaals geluid. En niet alleen voor spellen. En de kwaliteit was erg goed, vooral vergeleken met andere onboard oplossingen.
Zou Nvidia wachten tot de tijd beter geschikt is of zal een ander bedrijf eerder het idee over nemen?
[ Voor 5% gewijzigd door jona op 08-09-2004 11:43 ]
