[Folding@home] v5 client
  • SandStar
  • Laatst online: 21:40
SandStar
DPC-Crew
Zandster
*update*
De V5 client is nu de officiële client
Belangrijkste veranderingen zijn de build-in service support voor Windows en een uitgebreidere Windows GUI.
Noot erbij is dat de grafische versie niet supported is onder windows 98. Deze gebruikers zijn of aangewezen op de console client of de oudere V4 client.
Het is te downloaden op: http://folding.stanford.edu/download.html .
Changelog:
- Collection server support. If a client finishes a work unit from
a Work server with this feature enabled, then if 2 upload
attempts to that server fail, the client will return to the
work unit to a Collection server. Pending credit will be given
for the unit, becoming final when the Work server comes back up
and verifies what the Collection server has received. All work
servers will eventually be associated with a Collection server,
and many already are.
- Configuration option to allow downloads and uploads greater
than 5 MB in size, which some new projects will require due
to the size of what they are simulating.
- G@H configuration option reworded to be "No deadline" option.
- Print executable name and launch directory to log.
- Fix for bug where queue slot could get stuck "Fetching"
- MyFolding links updated.
Linux specific:
- OpenBSD support: If give flag -openBSD, client will automatically
make elf2olf system call on downloaded Cores.
Windows specific:
- Configuration option to pause work when the computer is using
battery power (for laptops).
- Behavior in response to a shutdown or logoff of the system should
be improved (exiting nicely).
- Console: Built in service installation support through Configuration,
to have the program automatically begin at machine startup. If one
wishes, the service can be further configured and interacted with
through the Services tool (GUI) that can be accessed through the
Windows Settings (under Administrative Tools in 2000/NT). The Sc
command line tool may also be used. There are known issues with
the Net tool.
- GUI: Larger window size and more informative display.
- GUI: Screensaver configuration option.
- GUI: Print a message to FAHlog.txt when ask to network.
[ Voor 11% gewijzigd door SandStar op 11-08-2004 23:52 ]
  • Schapie
  • Laatst online: 19-02-2025
Schapie
Bleh...
Zo dat is mooi van stanford ze hebben de qeue verbeterd (had hier soms problemen mee dat je wel een wu af had maar dat ie niet verstuurde maar dat was snel verholpen met -send all)
Maar hij neemt ook mijn wu over waar ik nu mee bezig ben ?
wanneer komen er weer stats paar maanden terug hadden we backup stats nu alleen die van kompjoefriek (kloppen wel dat niet maar wil graag de overall zien) of wachten we nog eventjes tot teak weer terug is ?
No signature found
  • SandStar
SandStar
DPC-Crew
Zandster
Schapie schreef op 04 augustus 2004 @ 20:13:
Hij behoord de wu over te namen waar je mee bezig bent maar het verstandigste is om te wachten tot je huidige wu klaar is en dan over te stappen
Verder hebben we een paar maanden geleden idd backup stats gehad maar die waren van Onno en die is er een tijd geleden al mee gestopt.
Aan die van KompjoeFriek wordt nog een beetje gesleuteld en het is het enigste wat we momenteel hebben, het wachten is op Teak.
Misschien rare vraag... maar wat schiet ik ermee op als ik hem nu installeer. Ik heb niet een hele snelle compu (AMD 2400+, 512 geheugen), maar wel gruwelijk snel internet. Was deze versie niet voor behoorlijk grote WU's?
  • KompjoeFriek
  • Laatst online: 20-09 23:16
KompjoeFriek
Statsidioot
Verwijderd schreef op 05 augustus 2004 @ 00:26:
Als je je client aanroept met -config of -configonly zal hij het aan je vragen:
Allow receipt of work assignments and return of work results greater than 5MB in size (such work units may have large memory demands) (no/yes) [no]?
De service optie werkt goed hier (onder WinXP) maar ik krijg wel een gare Service name, namelijk "FAH@C:+PROGRA~1+FOLDIN~1+fah5console"
wat de stats betreft, daarmee ben ik nog in gesprek met de dpc-crew maar hopelijk krijgen we vandaag weer stats! :9
[ Voor 5% gewijzigd door KompjoeFriek op 05-08-2004 01:36 . Reden: Layout vernueking opgelost ]
WhatPulse! - Rosetta@Home - Docking@Home
  • SandStar
SandStar
DPC-Crew
Zandster
Zoals KompjoeFriek al aangaf bestaat er nu ook de mogelijkheid om aan te geven dat je extra grote units wilt hebben. Doe dit alleen als je ongeveer 512mb ram hebt.
Ik draai ze zelf al een tijdje zonder problemen en ze vreten dan ongeveer 120mb aan ram.
  • SandStar
SandStar
DPC-Crew
Zandster
En toen was de client officieel uit:
Hi,
The v.5.00 client is now on the main download page for Windows and Linux. We'll turn to Macintosh now. Thanks go to all those who helped with testing and giving feedback, which is the main reason it's turned out well. The only changes from the Prerelease are that the release will not expire and that the Windows Console fixes an issue where certain methods of launching the program would result in an improper service install.
The full v.5 change log can be viewed by clicking on the appropriate version number link on the download page ( http://folding.stanford.edu/download.html ).
-Guha
  • JohFraEl
  • Laatst online: 23-08 22:15
JohFraEl
Slainte!
Zijn er nog leuke dingen voor de Apple Mac Users?
kunnen onze DP G5's nog iets leuks verwachten?
Winter | 1st T-net Review
  • SandStar
SandStar
DPC-Crew
Zandster
JohFraEl schreef op 12 augustus 2004 @ 02:28:
Der wordt momenteel nog gewerkt aan de V5 voor Mac...
  • Mobster
  • Laatst online: 07-06-2016
Mobster
Los Alcoholicos
Dus ik kan nu mooi de oude client uninstallen van mijn PC?
Kan ik de 'oude' FAQ gewoon aanhouden of is de installatie procedure ook helemaal gewijzigd? :)
Toch maar eens een andere sig bedenken :P
  • SandStar
SandStar
DPC-Crew
Zandster
Mobster schreef op 12 augustus 2004 @ 10:45:
Bij gebrek aan een pc met grafische client kan ik je er nog niet echt mee helpen. Wat ik heb begrepen is dat er qua installatie weinig rare dingen naar voren zullen komen.
Bij de console versie is er al nauwelijks sprake van een installatie, gewoon downloaden en runnen.
Het enigste wat eigelijk veranderd is zijn de vragen tijdens de configuratie; zie changelog.
Verder zijn er wat grafische aanpassingen.
  • Jive
  • Laatst online: 22-05 22:10
Jive
MooMooMastah
Native Win32 Service Support :)
Kan dit nu ook via een "proxy"flushen ??
Hoeveel mem vreet de standaard client ???
Is er een tool om deze makkelijk remote te installen ?
Kun je offline werken met netwerk buffers of proxy buffering ?
Jive's Box
Jive @ DNET
  • Schapie
Schapie
Bleh...
Jive schreef op 12 augustus 2004 @ 11:15:
Kan dit nu ook via een "proxy"flushen ?? je kan wel een proxy server instellen maar ik weet niet of je ook kan sparen. door middel van een proxy dan zie ook hieronder.
Dat verschilt erg per wu ik heb nu een erg grote wu p1300 en die
vreet inc client en core 160mb maar,
dat kan je ook uitschakelen (staat standaard uit)
dat je alleen kleinere wu's krijgt en dan zit het rond de 30/40 mb.
Is er een tool om deze makkelijk remote te installen ? Weet ik niet denk het wel.
Kun je offline werken met netwerk buffers of proxy buffering ?Nee nog niet f@h heeft wel een qeue waar hij tien wu's in kan oplsaan maar je zit mer de houdbaarhied van de wu's das nog een groot probleem met sparen.
Alhoewel nu ook kan aangeven dat je wu's wil zonder deadline in deze nieuwe versie (dat ga ik zeker uit proberen icm met wat andere dingen mischien dat het dan door porten teblokken mogelijk om te sparen en tegaan flushen wanneer wij dat willen maar dit is nog niet gedaan voor zover ik weet)
[ Voor 6% gewijzigd door Schapie op 12-08-2004 16:52 . Reden: typo's ]
No signature found
  • SandStar
SandStar
DPC-Crew
Zandster
Nee je kan niet via een proxy flushen, wel via een proxyserver maar dat is niet wat je denk ik bedoeld
De client vreet bij Tinkers rond de 5-7mb en bij gromacs ongeveer 14-25mb
Double gromacs weet ik momenteel niet maar dat zal vergelijkbaar zijn.
Daarnaast kan je dus aangeven extra grote units te willen hebben en die kunnen variëren; ik heb ze momenteel van 110mb ram.
Qua tools heb ik wel een script gevonden voor gebruik met een active directory omgeving. (uitleg is hier en daar in het frans, hopelijk heeft ie het eindelijk eens een keer vertaald)
Je kan eigelijk niet offline werken, je kan wel een buffer aanleggen met 10 units zonder hulpmiddelen en met hulpmiddelen kan je 80 units bufferen.
