Asus V7100 op AGP 4X en Tweak enabelen?
  • worsie
  • Laatst online: 22-02-2025
Ik heb hier net al een email over naar Asus gestuur, maar ga het hier ook maar nog ff proberen. Hoop dat niemand bezwaar heeft tegen engels, maar anders moet ik het twee keer gaan tikken. De Mail:
Dear Mr., Mrs.,
I have been trying to find a way to improve the performance of my videocard. I know from experience that the card performs exellent and runs very stable under the Asus V6.18 drivers. I can easily overklock the card to 210mhz core / 210 mhz memory. When tested with 3DMark2000 this gives a score of 5289 (default benchmark). The problem was however that I could find no confirmation that the card was running at 4XAGP. I've tried several diagnostics programs, but non were able to answer this.
I then installed the Asus V6.31b5 beta drivers. This gave a significant performance boost. The information utility on the display adapter->advanced->information indicates that the card is now running at 4XAGP. When running 3DMark2000 again, the score was up to 5585. However, I was not able to use the tweak utility. The Coolbits reg did not function properly as the dll NvQTwk.dll (or something like that) could not be found. When adding this file (I copied it from the Asus 6.18 driver) the error was gone, but no tweaking possibility visible.
I suspect that the card runs at 1XAGP with the 6.18 drivers and can be overclocked, and with the 6.31b5 drivers runs at AGP4X and cannot be overclocked.
I am now looking for a solution to either:
- run with the 6.18 drivers and find a way to enable 4XAGP
- run with the 6.31b5 drivers and find a way to enable the tweak utility.
Do you have a solution to do this, or is there an nVidia reference driver that will allow me to run both functionalities?
(possibly the nVidia 7.17 and DirextX8 final combination?)
Further system information:
motherboard: Abit KT7-RAID (Via 4in1 driver 4.25(1) and AGP404)
processor: AMD Athlon 1000 mhz (running at 1050 (10X105) at the time of testing)
memory: 384MB memory (3X128MB SDRAM PC133 memory) running at CAS3, FSB+PCI clock(138 mhz)
soundcard: Soundblaster Live! 5.1 (OEM)
Harddisk: IBM DTLA 30.6GB, 7200rpm, ATA100
NIC: 32Bit fast ethernet adapter.
PSU: 300W Aopen PSU ("Athlon approved")
Voltages: +12=12.01V, +5=5.1V, +3.3=3.4V, measured with Motherboard Monitor V.5.03
temperatures: CPU: 35°C after running 3DMark2000, Case: 23°C.
OS: Windows 98SE
Thank you very much for your help in this matter.
Dezelfde vraag dus aan mijn medetweakers :)
He, heb je al een tweakproggie als getune geprobeerd, daar zit alles is wat jij zoek op tweakgebied.
- AGP 4x for VIA chipset
- Tweak display properties
En nog meer tweak mogelijkheden
Porggie kan je downloaden vanaf www.tweakfiles.com
Misschien heb je dit al geprobeerd en zo niet probeer het ff, waarschijnlijk werkt het wel!!!!!
  • worsie
OK, thx, ik zal er es mee gaan spelen :)
Heb ondertussen al tig van die proggies geprobeerd, maar deze nog niet, dus who knows :)
  • worsie
Hmmm. Werkt nog steeds niet denderend. Met de Asus 6.31b5 drivers in combinatie met DirektX8 final haal ik de hoogste score (5643 op default). Maar ik krijg het nog steeds niet voor elkaar om te zien of ie nou wel of niet overgeklokt is :(.
Wordt hier eerlijk gezegd gestoord van. En ik weet zeker dat het beter kan. Heb al eens 5669 gehaald.
Nog meer suggesties?
