[LIRC] dev/lirc/serial bestaat niet
  • Belial_666
  • Laatst online: 14-08 13:04
ben al dagen bezig maar weet niet waar ik zoeken moet
LIRC wie kan mij helpen dit aan de praat te krijgen ?
dit heb ik gedaan
lirc geinstaleerd
lircd draait met geen errors
DEZE TUTORIAL: http://www.mandrake.tips.4.free.fr/lirc.html
I did:
vi /etc/sysconfig/lircd
and made it look as follows: (I left out all the lines that are commented out with a hash)
# Customized settings for lirc daemon
# The hardware driver to use, run lircd --driver=? for a list
DRIVER=default
# Hardware driver module to load
HWMOD=lirc_serial
DEVICE=/dev/lirc/serial
# Serial port for the receiver (for serial driver)
COM_PORT=/dev/ttyS0
DRIVER_OPTS="irq=4 io=0x3f8"
I knew that I was connecting the serial connector to the first port, which is /dev/ttyS0. (This was logical as there were 4 COM ports indicated in the file.) I didn't change anything of the DRIVER_OPTS since I had no clue what else to put, and actually I figured that they would put reasonable defaults. Which I found to be true.
Then I did, as root (as most commands here):
service lircd start
(You can also do:
/etc/rc.d/init.d/lircd start)
to which the system responded with:
Starting Linux Infrared Remote Control daemon: [ OK ]
Next I entered the following commands:
chkconfig --level 35 lircd on
depmod -a
modprobe lirc_serial
Note: the depmod took quite a bit of time. (Also note: instead of the chkconfig-command, I could have done: Mandrake Control Center, System, Services, and selected 'start on boot' for lircd.)
Dit zie ik dus niet en ik weet niet hoe ik verder moet
[root@paris root]# ll /dev/lirc/serial
showed me the device node:
crw-rw-rw- 1 root root 61, 0 Jan 1 1970 /dev/lirc/serial
so all seemed well from the device side.
die dev/lirc/serial bestaat niet !!
hoe nu verder ???
[ Voor 4% gewijzigd door Belial_666 op 17-08-2004 14:53 ]
  • V-2
  • Laatst online: 03-09-2025
V-2
Als je geen udev of devfs gebruikt, man mknod en zelf de device inode aanmaken. Voor udev ligt het wat moeilijker, je kan proberen om op dezelfde manier die inode aan te maken, maar je hebt kans dat ie na reboot weg is, dat ligt aan je distributie. Voor devfs geldt dat er blijkbaar wat mis is in je drivers waardoor die inode niet wordt aangemaakt ... lirc ken ik verder niet zo, dus veel verder kan ik je niet helpen...
  • Gotiniens
  • Laatst online: 21-08 23:19
Gotiniens
Fairly odd Tim
heb je wel modules in je kernel voor infrarood modules?
p.s. stop de gedeelte wat je van die site heb ff tussen [quote] tags
  • _Squatt_
Hoe weet je dat lircd draait?
Gaat het modprobe'n van de module goed? Staat lirc_serial in de lijst die lsmod terug geeft?
Je kunt de device node altijd zelf aanmaken met:
mknod c 61 0 /dev/lirc/serial
oeps, dit tabje wat lang open laten staan voor ik op reply klikte ;).
[ Voor 19% gewijzigd door _Squatt_ op 17-08-2004 14:43 ]
"He took a duck in the face at two hundred and fifty knots."
  • Belial_666
OK bedankt voor de snelle reactie.
ik gebruik Mandrake 10.
Ik weet niet of ik udev of devfs gebruik
waarschijnlijk devfs
/etc/modules is leeg
/etc/modules.conf
probeall usb-interface usb-uhci
alias eth0 8139too
alias sound-slot-0 es1371
above snd-ens1371 snd-pcm-oss
Gotiniens
Fairly odd Tim
Door Gotiniens - Tuesday 17 August 2004 14:35
ik gebruik niet de IR module maar de serial
  • Belial_666
lsmod:
Module Size Used by
lirc_serial 12544 0
lirc_dev 13440 2 lirc_serial
vfat 13760 0
fat 45120 1 vfat
ppp_synctty 8832 0
sg 38044 0
st 38616 0
sr_mod 17028 0
sd_mod 16832 0
scsi_mod 114648 4 sg,st,sr_mod,sd_mod
ide-cd 40548 0
cdrom 37184 2 sr_mod,ide-cd
nls_cp437 5568 18
nls_iso8859-1 3904 18
smbfs 62872 19
es1371 33280 1
soundcore 9248 2 es1371
gameport 4480 1 es1371
ac97_codec 17804 1 es1371
ppp_async 11744 1
ppp_generic 29552 6 ppp_synctty,ppp_async
slhc 7200 1 ppp_generic
af_packet 20520 6
hid 53312 0
floppy 59444 0
8139too 23712 0
mii 4992 1 8139too
md5 3872 1
ipv6 232352 12
supermount 37876 2
intel-agp 17372 1
agpgart 31016 2 intel-agp
nvidia 2073216 12
uhci-hcd 29104 0
usbcore 99132 4 hid,uhci-hcd
rtc 11576 0
ext3 111048 1
jbd 54680 1 ext3
[root@gizmo root]# mknod c 61 0 /dev/lirc/serial
mknod: invalid device type `61'
Try `mknod --help' for more information.
  • _Squatt_
Death schreef op 17 augustus 2004 @ 14:48:
Sorry, tijdje geleden dat ik mknod heb gebruikt:
mknod /dev/lirc/serial c 61 0
  • Belial_666
ok dat is gelukt.
nu een hele domme vraag. hoe weet ik nu of ie het doet :P
al ik
mode2 -d /dev/lirc/serial
doe dan gebeurd er nix.
volgens de handleiding zou ik allerlei dingen moeten zien als ik knoppen indruk
[ Voor 27% gewijzigd door Belial_666 op 17-08-2004 15:53 ]
