[XP 64BITS] Zo installeer je Doom3
  • 56 views sinds 30-01-2008
  • mmxmmx
  • Laatst online: 23-09 01:35
Ik weet niet of het al bekend was maar ja dan nog maar een keer :) This tenslotte erg belangrijk :)
To do a manual install, do the following:
1) Create a destination folder (for example, c:\program files\doom 3)
2) Insert CD 1.
3) Copy Doom3.exe from CD 1 (Setup\Data\Doom3.exe) to your destination folder.
4) Create a "base" directory in your destination folder (for example, c:\program files\doom 3\base).
5) Copy pak002.pk4 from CD 1 (Setup\Data\base\pak002.pk4) to the "base" folder.
6) Copy game00.pk4 from CD 1 (Setup\Data\base\game00.pk4) to the "base" folder.
7) Insert CD 2.
8] Copy pak000.pk4 from CD 2 (Setup\Data\base\pak000.pk4) to the "base" folder.
9) Copy pak001.pk4 from CD 2 (Setup\Data\base\pak001.pk4) to the "base" folder.
10) Insert CD 3.
11) Copy pak003.pk4 from CD 3 (Setup\Data\base\pak003.pk4) to the "base" folder.
12) Copy pak004.pk4 from CD 3 (Setup\Data\base\pak004.pk4) to the "base" folder.
13) Go to the base folder and create a text file called "doomkey". NOTE: This file should not have any file extension.
14) Open the doomkey file in notepad.
15) Enter your CD Key exactly as it appears on the CD Key sticker. Use all capital letters and do not include any dashes.
16) Save that file.
17) Doom 3 should now be installed on your computer.
The final layout on the CD drive should look like this:
[destination folder]\Doom3.exe
[destination folder]\base\doomkey
[destination folder]\base\game00.pk4
[destination folder]\base\pak000.pk4
[destination folder]\base\pak001.pk4
[destination folder]\base\pak002.pk4
[destination folder]\base\pak003.pk4
[destination folder]\base\pak004.pk4
Als je dit hebt gedaan blijft er nog 1 probleempje over het werkt niet omdat de exe op de 1 of andere manier niet je orginele Doom 1 cd kan vinden .
Maar niet getreurd je moet de fixed exe ff zoeken en die over de orginele heen gooien en dan werkt het als een trein .
Ik zal later nog ff proberen of het multiplayer gedeelte ook nog werkt maar ik moet nu eerst XP 64 er opnieuw op gooien omdat NortonSystemworks bla bla bla .
Ik denk wel dat het werkt omdat je tenslotte je legale cd key gebruikt .
Nog ff voor de duidelijkheid ik heb dus de orginele Doom 3 voor 60 € gekocht :)
[ Voor 3% gewijzigd door mmxmmx op 20-08-2004 17:43 ]
Asus RTX 5090 OC - AMD 9-9950 X3D en DDR5 G-Skill 64GB Ram
  • Crash
  • Laatst online: 22:43
Das leuk en aardig, maar geen vraag of probleem :)
Hier zou je het eventueel kunnen melden: [rml][ PC] Doom3 Deel 7[/rml]
