Firmware Version 2.97 voor Edimax BR-6104K
BR-6104K Firmware Version : 2.97 is nu beschikbaar.
Download:
http://www.edimax.co.uk/download/firmware/BR-6104KV297.zip
Whats new
Release Note ( BR6104K )
update:
2.97 : 2004.06.17
Fixed:
It can’t ping gateway in dynamic IP mode.
It can’t connect to port 80 after use DMZ function.
Remove “PPTP pass through” in ALG, Fix client in WAN use port forwarding can’t connect when PPTP server in LAN.
Manual connect in PPPoE/PPTP/L2TP mode problem, when change the connection mode from continue to manual connect will cause the problem.
When NAT is enable, the PC form WAN and set the default route to our router can communicate with PC that inside the NAT.
PPPoE/PPTP/L2TP’s user name can type “#”.
Special application conflict with ALG.
Added:
L2TP and Telstra Big Pond in wizard.
Dit lijkt me meer iets voor de meuktracker op de Frontpage. Submitten kan hier.
[ Voor 28% gewijzigd door Verwijderd op 29-07-2004 00:26 ]
