die lijkt mij normaal te zijn...
tijdens het opstarten krijg ik ook geen fouten.
het begint pas na een paar minuten dat hij vagen dingen gaat doen
stukje uit me /var/log/messages
Jul 27 21:39:35 anke named[79741]: check_hints: A records for B.ROOT-SERVERS.NET class 1 do not match hint records
Jul 27 21:40:22 anke named[80043]: starting (/etc/namedb/named.conf). named 8.3.6-REL Mon Oct 27 14:55:35 GMT 2003 root@freebsd-stable.sentex.ca:/usr/obj/usr/src/usr.sbin/named
Jul 27 21:40:22 anke named[80043]: limit files set to fdlimit (1024)
Jul 27 21:40:22 anke named[80043]: ctl_server: bind: /var/run/ndc: Address already in use
Jul 27 21:40:22 anke named[80043]: bind(dfd=20, [80.69.68.216].53): Address already in use
Jul 27 21:40:22 anke named[80043]: deleting interface [80.69.68.216].53
Jul 27 21:40:22 anke named[80043]: bind(dfd=20, [80.69.68.219].53): Address already in use
Jul 27 21:40:22 anke named[80043]: deleting interface [80.69.68.219].53
Jul 27 21:40:22 anke named[80043]: bind(dfd=20, [127.0.0.1].53): Address already in use
Jul 27 21:40:22 anke named[80043]: deleting interface [127.0.0.1].53
Jul 27 21:40:22 anke named[80043]: not listening on any interfaces
Jul 27 21:40:22 anke named[80045]: Ready to answer queries.
Jul 27 21:40:22 anke named[80045]: check_hints: A records for B.ROOT-SERVERS.NET class 1 do not match hint records
Jul 27 21:40:32 anke named[79741]: starting (/etc/namedb/named.conf). named 8.3.6-REL Mon Oct 27 14:55:35 GMT 2003 root@freebsd-stable.sentex.ca:/usr/obj/usr/src/usr.sbin/named
Jul 27 21:40:32 anke named[79741]: bind(dfd=22, [80.69.68.219].53): Address already in use
Jul 27 21:40:32 anke named[79741]: deleting interface [80.69.68.219].53
Jul 27 21:40:32 anke named[80070]: Ready to answer queries.
Jul 27 21:40:32 anke named[80070]: check_hints: A records for b.root-servers.net class 1 do not match hint records
Jul 27 21:41:21 anke named[80462]: starting (/etc/namedb/named.conf). named 8.3.6-REL Mon Oct 27 14:55:35 GMT 2003 root@freebsd-stable.sentex.ca:/usr/obj/usr/src/usr.sbin/named
Jul 27 21:41:21 anke named[80462]: limit files set to fdlimit (1024)
Jul 27 21:41:21 anke named[80462]: ctl_server: bind: /var/run/ndc: Address already in use
Jul 27 21:41:21 anke named[80462]: bind(dfd=20, [80.69.68.216].53): Address already in use
Jul 27 21:41:21 anke named[80462]: deleting interface [80.69.68.216].53
Jul 27 21:41:21 anke named[80462]: bind(dfd=20, [80.69.68.219].53): Address already in use
Jul 27 21:41:21 anke named[80462]: deleting interface [80.69.68.219].53
Jul 27 21:41:21 anke named[80462]: bind(dfd=20, [127.0.0.1].53): Address already in use
Jul 27 21:41:21 anke named[80462]: deleting interface [127.0.0.1].53
Jul 27 21:41:21 anke named[80462]: not listening on any interfaces
Jul 27 21:41:21 anke named[80464]: Ready to answer queries.
Jul 27 21:41:21 anke named[80464]: check_hints: A records for B.ROOT-SERVERS.NET class 1 do not match hint records
Jul 27 21:41:31 anke named[80070]: starting (/etc/namedb/named.conf). named 8.3.6-REL Mon Oct 27 14:55:35 GMT 2003 root@freebsd-stable.sentex.ca:/usr/obj/usr/src/usr.sbin/named
Jul 27 21:41:31 anke named[80070]: bind(dfd=22, [80.69.68.219].53): Address already in use
Jul 27 21:41:31 anke named[80070]: deleting interface [80.69.68.219].53
Jul 27 21:41:31 anke named[80474]: Ready to answer queries.
Jul 27 21:41:31 anke named[80474]: check_hints: A records for B.ROOT-SERVERS.NET class 1 do not match hint records
hij zit in een of andere loop, dit is stukje van named die op het moment niet erg lief is... en killen heeft geen zin.. hij komt vanuit zijn eigen weer in de loop..
