[Exchange2003] Exmerge error tijdens import .pst file
  • 115 views sinds 30-01-2008
Ik heb zojuist de exchange 2003 server aan de gang gekregen en wil hier nu graag een .pst file (afkomstig uit outlook 2003) importeren middels ExMerge.
Het .pst file is ongeveer 350mb groot en krijg het niet voor elkaar deze te importeren.
In het ExMerge.log komt telkens het volgende te staan:
29
30
31
32
33
34
Microsoft Exchange Mailbox Merge Program, v6.5.7226.0
Start Logging:August 13, 2004   12:17:46
[12:17:46] Logging Level: None
[12:17:46] Reading settings from file 'C:\Program Files\Exchsrvr\bin\EXMERGE.INI'.
[12:17:46] Reading list of subjects for messages to be selected from file ''
[12:17:46] Reading list of attachment names for messages to be selected from file ''
[12:17:46] List of folders to be ignored has been read. 0 folders in the list.
[12:17:46] Current machine locale ID is 0x409
[12:17:46] Operating System Version 5.2 (Build 3790)
[12:17:55] Accessing Domain Controller 'servername'
[12:17:55] 'servername' is running Exchange Server 2000 or later
[12:17:56] Mailbox '/o=name/ou=First Administrative Group/cn=Configuration/cn=Servers/cn=servername/cn=Microsoft System Attendant' will be ignored as its DN contains strings in the ignore list
[12:17:56] Mailbox '/o=name/ou=First Administrative Group/cn=Configuration/cn=Connections/cn=SMTP (servername)/cn={9EE03098-A30B-494E-943D-5B7D2054AE82}' will be ignored as its DN contains strings in the ignore list
[12:17:56] Mailbox '/o=name/ou=First Administrative Group/cn=Recipients/cn=SystemMailbox{9EE03098-A30B-494E-943D-5B7D2054AE82}' will be ignored as its DN contains strings in the ignore list
[12:17:56] Found 3 mailbox(es) homed on database 'FIRST STORAGE GROUP/MAILBOX STORE (servername)'.
[12:17:56] Ignored 3 mailbox(es) homed on database 'FIRST STORAGE GROUP/MAILBOX STORE (servername)'.
[12:17:56] Found 3 mailbox(es) homed on the specified databases.
[12:17:56] Ignored 3 mailbox(es) homed on the specified databases.
[12:18:10] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations.
[12:18:10] Merging data into target store. The program will copy only those messages that do not exist in the target store.
[12:18:10] Associated folder data will NOT be copied to the target store.
[12:18:10] Using 'English (US)' (0x409) as the default locale (Code page 1252)
[12:18:10] All mailboxes will be processed, regardless of locale
[12:18:10] Using last logon locale for all mailboxes, if possible
[12:18:10] Initializing worker thread (Thread0)
[12:18:10] Merging data from file 'C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\DESKTOP\MAIL\JEFFREY.PST' to mailbox 'Jeffrey' ('JEFFREY') on server 'servername'.
[12:18:10] Error configuring message service (MSPST MS) (MAPI_E_EXTENDED_ERROR)  (CMapiSession::CreateEMSPSTProfile)
[12:18:10] Errors encountered. Copy process aborted for mailbox 'Jeffrey' ('JEFFREY').
[12:18:10] Number of items copied from the source store for all mailboxes processed: 0
[12:18:10] Total number of folders processed in the source store: 0
[12:18:10] 0 mailboxes successfully processed. 1 mailboxes were not successfully processed. 0 non-fatal errors encountered.
[12:18:10] Process completion time: 00:00:00
De regel
roept bij mij vragen op.
Ik heb eerder wel een .pst file kunnen importeren maar die was ongeveer 60mb groot en was nog in outlook97/2000 formaat.....overigens kon ik een bestand van ongeveer 30mb niet importeren die ook afkomstig was uit outlook2003.....
Ik neem aan dat exchange wel gewoon om kan gaan met bestanden van deze grootte (350mb)....???
Pleaz help
[ Voor 4% gewijzigd door Verwijderd op 13-08-2004 12:31 ]
  • Zwelgje
  • Laatst online: 17-08 09:02
start outlook op, connect naar je exchange mailbox en importeer via outlook
waarschijnlijk kan exmerge niet met outlook2003 pst files overweg
[ Voor 32% gewijzigd door Zwelgje op 13-08-2004 12:42 ]
  • Arno
  • Laatst online: 22:14
Arno
PF5A
Er is ook geen nieuwere ExMerge uitgekomen sinds het PST formaat is aangepast bij Outlook 2003.
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
  • ArCadE
  • Laatst online: 22-10 11:53
ArCadE
No banana available
Hm, misschien dat er een mailbox size restrictie aan staat op de target mailbox?
Ander eventueel de pst openen in outllok 2003, nieuwe pst aanmaken die 2000 compatible is en daar de berichten naartoe slepen. Die pst vervolgens met exmerge proberen te importeren.
[ Voor 54% gewijzigd door ArCadE op 13-08-2004 13:34 ]
  • axis
  • Laatst online: 26-01-2023
heb je wel genoeg rechten om de mailbox in te mogen? by default hebben administrators geen full control over de mailboxen.
Two advices for network troubleshooting.. learn to draw diagrams in Visio, and THINK IN LAYERS!
ik heb mijn rechten als admin gewijzigd zodat ik volle rechten heb op de exchange server....
er is geen sizelimiet ingesteld
ik ben nu bezig met het kopieren van de bestanden via outlook zelf.....dat gaat prima.....een vreemd probleem hieraan is dat als ik dit doe, dan krijg ik in outlook gewoon de normale datumnotatie te zien van alle mailtjes (dus wanneer ik de mailtjes daadwerkelijk ontvangen heb), maar als ik dan via webaccess naar mijn mailbox ga dan zie ik dat alle mailtjes een datumnotatie hebben van het moment dat ze naar de server gekopieerd zijn.....das dus niet al te makkelijk.
misschien dat ik toch nog ff kan proberen om het pst niet read-only te zetten (voor zover hij daar al niet op staat), en kan ik ook nog eens kijken of ik het bestand met outlook2003 kan exporteren.
  • axis
Ook al ben je de almachtige enterprise admin, dan nog heb je geen full-control over alle mailboxen. Ome Bill heeft by default een vinkje verstopt die domain admins full control over de mailboxes DENIED. En zoals je weet overrulen deny ACLs de allow.
Je kunt met een registry key ervoor zorgen dat je de security page van je Organisation kunt zien in de System Manager, daar zie je de deny staan en weghalen. Google maar op 'ShowSecurityPage' ofzo.
Maar goed, dat even terzijde, dat is misschien helemaal niet de oorzaak van je probleem.
Dat probleem zou wel trouwens te omzeilen zijn door in te loggen op die bak (of op een werkstation) onder de account die bij de mailbox hoort, en dan exmerge te draaien.
[ Voor 15% gewijzigd door axis op 14-08-2004 01:42 ]
