Doom 3GL problemen
  • 143 views sinds 30-01-2008
  • Zucht388
  • Laatst online: 16-05 09:54
2992 MHz Intel CPU with MMX & SSE & SSE2 & HTT
512 MB System Memory
128 MB Video Memory
Winsock Initialized
Hostname: pcboven
IP: 192.168.0.2
doom using MMX & SSE & SSE2 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Current search path:
D:\Doom 3/base
D:\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
4966 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
...calling CDS: ok
...created window @ 0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...attempting to use stereo
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: MULTICHANNEL
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
X..GL_EXT_texture_lod not found
X..GL_1.4_texture_lod_bias not found
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Met catalyst 4.4 kan ik gewoon spelen, met 4.7 en 4.9 krijg ik dit :S
Wat kan het zijn? Ik heb een Radeon 9800 Pro...
EDIT:
Hmz, Thief 3 start ook niet op met driver 4.7 en 4.9 heel raar...
Ik krijg dus zo'n standaard windows fouten rapport error, kut zooi :(
[ Voor 5% gewijzigd door Zucht388 op 05-08-2004 12:54 ]
Who the hell is general failure and why is he reading of my hard-drive?
  • w0w
  • Laatst online: 16-05 12:40
w0w
Heb je 4.4 wel eerst verwijderd? Of gooi je 4.7 en 4.9 er gewoon over heen?
Waarom wil je btw 4.7 en 4.9 draaien als 4.4 het beste draait bij jou? Is er een probleem met 4.4 die jij hebt en die is opgelost in 4.7?
[ Voor 50% gewijzigd door w0w op 05-08-2004 13:00 ]
w0w schreef op 05 augustus 2004 @ 12:59:
4.9 heeft de nieuwe opengl driver en is zo'n 10% sneller met z'n huidige videokaart.
Kun je niet gewoon 4.4 installeren en dan de 4.9 opengl driver handmatig overschrijven?
  • w0w
w0w
Het zou uiteraard wel moeten... Ik heb ook een keer zoiets gehad (wel andere problemen..) maar toen ik de oude drivers met een progje helemaal had weggehaald en toen de nieuwe erop werkte het wel.. misschien het proberen waard?
Ik zie nou in het doom3 topic dat je 4.9 wil om d3 te spelen, logisch :9
[ Voor 13% gewijzigd door w0w op 05-08-2004 13:08 ]
  • Zucht388
Ok, ik zal (nu staat er 4.9 op) die helemaal verwijderen met zo'n driver verwijderaar, en an 4.9 erweer op zetten?
