• eswa
  • Laatst online: 01-06 22:29
Et voila, een topic met de goeie naam. Die andere mag dicht dan.
Goed.
Dit is dus de T-Dap/Wewa HD200 (20GB) mp3 speler.
Watch the new TARGET digital audio player. With a built-in 20GB hard disk, youll be able to store literally thousands of music tracks and carry your audio library with you wherever you go! Measuring only 100mm x 62mm, and only 22mm thick, its so small you can carry it in your pocket!
It plays MP3 and WMA formats, and also features a built-in FM radio.
Specifications
Memory: Capacity 20GB
Memory Type: 1.8" hard drive
Battery: 1350 MAH/3.7V rechargeable lithium battery
LCD: 128 x 128 4 grayscale display with blue backlight
Dimensions: 100mm(H) x 62mm(W) x 22mm(D)
Weight: 167g
USB Port: USB 2.0 high speed transfer (20 Mbyte/s)
USB Host: USB 1.1 port (USB 2.0 device compatible)
FM: Channel Range 87.5MHz ~ 108.0MHz, 20 presets
Charge Time: Battery charge time: 3 hours (achieve 80% battery after 1-hour fast charge)
Playback Time: 14 hours (Standard MP3 Playback)
SN rate: 90dB
Earphone output power: 5MW+5MW
Output frequency range: 20Hz ~ 20KHz
Record bit rate: 32Kbps ~ 320Kbps
Music file format: MP3, WMA
Record file format: VOC, MP3
Support ID3 language of the music file: Simplified Chinese, traditional Chinese, Korean; Japanese, English
Support compression rate: 8Kbps-320Kbps (MP3)/VBR - 8Kbps-192Kbps(WMA)/VBR
OS Support: Microsoft Windows 98/ME/2000/XP - Mac OS 9.X, 10.X
All specifications above are subject to change without prior notice.
Afbeeldingslocatie: http://www.target-int.nl/photo/65750.jpgAfbeeldingslocatie: http://www.target-int.nl/photo/65750c.jpg
Afbeeldingslocatie: http://www.target-int.nl/photo/65750a.jpg
Afbeeldingslocatie: http://www.target-int.nl/photo/65750b.jpg
Heeft iemand meer van deze speler gehoord, of hem zelfs al gekocht van dat bedrijf op marktplaats? PRIJS: €280
(http://www.marktplaats.nl...5.htm?av=a&fo=1&zoek=20gb)
Vind hem wel ergg lelijk, vind je niet :)
  • eswa
K vind em wel grappig, en best goedkoop...
  • PnD
  • Laatst online: 03-11 11:24
PnD
like in Pinda ^_^
Vind em wel aardig uitzien :) Ook een 1,8inch schijf dus lekker compact..
Zal is opzoek gaan naar user foto's enzo en reviews
edit: niet kunnen vinden
[ Voor 13% gewijzigd door PnD op 27-08-2004 16:51 ]
  • eswa
Ze hebben hem ook in gewone NL. webshops (die niet op marktplaats aanbieden)
http://www.electix.nl/pro...a26e72f896d524466d7adcb6b
http://www.lhs-shop.nl/in...rget=dept_32.html&lang=nl
(op beide sites trouwens 299 euri)
Hij is er blijkbaar ook in het zwart
http://global.yesasia.com...ction-electronics/did-10/
http://publish.it168.com/2004/0809/20040809003201.shtml
chinese review ofzo
Maar ik hou het toch gewoon bij de spelers van de bekende merken...
[ Voor 48% gewijzigd door eswa op 02-09-2004 21:44 ]
