Fikker werkt niet meer >suddenly<
  • Bonkdoos
  • Laatst online: 30-11-2025
Hoi,
mijn brander vertoont al driekwart jaar kuren. Ik probeerde in dit geval met nero een groot avi-bestand te branden. Hij begon niet eens met de klus, maar overdonderde me meteen met foutmeldingen:
power calibration area is full
could not perform write
command sequence error
could not perform fixation
Burnprocess failed at 2x (300 KB/s)
hieronder de logfile...........
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 5-5-99 22:22:00
Nero Version: 4.0.5.6
Recorder: <PHILIPS CDD3610 CD-R/RW>Version: 3.01 - HA 0 TA 1 - 4.0.5.6
Adapter driver: <ESDI_506> HA 0
CD-ROM: <PHILIPS CDD3610 CD-R/RW>Version: 3.01 - HA 0 TA 1
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 23848140 Byte
ShowDrvBufStat : 0
EraseSpeed : 0
Physical memory : 127MB (130492kB)
Free physical memory: 0MB (28kB)
Memory in use : 78 %
Wizard: Off
CD-ROM (ISO)
26.12.2000
12:19:48 #1 ISO9660GEN -11 File Geniso.cpp, Line 3245
First writeable address = 0 (0x00000000)
12:19:48 #2 ISO9660GEN -12 File Geniso.cpp, Line 3250
Data Mode: 1, Write Mode: TAO
12:19:48 #3 ISO9660GEN -11 File Geniso.cpp, Line 3245
12:19:48 #4 ISO9660GEN -12 File Geniso.cpp, Line 3250
12:19:50 #5 ISO9660GEN -11 File Geniso.cpp, Line 3245
12:19:50 #6 ISO9660GEN -12 File Geniso.cpp, Line 3250
12:19:54 #7 Phase 24 File dlgbrnst.cpp, Line 897
Start of caching files
12:19:54 #8 Phase 25 File dlgbrnst.cpp, Line 897
Caching files completed
12:19:54 #9 Phase 36 File dlgbrnst.cpp, Line 897
Start of burnprocess at 2x (300 KB/s)
12:20:09 #10 SCSI 0 File Cmdqueue.cpp, Line 735
SCSI Exec, HA 0, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E 0x00 0x00 0x00
12:20:10 #11 mmc 29442 File Isotrf.cpp, Line 1048
Power calibration area is full
12:20:10 #12 TRANSFER -20 File Isotrf.cpp, Line 1058
Could not perform Write
12:20:10 #13 SCSI 0 File Cdrdrv.cpp, Line 964
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
12:20:10 #14 mmc 11264 File Isotrf.cpp, Line 1166
Command sequence error
12:20:10 #15 TRANSFER -19 File Isotrf.cpp, Line 1167
Could not perform Fixation
12:20:10 #16 TRANSFER -20 File Isotrf.cpp, Line 1188
12:20:10 #17 Phase 38 File dlgbrnst.cpp, Line 897
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 5-5-99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 2, size=29771 bytes, created 2-12-00 11:43:04
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (089), size=197984 bytes, created 10-4-00 7:10:56
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 5-5-99 22:22:00
Wie kan mij hiermee helpen??? ik heb deze brander ruim 2 jaar geleden voor 569 gekocht dus het zou mooi zijn als ik erl anger dan anderhalf jaar plezier van zou hebben, al is het maar met 2speed !!!!!
zeg niet altijd wat je weet, maar weet altijd wat je zegt
  • Dromer
Probeer is een ander merk cdr's
Ik heb ook die power calibration zooi gehad en een andere cdr gepakt en het was weer opgelost..
Het is niet iets dodelijks voor je burner
  • Bonkdoos
damn heb ik net 50 van die 'verkeerde' cd-r's gekocht !!
ik weet dat dit een oud topic is maar ik heb precies het zelfde probleem met dezelfde brander ik heb verschillende soorten cd-r's gebruikt van Fujifilm, Maxell en TDK die laatste heb ik vaak gebruikt en toen ging het altijd goed kan het dus nog aan wat anders liggen dan alleen aan de cd's?
Ik heb
Nero 5.5.8.0
PHILIPS CDD3610 CD-R/RW alleen dan de noname versie (is precies het zelfde)
Windows XP Prof
De brander zit samen met mijn LiteOn 16x40 DVD-Rom op 1 kabel (brander is slave) maar dit was altijd al zo.
[ Voor 26% gewijzigd door Verwijderd op 10-09-2003 12:53 ]
  • BalusC
BalusC
Carpe diem
Jahoor, aan de brander :)
Hoeveel CD's heb je er al ongeveer mee gebakken?
Check eens de FAQ van dit subforum onder "Mijn CD/DVD lezer/brander werkt niet goed onder Windows" voor meer tips/suggesties".
Trouwens, we doen liever niet aan topicrecycling, of je de volgende keer gewoon een nieuw topic wil openen met eventueel een aantal verwijzigingen naar oudere topics etc :)
[ Voor 18% gewijzigd door BalusC op 10-09-2003 12:56 ]
  • stylezzz
  • Laatst online: 08:23
Een 3610??? Zowiezo een wonder dat ie het nog doet, dit is echt een bejaarde onder de cd-recorders geworden. Waarom haal je niet gewoon een nieuw lite-on 52X of iets dergelijks? Brand tig keer zo snel en je hebt geen problemen meer met slechte media..... :)
  • swampy
  • Laatst online: 25-03 09:06
swampy
Coconut + Swallow = ?
Mmm, het is wel een oude brander maar zou het nog moeten doen...daartegen....branders verslijten en het is goed mogelijk dat je brander gewoon op is. Zeker na zo'n tijd...weet niet hoeveel je ermee brandt.
Haal eens een Sony CD-R, die MOETEN gewoon te branden zijn!
There is no place like ::1
Een brander heeft maar een bepaald aantal branduren :/
Erg veel brand ik er niet mee hoogstens 1 à 2 cd per maand (hij is ongeveer 4 jaar oud.)
Ik probeer het nog een keer door windows opnieuw te installeren, en anders maar naar een nieuwe kijken, het was zo'n fijn brandertje :'(
Hij doet het weer, een keer open maken en al het stof van 4 jaar eruit blazen en dat was het! :)
