Blijkt wel weer wat ICQ eigenlijk voor een ontzettend vaag proggie is. Van Mirabilis kreeg ik ook al een zeer vaag mailtje toen ik hun dit probleem voorlegde.
Hello,
Thank you for taking the time to write us.
Please note that the "file transfer" function works 'peer to peer' and the
files are not relayed through the ICQ servers.
The speed can vary from transfer to transfer but there is no size limit for
the files/directories sent.
If you cannot receive or send files through ICQ, please make sure that
you're not behind a firewall, and if you or the other party are, make sure
it is configured properly.
If a file transfer gets "stuck" in the middle, please initiate the transfer
again, and in the very beginning move the speed slider to the middle.
Note that ICQ sends and receives the files as they are sent. In order to
view or play any delivered file, you will need to have the proper viewer.
Thank you.
Kan je dus ook al niets mee
