DNS REFUSED ?
  • 50 views sinds 30-01-2008
Even een copy paste van wat ik elders ook al gepost heb..
Hi,
I have installed suse 9.1 on a sony notebook, and use a 3com (3crwe154972) pcmcia wlan card.
Problem is, I cannot browse the internet by url, only by ip.
some info:
laptop:~ # route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth1
link-local * 255.255.0.0 U 0 0 0 eth1
loopback * 255.0.0.0 U 0 0 0 lo
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
laptop:~ # ifconfig
eth1 Link encap:Ethernet HWaddr 00:0D:54:9C:45:18
inet addr:192.168.1.93 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::20d:54ff:fe9c:4518/64 Scope:Link
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1869 errors:0 dropped:0 overruns:0 frame:0
TX packets:2135 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:179442 (175.2 Kb) TX bytes:865595 (845.3 Kb)
Interrupt:9
laptop:~ # iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
eth1 IEEE 802.11b/g ESSID:"3Com" Nickname:"laptop"
Mode:Managed Channel:11 Access Point: 00:0D:54:9B:E8:2D
Bit Rate:24Mb/s Tx-Power=31 dBm Sensitivity=20/200
Retry min limit:8 RTS thr:2347 B Fragment thr:2346 B
Encryption key:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
sit0 no wireless extensions.
laptop:~ # ping www.google.com
ping: unknown host www.google.com
laptop:~ # ping 216.239.59.99
PING 216.239.59.99 (216.239.59.99) 56(84) bytes of data.
64 bytes from 216.239.59.99: icmp_seq=1 ttl=243 time=46.6 ms
64 bytes from 216.239.59.99: icmp_seq=2 ttl=243 time=39.2 ms
--- 216.239.59.99 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 39.218/42.938/46.659/3.726 ms
laptop:~ # dig www.google.com
; <<>> DiG 9.2.3 <<>> www.google.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 52735
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
url]www.google.com[/url]. IN A
;; Query time: 16 msec
;; SERVER: 195.96.96.33#53(195.96.96.33)
;; WHEN: Sat Jul 24 16:02:29 2004
;; MSG SIZE rcvd: 32
there
Now as you can see, I am getting a REFUSED on my dig query.
tried several nameservers.
Can anyone help ?
Zit je wel op het netwerk van Casema (want 195.96.96.33 is de sec. DNS van Casema)?
En zoniet, heb je op je laptop ingesteld dat deze OOK de DNS serverinstellingen op moet halen bij de DHCP server?
Verwijderd schreef op 24 juli 2004 @ 16:48:
Deze Casema nameservers gebruik ik al zolang ik al online zit, nooit problemen mee.
En ik snap niet helemaal wat je bedoeld met die tweede opmerking?
De gateway staat ook in mijn resolv.conf als je dat bedoeld.
[ Voor 8% gewijzigd door Verwijderd op 24-07-2004 16:55 ]
Gateway? we hebben het toch over een DNS server? In je resovl.conf staat waar je resolver terecht moet wanner hij een onbekende naam op moet vragen. Anyway, wat krijg je als antwoord als je doet:
dig www.google.com @195.96.96.97
[ Voor 27% gewijzigd door Verwijderd op 24-07-2004 16:57 ]
Verwijderd schreef op 24 juli 2004 @ 16:56:
De gateway is de DHCP server waar je naar vroeg.
laptop:~ # dig www.google.com @195.96.96.97
; <<>> DiG 9.2.3 <<>> www.google.com @195.96.96.97
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 39695
;www.google.com. IN A
;; SERVER: 195.96.96.97#53(195.96.96.97)
;; WHEN: Sat Jul 24 17:01:39 2004
[ Voor 38% gewijzigd door Verwijderd op 24-07-2004 17:02 ]
Dus de (default?)gateway is ook toevallig de DHCP server, en ook nog eens toevallig DNS server?
mmmm, snap ik niet.
Op welk netwerk zit je, welke provider?
[ Voor 16% gewijzigd door Verwijderd op 24-07-2004 17:03 ]
Op een of andere wazige manier pakt ie nu wel andere nameservers.
Mijn andere machines gebruiken wel gewoon de casema servers.
Raar, maargoed, het werkt nu blijkbaar :)
Dank je voor je hulp.
Verwijderd schreef op 24 juli 2004 @ 17:02:
mmmm, snap ik niet.
Het is niet de DNS server, maar wel hetgeen waar de instellingen vandaan gehaald worden door de laptop.
Probleem is dus opgelost?
Jij zit aan je IP-adres te zien achter een soho-routertje. Dat routertje is naar ik schat je DHCP server. Wanneer jij die dig zou richten aan 192.168.1.1 krijg je schat ik zo ook gewoon antwoord.
Dat is dus eigenlijk je DNS server (caching only). Deze zal het op zijn beurt vragen bij de DNS server van je provider. Maar je hebt nog steeds niet gezegd wie je provider is.
[ Voor 90% gewijzigd door Verwijderd op 24-07-2004 17:13 ]
Zie twee post hoger ;)
Verwijderd schreef op 24 juli 2004 @ 17:12:
ik zit op een 3com router, en mijn ISP is Planet.
ik moet eens leren lezen, en niet op de quote button te drukken als ik wil editten O-)
Als je bij Planet zit, dan ben je toch niet verbaasd wanneer de DNS server van Casema je (af en toe) weigert? Wat mankeert er aan de DNS servers van Planet?
Verwijderd schreef op 24 juli 2004 @ 17:25:
Zoals ik al zei, ik heb altijd die DNS gebruikt, nummer zat in mijn hoofd.
En nog nooit problemen mee gehad.
Andere machines hier draaien nog steeds op Casema, en die doen het gewoon.
  • Wilke
  • Laatst online: 22:58
Gathering of Tweakers is een nederlandstalig forum. Dat je crosspost over meerdere forums vind ik nog tot daar aan toe, maar het mag hier dan ten minste wel gewoon in het Nederlands, dit komt wel heel erg lui over.
Verder bestaat je topictitel alleen uit op een irritante manier de aandacht vragende hoofdletters, terwijl dit volkomen onnodig is.
Deze twee redenen samen zijn voor mij aanleiding dit topic te sluiten.
