[win2003] softwarematige harde reset
  • BitByter
  • Registratie: Juli 1999
  • Laatst online: 13-08 07:38
BitByter
Prutst dit forum
ik zoek eigenlijk een manier om effe een windows 2003 remote keihard te resetten :)
ik kan gewoon in TS inloggen en software starten, maar ik zoek een programmatje ofzo, wat gewoon "meteen" die bak laat resetten, zonder dat hij ook maar iets opslaat of wat dan ook
alsof je de reset knop indrukt :)
  • Microkid
  • Laatst online: 18:08
Microkid
Smile
Al eens shutdown.exe ingetypt? ;)
Usage: shutdown [/i] [/f] [/m \\computer][/t xxx][/d [p:]xx:yy [/c "comment"]]
No args Display help. This is the same as typing /?
/? Display help. This is the same as not typing any options
/i Display the graphical user interface (GUI). This must be the first option
/l Log off. This cannot be used with /m or /d option
/s Shutdown the computer
/r Shutdown and restart the computer
/a Abort a system shutdown. This can only be used during the time-out period
/p Turn off the local computer with no time-out or warning. This can only be used with /d option
/h Hibernate the local computer. This can only be used with the /f option
/e Document the reason for an unexpected shutdown of a computer
/m \\computer Specify the target computer
/t xxx Set time-out period before shutdown to xxx seconds. The valid range is 0-600, with a default of 30
/c "comment" Comment on the reason for the restart or shutdown. Maximum of 127 characters allowed
/f Force running applications to close without forewarning users
/d [p:]xx:yy Provide the reason for the restart or shutdown
p indicates that the restart or shutdown is planned
xx is the major reason number (positive integer less than 256)
yy is the minor reason number (positive integer less than 65536)
[ Voor 102% gewijzigd door Microkid op 10-08-2004 18:26 ]
  • BitByter
BitByter
Prutst dit forum
het kan aan mij liggen, maar een optie om 'm keihard te resetten zit er niet bij :)
Syntaxis: shutdown.exe [-i | -l | -s | -r | -a] [-f] [-m \\computernaam] [-t xx]
[-c "opmerking"] [-d up:xx:yy]
No args Dit overzicht weergeven (gelijk aan -?)
-i Grafische interface weergeven (alleen als eerste
schakeloptie)
-l Afmelden (kan niet met de schakeloptie -m worden
gebruikt)
-s De computer afsluiten
-r De computer afsluiten en opnieuw opstarten
-a Het afsluiten van het systeem afbreken
-m \\computernaam Externe computer voor afsluiten/opnieuw
opstarten/afbreken
-t xx Time-out voor afsluiten instellen op xx seconden
-c "opmerking" Commentaar tijdens afsluiten (maximaal 127 tekens)
-f Actieve applicaties afsluiten zonder waarschuwing
-d [u][p]:xx:yy Code voor reden afsluiten
u is de gebruikerscode
p is een geplande afsluitingscode
xx is de code voor de hoofdreden
(positief heel getal onder de 256)
yy is de code voor de bijreden
heb ik dan een andere shutdown :?
[ Voor 4% gewijzigd door BitByter op 10-08-2004 18:27 ]
  • Microkid
Microkid
Smile
shutdown -r -t 5 zou de server in 5 seconden moeten herstarten. Wat wil je dan nog meer :?
  • Morax
  • Laatst online: 28-08 23:20
Wat is hier mis mee dan?
What do you mean I have no life? I am a gamer, I got millions!
  • BitByter
BitByter
Prutst dit forum
ja, hij gaat dan "herstarten"
is dat alsof ik de resetknop indruk ??
nee, want hij gaat dan "netjes" afsluiten
en dat moet NIET, omdat hij niet goed reboot :)
heb ff geen zin om door de regen een half uur met de scooter te rijden om die bak een duwtje te geven omdat hij weer 's niet goed reboot :)
  • Zwelgje
  • Laatst online: 17-08 09:02
achter de console is het
ctrl-alt-del en dan ook de rechterCTRL knop ingedrukt houden, en dan kiezen voor shutdown, dan krijg je een melding dat er niks wordt opgeslagen
echter op een TS werkt dat niet
  • BitByter
BitByter
Prutst dit forum
nee, en hij slaat dan niks op nee, maar altijd nog wel z'n filecache
het moet bijna EXACT hetzelfde zijn, alsof ik de resetknop indruk
het software programma "remotely anywhere" kan dit, maar ik moet die bak herstarten om het te kunnen installeren :/
[ Voor 6% gewijzigd door BitByter op 10-08-2004 18:32 ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
zwelgje schreef op 10 augustus 2004 @ 18:31:
en als je /console gebruikt misschien? (Ik roep maar wat hoor)
dus:
mstsvc /v:123.45.67.89 /console
Waarbij 123.45.67.89 het IP van de server is...
|:( Ctrl-Alt-Delete werkt altijd lokaal. Het is niet voor niets een SAS...
[ Voor 9% gewijzigd door RobIII op 10-08-2004 18:33 ]
Je eigen tweaker.me redirect
Over mij
  • BitByter
BitByter
Prutst dit forum
ik ben al als console ingelogged :) met -console :)
eerst kon ik het met het proggie kill.exe
kill.exe winlogon
dan crahste 2003, maar in TS of -console TS werkt dat niet
[ Voor 56% gewijzigd door BitByter op 10-08-2004 18:34 ]
  • Zwelgje
RobIII schreef op 10 augustus 2004 @ 18:32:
dus:
werkt ook niet, je moet er fysiek achter zitten
mischien dat andere remotecontrol tools het wel kunnen :? alleen daar heeft de TS nu niets aan
  • alt-92
alt-92
ye olde farte
je kan alleen een harde shutdown forceren via console dacht ik, er is een key combo voor....
[edit]
Die van zwelgje dus, dat krijg je als je eerst loopt te zoeken 8)7
Anders:
http://www.worldssp.net/software/Force-Shutdown.htm
[ Voor 21% gewijzigd door alt-92 op 10-08-2004 18:37 ]
  • Microkid
Microkid
Smile
Anders dit nog:
Winlogon service stoppen werkt geheid. Hierdoor zal de server ZICHZELF omwege security redenen rebooten. Wij gebruiken dit op het werk zelf altijd als laatste redmiddel.
Ik gebruik hiervoor zelf de tool "pskill" voor. Deze tool is onderdeel van de pstools die bij sysinternals gratis te downloaden zijn. linkje: www.sysinternals.com/ntw2k/freeware/pstools.shtml
De syntax wordt dan:
"pskill \\machine winlogon"
  • BitByter
BitByter
Prutst dit forum
dat werkt dus niet in ts ofzo
ik heb het geprobeerd, maar hij start METEEN weer een nieuwe winlogon.exe
ook al heb ik geen sessie open staan en is de console uitgelogged
kan ik met hyena altijd nog "taken" starten
als ik dan kill winlogon doe, crashed het systeem helaas niet
hij start meteen weer een nieuwe :?
als ik het hier lokaal doe op me bak, werkt het wel
remote dus niet :( ofzo :( argh :(
[ Voor 15% gewijzigd door BitByter op 10-08-2004 19:08 ]
  • Zwelgje
BitByter schreef op 10 augustus 2004 @ 19:08:
er, jouw server is via netbios/rpc te benaderen :? :?
aangezien je het via hyena doet
  • BitByter
BitByter
Prutst dit forum
yup :)
  • Zwelgje
en die bak is publiek te bereiken?
  • Zwelgje
zwelgje schreef op 10 augustus 2004 @ 19:12:
en die bak is publiekelijk te bereiken?
!@#$ sta ik mezelf te quoten |:(
[ Voor 12% gewijzigd door Zwelgje op 10-08-2004 19:12 ]
  • alt-92
alt-92
ye olde farte
dan kill je lsass toch gewoon? (deed sasser ook)
  • BitByter
BitByter
Prutst dit forum
inderdaad, is dat nie goed dan ??
je moet admin rights hebben om iets te kunnen :)
  • alt-92
alt-92
ye olde farte
rpc/netbios over inet enablen is natuurlijk dikke fuck.
  • BitByter
BitByter
Prutst dit forum
als je lsass closed, gaat hij na een minuut REBOOTEN, en dat is niet de bedoeling
hij moet gewoon crashend resetten oid :)
  • Zwelgje
BitByter schreef op 10 augustus 2004 @ 19:13:
:D
das nie zo moeilijk als je alles poortjes open laat staan
zet dan op zijn minst die firewall aan in 2003 en laat alleen rdp door
  • alt-92
alt-92
ye olde farte
in die tijd dat je nu aan het kutten bent was je er dus allang geweest ;)
  • BitByter
BitByter
Prutst dit forum
ok, allemaal goed :) maar ik wil eik eerst ff die bak resetten ;)
  • Zwelgje
BitByter schreef op 10 augustus 2004 @ 19:15:
You can force Windows 2000 and XP to display the blue screen of death. Hopefully, the only reason to do this is that you'll never see it otherwise! In the Registry key HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Services\i8042prt\Parameters, find or create a DWORD value named CrashOnCtrlScroll. Double-click on the value and set its data to 1. Restart your computer. Now you can cause a crash by holding the right-hand Ctrl key and pressing the Scroll Lock key twice.
is dat mischien iets?
  • BitByter
BitByter
Prutst dit forum
  • alt-92
alt-92
ye olde farte
Fietsen dan maar :Y)
Daar is wel een vbsje voor, ik heb er 1 om pc uit te zetten, of ie iets opslaat weet ik alleen nie :) Nooit uitgeprobeert :X
  • alt-92
alt-92
ye olde farte
je ZOU natuurlijk een .vbscript kunnen maken wat de keypresses nadoet....
  • CaDje
  • Laatst online: 09:12
CaDje
Framedrops for life
dus:
Als je Remote desktop gebruikt. (Dat neem ik aan) Kun je naar Start gaan => settings => windows security. Dan krijg je hetzelfde als de combinatie crtl, alt, del.
  • Zwelgje
CaDje schreef op 10 augustus 2004 @ 20:28:
ctrl-alt-end doet hetzelfde
  • BitByter
BitByter
Prutst dit forum
FOK, nou heb ik EINDELIJK een tooltje gevonden, het heet "bang"
het is een klein windows proggie, en ik moet dus op een knop drukken om 'm te activeren...
maar NU, is m'n TS client blijven hangen, administrator is nog ingelogd, en die sessie timed niet out
iemand een idee om remote die sessie te beeindigen ?
[ Voor 20% gewijzigd door BitByter op 10-08-2004 21:40 ]
  • Zwelgje
BitByter schreef op 10 augustus 2004 @ 21:39:
Terminal server manager opstarten op je lokale pc en dan connecten naar die doos
(je had alle poortjes openstaan dus dat moet werken }) )
  • BitByter
BitByter
Prutst dit forum
sjaisse, ik heb XP hier lokaal
ff iets verzinnen
  • Zwelgje
BitByter schreef op 10 augustus 2004 @ 21:48:
ff iets verzinnen
adminpak2003 downloaden van de ms site, daar zit alles in
http://www.microsoft.com/...dcbacff8e3&displaylang=en
[ Voor 19% gewijzigd door Zwelgje op 10-08-2004 21:50 ]
  • BitByter
BitByter
Prutst dit forum
geen sp1 geinstalleerd :( *zucht* het zit mee ;)
  • BitByter
BitByter
Prutst dit forum
na het geinstalleerd te hebben, bleek dat hij niet op een ip adres kan connecten :/
  • alt-92
alt-92
ye olde farte
Ik zei toch dat het fietsen zou worden? :Y)
  • Tomsworld
Tomsworld
officieel ele fan :*
Volgens mij is er maar een goede oplossing voor zo'n probleem. En dat noemt een masterswitch :)
"De kans dat een snee brood op een nieuw tapijt valt met de beboterde zijde onderaan, is recht evenredig met de prijs van het tapijt"
  • alt-92
alt-92
ye olde farte
Die kan ie morgenochtend mooi gelijk meenemen en neerhangen :P
  • BitByter
BitByter
Prutst dit forum
laatste kickje??
iemand nog een tip?
zit nog steeds met het zelfde gezever hier :P
ps, ik heb een proggie dat werkt het heet "bang"
het probleem is alleen, dat ik op een "knop" moet drukken, het is een windows proggel
aangezien ik die bak niet kan remote desktoppen oid, kan ik niet op die knop drukken
eigenlijk zou ik 'm moeten aanpassen ofzo, dattie meteen start
maarl ijkt me nogal moeilijk
http://www.mikoo.nl/bang.zip
[ Voor 68% gewijzigd door BitByter op 13-08-2004 18:35 ]
  • alt-92
alt-92
ye olde farte
......en dat allemaal omdat je GEEN ZIN hebt om te fietsen / scooteren?
Get a life man...
1x erheen en je bent van je gezanik verlost (en wij ook).
  • BitByter
BitByter
Prutst dit forum
nou, ik heb er inderdaad geen zin in
vooral omdat de beheerder 2 weken op vakantie is.....
  • Tomsworld
Tomsworld
Ipv allemaal zo'n workarounds te zoeken, pak het probleem aan ? Een goed beheerde server crasht niet zomaar.
En anders bestaan er hardware oplossingen zoals een apc masterswitch. Hoe wil jij een hardwarematig iets met software oplossen. Als dat kan geef me eens een linkje voor wat harddisks van 300 GB.
  • BitByter
BitByter
Prutst dit forum
download bang.zip en laat je bak crashen
dat is wat ik bedoel, en nee het gaat niet hardwarematig
maar het komt het meest in de buurt van een hardware reset
  • Wacky
  • Laatst online: 27-08 21:39
Wacky
Dr. Lektroluv \o/
BitByter schreef op 13 augustus 2004 @ 18:51:
Reken voorrijkosten e.d. dan verdien je er nog geld mee ook :P
  • FastBunny
  • Laatst online: 26-08 11:52
FastBunny
Give it the Works !
Is het niet handiger uit te zoeken waarom het rebooten fout gaat :? Keihard resetten kan nooit goed zijn voor je pc namelijk. Overigens had je vroeger genoeg restart.exe files, wellicht kun je die proberen, maar ik zou eens naar de oorzaak kijken ipv een workaround te doen.
Server: Dell PowerEdge R610, 48GB DDR3 1333MHz, 3 x 4TB IronWolf RAID5, Dell H700, VMware ESXi 6.0
Laptop: Dell Latitude E6510, Intel i5-560m, 8GB RAM, 128GB Samsung SSD, 250GB 7200rpm, 15.4" WUXGA FHD
PSN: FastBunny_NL
  • alt-92
alt-92
ye olde farte
BitByter schreef op 13 augustus 2004 @ 18:49:
Als jij niet de beheerder bent zou ik er lekker vanafblijven.
  • BitByter
BitByter
Prutst dit forum
FastBunny schreef op 13 augustus 2004 @ 18:57:
het hoeft maar 1 keer, want dan kan ik een ghost terug zetten
en ik weet al waarom hij niet goed reboot.
onze "goederen" disk raid array, word niet gedetecteerd
in computer beheer stond dat hij ontkoppeld was, en ik wilde hem activeren
hij blijft oneindig lang activeren, ook het disk management is daardoor niet meer zichtbaar.
als je reboot, blijft hij nog steeds die disk proberen te proben (oid)
daarom een harde reset
BackSlash32 schreef op 13 augustus 2004 @ 18:59:
niet echt "beheerder " maar meer "eigenaar, van een dikke verbinding"
[ Voor 23% gewijzigd door BitByter op 13-08-2004 19:04 ]
