[XP] Issass.exe foutmelding*
hallo allemaal,
Na het installeren van een pc'tje met windows xp prof. sp1
kreeg ik na het installeren van het internet de vreemde melding
lsass.exe status code -1073741819
En net zoals het blaster virus sloot de pc af na 1min.
Maar na scannen blijkt het het blaster virus niet te zijn :?
symantec corp. herkent het ook niet na nieuwste updates.
Ik heb gezocht op het forum maar ook nix.
Wat kan dit zijn?
  • Jassy
  • Laatst online: 03-11 16:39
mijn vriendje google zegt dit:
SYMPTOMS
After you install an Internet-based file sharing program, such as BearShare, you may receive the following error message:
The system process LSASS.EXE terminated unexpectedly with status code -1073741571. The system will now shut down and restart.
If you restart the computer in Safe mode, you may receive one or more error messages similar to the following:
Svchost.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log will be created.
CAUSE
This behavior may occur if you install the Internet-based file sharing program on a computer on which the Microsoft Winsock Proxy Client is installed. This behavior may be caused by a corrupted Winsock2 registry key.
RESOLUTION
To resolve this issue, remove the Winsock2 registry key, and then restart the computer. To do this, follow these steps.
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. In Registry Editor, navigate to the following subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Winsock2
4. Right-click Winsock2, and then click Delete on the shortcut menu that appears.
5. Click Yes to confirm the deletion of the key.
6. Repeat steps 3 through 5 to remove the following registry subkeys (if present):
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Winsock2
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Winsock2
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Winsock2
7. Quit Registry Editor.
8. Restart Windows normally.
kun je hier wat mee?
Bekijk op www.dabmonitor.nl informatie over diverse Nederlandse DAB Ensembles.
google?
kan je genoeg vinden denk ik.
Ik ga het proberen maar toch denk ik niet dat dit het is,
want ik heb geen enkel share programma'tje geinstalleerd
  • elevator
elevator
Officieel moto fan :)
-FACEMAN-,
Als je zoekt op 'lsass.exe' in de search ([search=lsass.exe] dus) - dan vindt je een boel resultaten. [google=sasser] ga je ook een heleboel vinden - ik geloof dan eigenlijk ook helemaal niet dat je gezocht hebt als ik eerlijk ben. Vertel mij eens waar je op gezocht hebt (en neem dat uberhaupt in elk topic op) :)
Verder pas ik eventjes je topic titel aan zodat het besturingssysteem er in staat - probeer daar voortaan zelf aub ook op te letten :)
  • K-Jay
  • Laatst online: 03-11 23:08
K-Jay
Klaas Jan
Zoeken op Microsoft.com levert: What You Should Know About the Sasser Worm.
Zo moeilijk is het niet.
Beter remmen=sneller racen: loadcellmod
  • morpheus
  • Laatst online: 01-11 16:42
Ik heb er sinds kort plotseling ook last van. Gek, want de bedrijfslaptop is normaal gesproken altijd up to date met beveiligingen (automatisch) en een up to date virusscanner (die niets vind).
Maar ondertussen met netstat is ie wel het hele subnet aan het afgaan :{
De betrokken kenmerken zijn ook niet te vinden.
3kwp pvoutput
