[Debian] Apt-get install apache gemold
  • Mujo
  • Laatst online: 23-08-2021
Mujo
Nee hè?
Heren (en dames?),
Vanaf m'n fresh geïnstalleerde Debian (woody) doos
heb ik (per ongeluk)
"apt-get install apache" onderbroken.
Nu wil apt-get helemaal niet meer verder.
Verschillende dingen heb ik geprobeerd met apt-get (remove, upgrade,
update, clean, you name it), maar hij lijkt vast te
zitten bij de package "libexpat1".
Hieronder wat output:
DreamWorld:/FILES# apt-get install apache
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  apache: Depends: libexpat1 (>= 1.95.2-6) but it is not installable
          Depends: apache-common (>= 1.3.26-0) but it is not going to be installed
          Depends: apache-common (< 1.3.27-0) but it is not going to be installed
E: Sorry, broken packages
DreamWorld:/FILES#
Dacht dat het dus aan libexpat1 lag, want daar had ik het proces toen per
ongeluk gekilled (package broken):
DreamWorld:/FILES# apt-get remove libexpat1
Package libexpat1 is not installed, so not removed
0 packages upgraded, 0 newly installed, 0 to remove and 0  not upgraded.
DreamWorld:/FILES#
Grrr. Packages zijn niet geïnstalleerd dus removen lukt ook niet.
Waarom blijft apt-get dan zeuren om Broken packages? :?
DreamWorld:/FILES# dpkg --remove libexpat1
dpkg - warning: ignoring request to remove libexpat1 which isn't installed.
DreamWorld:/FILES# dpkg --remove apache-common
dpkg - warning: ignoring request to remove apache-common which isn't installed.
DreamWorld:/FILES#
Hulp gezocht dus, bij het het oplossen van dit probleem.
Gelieve niet te roken in mijn kantoorkamer!
Ik ben meer verslaafd aan sex, dan jij aan roken, maar je ziet mij toch ook niet neuken op kantoor?
  • Creepy
  • Laatst online: 00:45
Creepy
Tactical Espionage Splatterer
En een apt-get -f install gevolgd door een apt-get install apache?
En eventueel een apt-get install libexpat1, aangezien apache libexpat1 nodig heeft en deze niet installeerbaar lijkt.
Je hebt niet extra sources toegevoegd aan je sources.list?
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
  • Mujo
Mujo
Nee hè?
DreamWorld:~# apt-get -f install
DreamWorld:~# apt-get install libexpat1
Package libexpat1 has no available version, but exists in the database.
This typically means that the package was mentioned in a dependency and
never uploaded, has been obsoleted or is not available with the contents
of sources.list
E: Package libexpat1 has no installation candidate
"has no installation candidate" wat dat ook zijn moge...
Aan de sources list heb ik maar 1 source toegevoegd, omdat ik die
nodig had voor m'n firewall-packages.
/etc/apt/sources.list:
deb http://security.debian.org/ stable/updates main
deb ftp://ftp.wallaby.be/debian/ ./
Moet het niet aan liggen dunkt me.
[ Voor 4% gewijzigd door Mujo op 22-07-2004 20:54 ]
  • Mujo
Mujo
Nee hè?
/edit: per ongeluk vorige bericht gequote
[ Voor 100% gewijzigd door Mujo op 22-07-2004 20:54 ]
  • Creepy
Creepy
Mujo schreef op 22 juli 2004 @ 20:53:
Als dit heel je sources.list is, dan heb je ALLEEN maar de debian updates te pakken, en mist de normale Debian repository.
Onderstaande toevoegen lost waarschijnlijk je probleem op.
deb http://ftp.debian.nl/debian/ stable main contrib non-free
  • Mujo
Mujo
Nee hè?
sources.list: 3 lines, 150 characters.
DreamWorld:/etc/apt# apt-get update
Get:1 http://ftp.debian.nl stable/main Packages [1774kB]
Hit http://security.debian.org stable/updates/main Packages
Hit http://security.debian.org stable/updates/main Release
Hit ftp://ftp.wallaby.be ./ Packages
Hit ftp://ftp.wallaby.be ./ Release
Get:2 http://ftp.debian.nl stable/main Release [95B]
Get:3 http://ftp.debian.nl stable/contrib Packages [49.2kB]
Get:4 http://ftp.debian.nl stable/contrib Release [98B]
Get:5 http://ftp.debian.nl stable/non-free Packages [65.3kB]
Get:6 http://ftp.debian.nl stable/non-free Release [99B]
Fetched 1889kB in 12s (152kB/s)
DreamWorld:/etc/apt# apt-get -f install apache
The following extra packages will be installed:
  apache-common libexpat1
The following NEW packages will be installed:
  apache apache-common libexpat1
0 packages upgraded, 3 newly installed, 0 to remove and 0  not upgraded.
Need to get 1226kB of archives. After unpacking 3781kB will be used.
Do you want to continue? [Y/n]
U zij de glorie! ;)
Stom, een Debian install manual van een paar maanden geleden vertelde
me ook dat ik eerst wat extra sources toe had moeten voegen. Bedankt!
[ Voor 17% gewijzigd door Mujo op 22-07-2004 21:15 ]
