De nieuwe Minolta Dimage Z3
  • 137 views sinds 30-01-2008
Leverbaar eind Juli, prijs onbekend. Verbeteringen t.o de Z1/Z2 zijn 4MP en stabilisator(anti-shake) 12x powerzoom.
Een paar shots (org. DPREVIEW)
Afbeeldingslocatie: http://www.dpreview.com/news/0407/dimagez3frontback.jpg
Vanaf de zijkant heeft ie erg veel weg van de oudere Canon PRO 70/90IS Hij is alleen iets korter;)
[url]
Afbeeldingslocatie: http://www.dpreview.com/news/0407/dimagez3specsview.jpg[
Caon PRO 90IS
Afbeeldingslocatie: http://www.chip.pl/arts/archiwum/n/images/198219_ff9dd15672.jpg
Hieronder de specs:
Number of effective pixels: 4.0 million
CCD: 1/2.5-type interline primary-colour CCD Total pixels: 4.2 million
Camera sensitivity: Auto and 50,100, 200, and 400 ISO equivalents
Focal length: 5.83 - 69.9mm (35mm equivalent: 35 - 420mm)
Lens construction: 13 elements in 10 groups
Maximum aperture: f/2.8 - f/4.5
Minimum focus distance: Wide: 0.6m/2.0ft from front of lens
Telephoto: 2.0m/6.6ft from front of lens
Wide: 0.685m / 2.2ft from CCD
Telephoto: 2.085m/ 6.8ft from CCD
Minimum macro distance: Super Macro Standard macro
Focal length 10.45mm* Wide Telephoto
From front of lens 1 cm 10cm 120cm
From CCD 9.5cm
18.5cm 128.5cm
Maximum magnification: 0.20x
Equivalent to 1.2x in 35mm format
Area covered at maximum magnification: 31 x 23mm /1.2 x 0.9 in.
Viewfinder type: Electronic viewfinder
0.3-type with a total of 118,000 pixels
LCD monitor: 3.8cm (1.5 inch) digital-interface TFT colour Total number of pixels: 78,000 (approx.)
Automatic monitor amplification
Field of view: Viewfinder: 100% (approx.)
LCD monitor: 100 % (approx.)
Diopter control: - 3 ~ +1m-1
Eye relief: 20.8mm
Shutter: CCD electronic shutter and mechanical shutter
Shutter speed range: 4 - 1/1000 s in programmed-AE and aperture-priority modes.
15 - 1/1000 s in shutter-priority and manual exposure modes.
Bulb (max. 30 s)
2 - 1/1000 s in auto-recording and Digital Subject Programs
Autofocus system:
Video AF system
Autofocus areas: 5-Point Wide Focus Area
Spot focus areas with Focus Area Selection
Focus modes: Single-shot AF, Continuous AF with predictive focus control, Full-time AF, Manual focus.
Focus lock: By pressing shutter-release button partway down.
Metering: Multi-segment, Center-weighted, Spot
Multi-segment metering: 256 segments
Exposure modes: Programmed AE, Aperture priority, Shutter priority, Manual
Digital Subject Programs: Automatic (Portrait, Sports action, Landscape, Sunset, Standard)
Manual (Portrait, Sports action, Landscape, Sunset, Standard, Night portrait.)
Exposure compensation: ±2 Ev in 1/3 increments
AE lock: By pressing shutter-release button partway down
Flash metering: Pre-flash TTL
Flash range: Wide: 0.2 - 4.0 m / 0.7 - 13.1 ft. (approx.) from front of lens
Telephoto: 1.2 - 2.5 m / 3.9 - 8.2 ft. (approx.) from front of lens
(Camera sensitivity: auto)
Flash modes: Autoflash, Autoflash with red-eye reduction, Fill flash, Slow-shutter sync. Autoflash not available with aperture priority, shutter priority, and manual exposure modes.
Flash cancel by pushing the built-in flash down.
Flash recycling time: 7 s (approx.)
Flash compensation: ± 2 Ev in 1/3 increments
Flash-sync speeds: All shutter speeds
External flashes: Auto-flash metering with Program/Maxxum Flash 2500 (D), Program/Maxxum 3600HS (D), Program/Maxxum Flash 5600HS (D)
Continuous advance: - UHS (Ultra High Speed) continuous advance: 10fps (approx.) (1280 x 960)
- Standard continuous advance:
2.5 fps (approx.)?(2272 x 1704)
* Actual speed may vary depending upon the subject and camera settings.
Approximate number of frames that can be captured at one time with the continuous-advance drive modes:
Progressive Capture: Stores images from the built-in memory to the memory card from the latest frame captured with the continuous advance. Maximum number of images that can be recorded with the Progressive Capture mode:
UHS: 15 frames (10 fps)
Standard: 5 frames (2.5 fps) (2272 x 1704, Standard)
Exposure bracketing:
Three frame bracket in 1.0, 0.5, 0.3 Ev increments
Self-timer: 10 s, 2s (approx.)
Movie: Recording time dependent on memory card capacity, image size, and frame rate.
Frame rate: 15fps, 30 fps
Audio: monaural
Optical zoom is ON in recording
Movie frame capture
Night movie (automatic selection or disabled)
White balance control: Automatic, Preset (Daylight, Cloudy, Tungsten, Fluorescent,
Flash), Custom
Digital Effects Control: Contrast compensation, Sharpness
Contrast compensation: Three levels (Low, Normal, High)
Sharpness settings: Three levels (Soft, Normal, Hard)
Colour modes: Natural Colour, Vivid Colour, Black and white, Sepia
Noise reduction: User selectable dark noise reduction
Digital zoom: 4x (max.) in 0.2x increments
Copy function: To copy single or multiple images to the same or another memory card.
E-mail Copy function: Creates a compressed 640x480 JPEG image for transmission.
Date imprinting: Year/month/day (Format can be changed.)
Imprinting can be disabled
Key customization: The function activated by the flash-mode button can be changed.
Image-quality modes: Fine, Standard, Economy
Number of recorded pixels Still images:
2272 x 1704, 1600 x 1200, 1280 x 960, 640 x 480
1280 x 960 in UHS continuous-advance mode
Movie clips:
640x480, 320x240
Storage capacity: Approximate storage capacity of a 16MB SD (Secure Digital) Memory Card:
Still images
2272x1704 1600x1200 1280x960 640x480
Fine 6 frames 14 frames 23 frames 50 frames
Standard 14 frames 23 frames 38 frames 67 frames
Economy 27 frames 41 frames 53 frames 100 frames
Movie clips
640x480 FINE 640x480 Standard 320x240 Standard
30 fps 9sec 14sec 30sec
15 fps 19sec 28sec 58sec
* Movie clips recorded with audio.
* Actual number of images may vary depending upon the subject and memory card used.
File formats: JPEG, Motion JPEG (MOV): with audio
DCF 2.0-compliant
DPOF-compliant (Supported by printing functions in ver. 1.1)
Exif 2.2
Folder name formats: Standard, Date
Printing output control: Exif Print, PRINT Image Matching II, PictBridge
Recording media: SD (Secure Digital) Memory Cards, Multimedia Cards
Computer interface:
Full-speed 12Mbps data transfer with USB 2.0 compatible computer
AV output:
NTSC, PAL (selected on the camera)
Anti-shake system: CCD-shift Anti-Shake system User selectable
Batteries Four AA batteries: Alkaline, Ni-MH
Battery performance Playback: Approximate continuous playback time: 220 min. (approx.) with alkaline batteries.
Recording: Approximate number of recorded images: 170 (approx.) Conforming to CIPA (included 4X AA alkaline batteries, included SD memory card)
External power source: 6V DC with specified AC adapter (sold separately)
Dimensions: 108.5 (W) x 80.0(H) x 83.5(D) mm
4.3(W) x 3.1 (H) x 3.3 (D) in.
Weight:
335g / 11.8oz. (Approx.) without batteries or recording media
Operating temperature: 0-40ºC / 32-104°F
Standard accessories: Neck Strap NS-DG7000
Lens Cap LF-243 set
Accessory Shoe Cap SC-1000
AV Cable AVC-700
USB Cable USB-2
DiMAGE Viewer CD-ROM
ArcSoft VideoImpression™ 2 CD-ROM (for Windows only)
Four AA Alkaline batteries
Optional accessories AC Adapter AC-1L or AC-11
Camera Case CS-DG1000
Leather Neck Strap NS-DG1000
Wide-Angle Converter ZCW-300 kit
Adapter ring for attaching filter/converter ZCA-300
PROGRAM FLASH 3600HS (D), 5600HS (D),
2500(D)
LetsGoDigital http://www.letsgodigital..../articles/story_1435.html heeft al een preview van de camera. Wanneer deze in de handel gaat komen is nog onbekend, maar dat zal niet lang duren denk ik.
Datasheet kun je http://www.konicaminoltae...res1.d4w?language=english
neerhalen.
Ik ga hem zelf niet kopen. Ben tevreden met de Minolta A1
Volgende de Z10?;)
Afbeeldingslocatie: http://www.gizmodo.com/archives/images/minolta_z10.jpg
er is al een topic over deze fantastische camera
/me invites u to
[rml][ DigiCam] Minolta Dimage Z3 4 MP 12x Zoom opvolger van Z2[/rml]
Oh OK, nou dit topic wissen kan zeker niet?
nope ik heb al een topic report gedaan maar ze schieten niet op ;)
mischien jij zelf ook een doen
  • Remy
  • Laatst online: 08-09 11:55
Remy
I usually get 100% accuracy
LinkedIn
Instagram
