[PHP][MYSQL] Resource id #18
  • 112 views sinds 30-01-2008
  • GewoonNico
  • Laatst online: 19-10 15:23
Ik probeer via een form een plaatje in een database te mikken...
script:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
function img_to_db($image,$tablename,$maxthumbwidth,$maxthumbheight,$maxoriginalwidth,$maxoriginalheight)
    // Thumb Maken
    $maxX = $maxthumbwidth;
    $maxY = $maxthumbheight;
    $imgsize = getimagesize($image);
    switch($imgsize[2])
        case 1:
            $timg = imageCreateFromGIF($image);
            $type = "gif";
            break;
        case 2:
            $timg = imageCreateFromJPEG($image);
            $type = "jpg";
            break;
        case 3:
            $timg = imageCreateFromPNG($image);
            $type = "png";
            break;
    $type = "jpg";
    $imgX = $imgsize[0];
    $imgY = $imgsize[1];
    $_X = $imgX/$maxX * 100;
    $_Y = $imgY/$maxY * 100;
    if((100-$_X) < (100-$_Y))
        $_K = $_X;
    else
        $_K = $_Y;
    $newX = floor($imgX/$_K * 100);
    $newY = floor($imgY/$_K * 100);
    $imgh = imageCreateTrueColor($newX, $newY);
    imagecopyresized($imgh, $timg, 0,0,0,0,$newX,$newY,$imgX,$imgY);
    //$db_thumb = ImageJPEG($imgh,"",100);
    //$fullfile = fread(fopen($db_thumb,"r"),filesize($db_thumb));
    //$coded = chunk_split(base64_encode($db_thumb));
    $coded = addslashes($imgh);
    mysql_query("INSERT INTO ".$tablename." (img_small) VALUES('".$coded."')");
Uitleesscript:
PHP:
define("INCMS", "TRUE");
// Extra beveiliging
require("../includes/settings.php");
header("Content-type: image/jpeg");
if ($_GET['s'] == "t")  { $size = "img_small"; }
else                    { $size = "img_large"; }
$imageq = mysql_query("SELECT * FROM ".$_GET['t']." WHERE id='".$_GET['id']."'");
$row = mysql_fetch_array($imageq);
$image = $row["".$size.""];
echo("".$image."");
Uitkomst als ik het plaatje wil bekijken:
Resource id #18
in de database staat wel [BLOB - 15 Bytes]
Dus naar mijn mening staat er toch iets in...
Wie kan me helpen....
  • T-Blizzard
  • Laatst online: 16:43
//Binaire data van een thumb inlezen
function getBinaryDataT()
ob_start();
imagejpeg($this->tempthumb);
$this->binarydataT = ob_get_contents();
ob_end_clean();
Ik deed het in mijn classe altijd zo met behulp van output buffering.
  • GewoonNico
Thanx
Voor diegene die t ook eens willen proberen: Dit is mijn uiteindelijke script geworden
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
function getbinarydata($img)
    ob_start();
    imagejpeg($img,"",100);
    $db_img = ob_get_contents();
    return $db_img;
    ob_end_clean();
    // Thumb Maken
    switch($imgsize[2])
        case 1:
            $type = "gif";
            break;
        case 2:
            $type = "jpg";
            break;
        case 3:
            $type = "png";
            break;
    $type = "jpg";
        $_K = $_X;
    else
        $_K = $_Y;
    $coded = addslashes(getbinarydata($imgh));
[ Voor 6% gewijzigd door GewoonNico op 26-08-2004 18:11 ]
  • 4Real
  • Laatst online: 14-09-2024
Kleine verandering:
PHP:
echo("".$image."");
Naar:
PHP:
$image = $row[$size];
echo($image);
$row["".$size.""]; "".$size."" is overbodig kan ook zonder die "". .""
