X800pro VIVO Probleem Doom 3
Ik kan de games niet eens opstarten.... Heel erg vreemd.
Met mijn 9800XT kon ik het gisteren nog wel... Alleen drivers veranderd.
Dit is de foutmelding!
2998 MHz Intel CPU with MMX & SSE & SSE2
2048 MB System Memory
256 MB Video Memory
Winsock Initialized
Hostname: FERRY
IP: 10.0.0.150
doom using MMX & SSE & SSE2 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
4966 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...attempting to use stereo
...PIXELFORMAT 3 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: MULTICHANNEL
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
X..GL_ARB_texture_non_power_of_two not found
...using GL_ARB_texture_compression
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
...using GL_ATI_separate_stencil
...using GL_ATI_fragment_shader
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
X..EXT_depth_bounds_test not found
---------- R_NV20_Init ----------
Not available.
----- R200_Init -----
GL_NUM_FRAGMENT_REGISTERS_ATI: 6
GL_NUM_FRAGMENT_CONSTANTS_ATI: 8
GL_NUM_PASSES_ATI: 2
GL_NUM_INSTRUCTIONS_PER_PASS_ATI: 8
GL_NUM_INSTRUCTIONS_TOTAL_ATI: 16
GL_COLOR_ALPHA_PAIRING_ATI: 1
GL_NUM_LOOPBACK_COMPONENTS_ATI: 3
GL_NUM_INPUT_INTERPOLATOR_COMPONENTS_ATI: 3
FPROG_FAST_PATH
---------- R_ARB2_Init ----------
Available.
Cg not available.
---------- R_Exp_Init ----------
PARAM bloom0 = { 0.199501 };
PARAM bloom1 = { 0.176059 };
PARAM bloom2 = { 0.121004 };
PARAM bloom3 = { 0.064769 };
PARAM bloom4 = { 0.027000 };
PARAM bloom5 = { 0.008765 };
PARAM bloom6 = { 0.002216 };
PARAM bloom7 = { 0.000436 };
Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp
glprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
found DLL in pak file: C:\Program Files\Doom 3\base\game00.pk4/gamex86.dll
copy gamex86.dll to C:\Program Files\Doom 3\base\gamex86.dll
ERROR: LoadLibrary 'C:\Program Files\Doom 3\base\gamex86.dll' wants to load 'C:\PROGRA~1\DOOM3~1\base\gamex86.dll'
ERROR: couldn't load game dynamic library
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Erg kut gewoon :(
Mijn specs zijn:
Asus p4c800 Deluxe
Intel Pentium 4 3.0C HT
2x 512DDR 400
Sapphire X800Pro VIVO
Wie weet de oplossing... Heb alle Omega Drivers al gebruikt.
  • Vlassie1980
  • Laatst online: 19-10 11:35
Heb je al verschillende drivers geprobeerd? Met je AGP en fast-write instellingen gerommeld?
Als dit niet helpt kan je ook nog het ATi verwijderprogramma gebruiken, die haalt alle ATi bestanden van je pc af
Suc6
[ Voor 32% gewijzigd door Crash op 19-08-2004 12:45 ]
  • Brede P
  • Laatst online: 08-01 14:43
Met betrekking tot Doom 3 heeft Ati een (naar mijn weten nog steeds) Beta driver staan, met een Doom 3 fix. Misschien dat die problemen oplost?
Heb je je 9800XT verwijderd voor je je nieuwe kaart er in stopte?
  • MiNDiT
  • Laatst online: 31-05-2024
Dit is een bekend probleem. Je moet inderdaad de beta driver van ATI gebruiken of eventueel wachten op een nieuwe 'final' driver
