[cedega] Render problemen
Heb sinds een tijdje ook cedega, (nieuwe versie winex). Het werkt opzich perfect, alleen blijf ik render problemen houden. Spellen etc installeren zonder problemen, alleen veel games gaan fout op render problemen. De WoW beta wil zelfs nieteens zijn install-scherm geven:
$cedega ./wow/Installer.exe
geef gewoon de promt terug, zonder dat er iets gebeurd..
$ cedega -debugmsg +err ./wow/Installer.exe
fixme:win32:PE_CreateModule Load Configuration directory ignored
fixme:xrender:X11DRV_XRender_Finalize Free cached glyphsets
$ cedega -debugmsg +err ./morrowind/Morrowind\ Launcher.exe
En geeft in een scherm:
Render Creation Error: "Unknown frame buffer mode."
Even wat info:
$ fglrxinfo
display: :0.0 screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9700 PRO Generic
OpenGL version string: 1.3 (X4.3.0-3.9.0)
$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
GLX_ATI_render_texture
GLX extensions:
OpenGL extensions:
GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_multisample,
GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_shadow,
GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_element_array,
GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer,
GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object,
GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3,
GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection,
GL_EXT_texture3D, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader,
GL_HP_occlusion_test, GL_NV_texgen_reflection, GL_NV_blend_square,
GL_NV_occlusion_query, GL_NV_point_sprite, GL_ARB_point_sprite,
GL_SGI_color_matrix, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_lod,
GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
$ cat .transgaming/config
WINE REGISTRY Version 2
;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
;; MS-DOS drives configuration
;; Each section has the following format:
;; [Drive X]
;; "Path"="xxx" (Unix path for drive root)
;; "Type"="xxx" (supported types are 'floppy', 'hd', 'cdrom' and 'network')
;; "Label"="xxx" (drive label, at most 11 characters)
;; "Serial"="xxx" (serial number, 8 characters hexadecimal number)
;; "Filesystem"="xxx" (supported types are 'msdos'/'dos'/'fat', 'win95'/'vfat', 'unix')
;; This is the FS Wine is supposed to emulate on a certain
;; directory structure.
;; Recommended:
;; - "win95" for ext2fs, VFAT and FAT32
;; - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
;; DON'T use "unix" unless you intend to port programs using Winelib !
;; "Device"="/dev/xx" (only if you want to allow raw device access)
[Drive C]
"Path" = "/home/dennis/.transgaming/c_drive"
"Type" = "hd"
"Label" = "Dos Drive"
"Filesystem" = "win95"
[Drive D]
"Path" = "${HOME}"
"Type" = "hd"
"Label" = "My Home"
[Drive E]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "tmp"
[Drive G]
"Path" = "/"
"Type" = "hd"
"Label" = "root"
[wine]
"Windows" = "c:\\windows"
"System" = "c:\\windows\\system32\\"
"Temp" = "e:\\"
"Path" = "c:\\windows\\;c:\\windows\\system32\\"
"GraphicsDriver" = "x11drv"
; Wine doesn't pass directory symlinks to Windows programs by default.
; Enabling this may crash some programs that do recursive lookups of a whole
; subdir tree in case of a symlink pointing back to itself.
; Note: The WINESHELLLINK Environment variable will override this setting.
; (which is set in the winex startup script)
;"ShowDirSymlinks" = "1"
"ShellLinker" = "/usr/lib/transgaming_cedega/winex/bin/wineshelllink"
; Browser to be used by winebrowserlink.
; Note: The WINEBROWSER Environment variable will override this setting.
;"Browser" = "/usr/bin/konqueror"
# <wineconf>
[DllDefaults]
"DefaultLoadOrder" = "native, builtin, so"
[DllOverrides]
"commdlg" = "builtin, native"
"comdlg32" = "builtin, native"
"oleaut32" = "builtin, native"
"ver" = "builtin, native"
"version" = "builtin, native"
"shell" = "builtin, native"
"shell32" = "builtin, native"
"shfolder" = "builtin, native"
"shlwapi" = "builtin, native"
"lzexpand" = "builtin, native"
"lz32" = "builtin, native"
"comctl32" = "builtin, native"
"commctrl" = "builtin, native"
"advapi32" = "builtin, native"
"crtdll" = "builtin, native"
"mpr" = "builtin, native"
"winspool.drv" = "builtin, native"
"d3d8" = "builtin, native"
"d3drm" = "builtin, native"
"ddraw" = "builtin, native"
"dinput" = "builtin, native"
"dinput8" = "builtin, native"
"dmusic" = "builtin, native"
"dsound" = "builtin, native"
"opengl32" = "builtin, native"
"msvcrt" = "native, builtin"
"rpcrt4" = "native, builtin"
"msvideo" = "builtin, native"
"msvfw32" = "builtin, native"
"mcicda.drv" = "builtin, native"
"mciseq.drv" = "builtin, native"
"mciwave.drv" = "builtin, native"
"mciavi.drv" = "native, builtin"
"mcianim.drv" = "native, builtin"
"msacm.drv" = "builtin, native"
"msacm" = "builtin, native"
"msacm32" = "builtin, native"
"midimap.drv" = "builtin, native"
"wininet" = "builtin, native"
"msvcr71" = "native, builtin"
[Version]
; Windows version to imitate. Valid versions are: 'win20', 'win30', 'win31', 'win95', 'win98', 'winme', 'nt351', 'nt40', 'win2000', 'winxp'
"Windows" = "win98"
; DOS version to imitate
;"DOS" = "6.22"
[x11drv]
; Number of colors to allocate from the system palette
"AllocSystemColors" = "100"
; Number of colors to copy from the default palette
"CopyDefaultColors" = "0"
; Use a private color map
"PrivateColorMap" = "N"
; Favor correctness over speed in some graphics operations
"PerfectGraphics" = "N"
; Color depth to use on multi-depth screens
;;"ScreenDepth" = "16"
; Name of X11 display to use
;;"Display" = ":0.0"
; Allow the window manager to manage created windows
"Managed" = "Y"
; Use a desktop window of 640x480 for Wine
;"Desktop" = "800x600"
; Use XFree86 DGA extension if present
; (make sure /dev/mem is accessible by you !)
"UseDGA" = "N"
; Use XShm extension if present
"UseXShm" = "Y"
; Enable DirectX mouse grab
"DXGrab" = "Y"
; Use XVidMode extension if present
"UseXVidMode" = "Y"
; Use XRandR extension if present
"UseXRandR" = "N"
; Create the desktop window with a double-buffered visual
; (useful to play OpenGL games)
"DesktopDoubleBuffered" = "Y"
; Code page used for captions in managed mode
; 0 means default ANSI code page (CP_ACP == 0)
"TextCP" = "0"
; Use this if you have more than one port for video on your setup
; (Wine uses for now the first 'input image' it finds).
;; "XVideoPort" = "43"
; Use this to make your X server execute all commands
; sequentially rather than buffering commands. Will make
; everything really SLOW but can be nice for debugging.
;; "Synchronous" = "Y"
; Enable the FPS count on the TransGaming HUD (also activates the HUD)
;; "ShowFPS" = "Y"
; Enable memory statistics on the TransGaming HUD (must have ShowFPS activated)
;; "ShowMem" = "Y"
; How much Video RAM does your card have?
"VideoRam" = "32"
; How much should WineX attempt to store into faster AGP memory
"AGPVertexRam" = "16"
; Use NV_VAR (enabled by default)
;;"NV_VAR" = "Y"
; Use ARB_VBO (enabled by default, NV_VAR takes precendence)
;;"ARB_VBO" = "Y"
[d3dgl]
"AnisotropicTextureFiltering" = "N"
"VertexShaders" = "Y"
; type of vertex shaders to use (Hardware/Software/Auto)
; hardware will use whatever the opengl drivers make available
; software will use winex software emulation (will be slow!)
; (has not been implemented yet!)
;; "VertexShaderMode" = "Auto"
"PixelShaders" = "Y"
; Which version of pixel shaders to attempt to use, if available
;;"PixelShadersLevel" = "1.1"
"ClipSpaceFix" = "Y"
; enable software vertex blend weight support (Yes/No/Auto)
; provide software blending fallback if hardware support not available
;; "SoftwareVertexBlending" = "Auto"
; (dev-only) Maximum number of texture stages that WineX should attempt to use (1-8)
;; "MaxTextureStages" = "8"
; (dev-only) Identify polygons under the mouse cursor
;; "InterceptMode" = "N"
; (dev-only) apply fragment translation in vertex program (Yes/No/Auto)
;;"FragmentOffset" = "Auto"
[dinput]
; dead zone for joystick input from 0 to 10000. 1000 is 10% of range.
"DefaultDeadZone" = "1000"
[joystick]
;; Configuration of the function of joystick axes
;; The joystick name and axis functions can be determined with jstest.
;; The available axis types are:
;; "none", "X", "Y", "Z", "RX", "RY", "RZ",
;; "slider", "hat", "POV", and "ball"
;; "hat" and "POV" are synonymous. Hats use two axes.
"Logitech Inc. WingMan RumblePad" = "X,Y,slider,Z,RZ,hat,none"
[fonts]
;Read documentation/fonts before adding aliases
"Resolution" = "96"
"Default" = "-adobe-times-"
; Use new improved fonts (uses FreeType and XRender libraries) at user request.
; Defaults to "Y".
;"FreeType" = "N"
[FontPatterns]
"Pattern0" = "-adobe-times*"
"Pattern1" = "-adobe-helvetica*"
"Pattern2" = "-adobe-courier*"
"Pattern3" = "-misc-fixed*"
[FontDirs]
;"0"="/path/to/extra/fonts"
[FontAlias]
;; Add font aliases here. On the left put the name of the windows font family
;; that you want to fake, on the right put the a similar font family that you
;; have installed. These will override the fontconfig and the WineX builtin fallbacks,
;; but may look better (if you choose them correctly).
;; Alias' may refer to other alias' that have been defined above them.
;; These alias' are the first that WineX loads.
;; Serif Fonts
;"Times New Roman"="Times"
"MS Serif"="Times New Roman"
;; Sans Serif Fonts
;"Arial"="Helvetica"
"Helv"="Arial"
"MS Sans Serif"="Arial"
"System"="Arial"
"Tahoma"="Arial"
;; Mono Space Fonts
;"Courier New"="Courier"
;"FixedSys"="Courier"
[memory]
;; Attempt to make memory allocation more windows like.
;; Not for use with all applications. Best used in app default section.
; "MemoryLayoutOverride" = "0x10000000"
[serialports]
"Com1" = "/dev/ttyS0"
"Com2" = "/dev/ttyS1"
"Com3" = "/dev/ttyS2"
"Com4" = "/dev/modem"
[parallelports]
"Lpt1" = "/dev/lp0"
[spooler]
"LPT1:" = "|lpr"
"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
"LPT3:" = "/dev/lp3"
[ports]
;"read" = "0x779,0x379,0x280-0x2a0"
; "write" = "0x779,0x379,0x280-0x2a0"
[spy]
"Exclude" = "WM_SIZE;WM_TIMER;"
[registry]
;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
;Defaults are read all, write to Home
; Global registries (stored in /etc)
"LoadGlobalRegistryFiles" = "n"
; Home registries (stored in ~user/.wine/)
"LoadHomeRegistryFiles" = "Y"
; Load Windows registries from the Windows directory
"LoadWindowsRegistryFiles" = "n"
; TRY to write all changes to home registries
"WritetoHomeRegistryFiles" = "Y"
; Registry periodic save timeout in seconds
; "PeriodicSave" = "600"
; Save only modified keys
"SaveOnlyUpdatedKeys" = "Y"
[Tweak.Layout]
;; supported styles are 'Win31'(default), 'Win95', 'Win98'
"WineLook" = "Win98"
[Console]
"Drivers" = "xterm"
;"Drivers" = "tty"
"XtermProg" = "konsole"
;"InitialRows" = "25"
;"InitialColumns" = "80"
;"TerminalType" = "nxterm"
[Clipboard]
"ClearAllSelections" = "0"
"PersistentSelection" = "1"
; List of all directories directly contain .AFM files
[afmdirs]
;"1" = "/usr/share/ghostscript/fonts"
;"2" = "/usr/share/a2ps/afm"
;"3" = "/usr/share/enscript"
;"4" = "/usr/X11R6/lib/X11/fonts/Type1"
[Wineserver]
"SHMWineserver" = "Y"
[WinMM]
"Drivers" = "wineoss.drv"
"WaveMapper" = "msacm.drv"
"MidiMapper" = "midimap.drv"
[wineoss]
"UseMMap" = "N"
"FullDuplex" = "N"
;; Specify a mapping for what digital audio devices to use
;"dsp0" = "/dev/dsp0"
;"mixer0" = "/dev/mixer0"
[winealsa]
"UseMMap" = "Y"
;"pcm0" = "hw"
;"ctl0" = "hw"
;; App default settings
;; Battle Field 1942 settings
[AppDefaults\\bf1942.exe\\d3dgl]
"ClipSpaceFix" = "N"
;; Medal Of Honor settings
[AppDefaults\\mohaa.exe\\memory]
[AppDefaults\\mohaademo.exe\\memory]
[AppDefaults\\moh_spearhead.exe\\memory]
[AppDefaults\\moh_spearhead.exe\\Version]
"Windows" = "win2k"
[AppDefaults\\moh_spearhead_demo.exe\\memory]
;; SimCity 4 settings
[AppDefaults\\SimCity 4.exe\\Version]
"Windows" = "win2k"
[AppDefaults\\SimCity 4.exe\\transgaming]
"cmdlineadd" = "-d:software"
;; Civ 3
[AppDefaults\\Civilization3.exe\\Version]
"Windows" = "win2k"
;; Call of Duty
[AppDefaults\\CoDSP.exe\\Version]
"Windows" = "win2k"
[AppDefaults\\CoDMP.exe\\Version]
"Windows" = "win2k"
;; City of Heros
[AppDefaults\\CityOfHeroes.exe\\Version]
"Windows" = "win2k"
[AppDefaults\\CityOfHeroes.exe\\cursor]
"CursorAlphaAlwaysOn" = "Y"
[AppDefaults\\CohUpdater.exe\\Version]
"Windows" = "win2k"
[AppDefaults\\CohUpdater.exe\\cursor]
;; EverQuest
[AppDefaults\\eqgame.exe\\d3dgl]
"ForceMaxVertexBlendMatrices" = "2"
[AppDefaults\\testeqgame.exe\\d3dgl]
;; Need for Speed Underground
[AppDefaults\\Speed.exe\\d3dgl]
"PixelShaders" = "N"
;; Max Payne 2
[AppDefaults\\MaxPayne2.exe\\d3dgl]
# </wineconf>
$ glxgears
17026 frames in 5.0 seconds = 3405.200 FPS
Hoop genoeg informatie gegeven te hebben, drivers werken goed, met het programmatje glxgears geeft volgens mij voldoende FPS, en ook alle andere manieren van checken (fglxinfo etc) geven de juiste informatie..
Draai trouwens gentoo, met de 2.4.26-gentoo-r7 kernel, gebouwd vanaf stage2.
  • kroeske
  • Laatst online: 25-03 11:35
Ik denk dat je meer succes zult hebben als je het op de fora van Transgaming zelf vraagt.
[edit]
ik neem aan dat wow World of Warcraft is btw?
wellicht dat je hier meer info kunt vinden
[ Voor 48% gewijzigd door kroeske op 10-08-2004 15:55 ]
Euh ja inderdaad, bedankt daar heb ik uiteraard ook al rondgekeken..
Maar omdat het probleem zich niet alleen bij WoW voordoet maar bij alle games, had ik het idee dat wellicht meer mensen hetzelfde probleem hebben gehad, of me kunnen uitleggen wat deze regel eigenlijk betekend:
  • kroeske
gebruik je toevallig Prelink of Exec-Shield op je systeem?
zoja, bekijk dan ff je release notes van cedega, daar staat voor veel dingen in.
heb je dit ook al gedaan? (lijkt me een eerdere oplossing dan dat hierboven staat...)
Make sure that your video card has working 3D acceleration
If you are using an NVidia video card, please make sure that the latest drivers
from http://www.nvidia.com have been installed on your system, and that
OpenGL is working properly.
To test your graphics card for OpenGL support execute the following command:
$ glxinfo | grep #direct rendering#
output will return "direct rendering:"
If this is 'Yes' or 'Enabled' then OpenGL is likely set up correctly. If it is
listed as 'no' or 'disabled' then double check your 3D setup.
[ Voor 72% gewijzigd door kroeske op 10-08-2004 17:09 ]
Verwijderd schreef op 10 augustus 2004 @ 15:48:
$ glxinfo
Yup, ook geregeld
Sorry voor een late reply, maar om het topic een beetje up-to-date te houden:
Heb Half-Life geinstalleerd, en dat draait werkelijk perfect, dus ik denk het aan de games zelf ligt ofzo, moet nog even verder kijken. Als iemand tips heeft plaats ze dan aub.
Overigens nog een raar probleem:
Tijdens het installeren van Dark Age of Camelot kan de setup bestanden niet vinden op de cd, kan het zijn dat de cd fout gelezen wordt (moet ik hem misschien op een speciale manier mounten ofzo? nu doe ik gewoon " mount /mnt/cdrom "
Setup zoekt bijvoorbeeld naar "help.html" en op de cd staat "help.htm" etc..
  • Straphka
Heb je iso9660 meegecompileerd in je kernel? Ik had nl hetzelfe probleem met het installen van UT2K4 voor Linux en het bleek dus aan deze ISO standaard te liggen.
Just my 2 cents
Ik heb:
ISO 9660 CDROM file system support als built-in in mijn kernel
Daaronder vallen ook Mircosoft Joliet CDROM extensions en
Transparent decompression extensions.
Deze heb ik niet.. zouden deze ook ingebakken moeten zijn?
[ Voor 84% gewijzigd door Verwijderd op 28-08-2004 16:56 ]
  • _Squatt_
Verwijderd schreef op 28 augustus 2004 @ 16:47:
Je hebt ook Joliet extensions nodig, ISO9660 ondersteunt alleen 8.3 filenames.
"He took a duck in the face at two hundred and fifty knots."
Ok het wordt een beetje offtopic, maar:
Ik heb de joliet extentions en ook die andere maar ingebakken in de kernel, maar blijf hetzelfde probleem houden. Ook krijg ik overigens UT2004 niet geinstalleerd:
mount: block device /dev/cdroms/cdrom0 is write-protected, mounting read-only
Mounted device /dev/cdroms/cdrom0
Unmounting device /dev/cdroms/cdrom0
Dit gebeurd de hele tijd, hij leest de cd wel, maar op een of andere manier ziet hij niet dat de goede cd er wel in zit..
En Dark Age of Camelot wil ook nogsteeds niet installeren, leest nogsteeds de cd verkeerd.. Zal eens een andere kernel proberen zometeen...
