[Ervaringen] Laptop acer 400x(w)lmi
  • nick_vh
  • Laatst online: 11-04-2025
Ik sta op het punt deze te kopen hieronder de specifikaties:
TravelMate 4000 Acer recommends Microsoft® Windows® XP Professional
Technical specifications
Operating System Microsoft® Windows® XP Home Edition
Processor & Chipset Mobile Intel® Centrino™ Technology
Intel® Pentium® M processor with 1MB L2 Cache and supporting Enhanced Intel® SpeedStep® Technology
Intel® 855GME chipset with 400MHz FSB
Wireless: Integrated Intel® PRO/Wireless 2200 BG network connection
Memory DDR333 memory, upgradeable to 1GB*using dual soDIMM modules
HDD ATA/100 hard disc drive
Storage Integrated Dual DVD-RW drive
15.4" WXGA TFT LCD with 1280 × 800 pixel resolution; 16:10 viewing ratio
16.7 million colours
Support S-video (NTSC/PAL) TV-out
Graphics ATI MOBILITY™ RADEON™ 9700, with 64 MB of external DDR VRAM featuring ATI POWERPLAY™ support
Simultaneous LCD and CRT display
DualView™ support
MPEG-2/DVD hardware assisted capability
Microsoft® DirectX® 9.0 support
Multimedia Audio system with two built-in speakers
MS-Sound compatible
Communication 10/100Mbps Fast Ethernet; Wake-on-LAN ready
56K ITU V.92 modem with PTT approval; Wake-on-Ring ready
Integrated Intel® PRO/Wireless 2200BG network connection 802.11b/g dual band Wi-Fi CERTIFIED™ solution
I/O Interfaces 3x USB 2.0
1x Infrared (FIR)
1x VGA for external monitor
1x 32bit type II PCMCIA CardBus slot
1x S-video out (NTSC/PAL)
1x IEEE 1394 port
1x RJ-11 jack
1x RJ-45 jack
1x speaker/ headphone/ line-out jack
1x microphone/ line-in jack
1x DC-in jack for AC adapter
Security Slot for Kensington lock
BIOS user and supervisor passwords
Power supply and battery ACPI power management supporting Standby and Hibernation modes
60 W Li-ion battery pack (depending on model)
5-hour battery life (actual battery life might vary, depending on usage and configuration);
1.5-hour rapid charge
3.5-hour charge-in-use
65 W AC adaptor
Keyboard & Special Controls 88-/89-key keyboard; Acer FineTouch™ keyboard with a 5-degree curve; inverted "T" cursor layout; 2.5 mm (minimum) key travel
Touchpad with buttons and 4-way integrated scroll keys
12 function keys; four cursor keys; two Windows® keys; hotkey controls; embedded numeric keypad; international language support
Four easy-launch buttons: Internet browser, email with LED, Acer Empowering Key, and one user-programmable button
Weight and dimensions 364 (W) x 279 (D) x 34(H) mm
2.91 kg for 15.0” LCD model;
2.95 kg for 15.4" WXGA LCD model
Quality & Reliability Tests Temperature & humidity test
Free drop test
Acoustics test
Weight pressure tests
Shock and vibration test
Electrostatic discharge test
MTBF (Mean Time Between Failure) test Hinge life test
Hinge life test
Keyboard-switch life test
Software Norton AntiVirus™ (60 days trial)
Adobe Acrobat® Reader™
Cyberlink PowerDVD®
NTI® CD Maker™ (for models featuring DVD/CD-RW combo or DVD-RW drive module)
Acer Launch Manager
Acer eManager
Acer System Recovery CD
Acer disc-to-disc recovery (This feature uses 2 GB of hard disc space)
Options Memory expansion modules
Additional battery
Additional AC adapter
Certifications DMI 2.0
ACPI
Mobile PC2001
CCX
Wi-Fi®
Warranty 1 year send-in with International Travellers Warranty
http://www.acer.be/acereu...tity3/1/TM4000_normal.jpg
________________________________________________
heeft iemand hier ervaringen mee?
  • Han
Han
Is het een Acer 400x(w)lmi of een Acer travelmate 4000?
Over een Acer 400x(w)lmi kan ik niks vinden, enkel over een Acer 4001 Lmi.
  • nick_vh
Ik denk dat er ook een 4003wlmi bestaat dus heb ik er een x bijgezet, maar misschien best als dit vervangen wordt door een *tje?
sorry voor de verwarring
