[acpi] throttling
  • technocow
  • Laatst online: 22-10 17:15
hallo,
op mijn laptop (MD9580A / asus L8400) heb ik debian unstable draaien met een 2.6.7 kernel.
De CPU is een intel mobile pIII 1ghz
na wat gespeel en geklooi met de kernel heb ik mijn acpi goed draaien alleen iets TE goed :( als ik kde opgestart heb gaat hij direct throttelen van T0 naar T7
hij pakt dus geen tussen stand :?
cat /proc/acpi/processor/CPU0/throttling
state count:             8
active state:            T7
states:
    T0:                  00%
    T1:                  12%
    T2:                  25%
    T3:                  37%
    T4:                  50%
    T5:                  62%
    T6:                  75%
   *T7:                  87%
dmesg|grep ACPI
29
30
31
32
33
34
35
36
 BIOS-e820: 000000000fff0000 - 000000000ffffc00 (ACPI data)
 BIOS-e820: 000000000ffffc00 - 0000000010000000 (ACPI NVS)
ACPI: RSDP (v000 PTLTD                                     ) @ 0x000f7040
ACPI: RSDT (v001 PTLTD    RSDT   0x06040001  LTP 0x00000000) @ 0x0fffc800
ACPI: FADT (v001 ASUS   L8400B   0x06040001 PTL  0x000f4240) @ 0x0ffffb65
ACPI: BOOT (v001 PTLTD  $SBFTBL$ 0x06040001  LTP 0x00000001) @ 0x0ffffbd9
ACPI: DSDT (v001  Intel   Trajan 0x06040001 MSFT 0x01000004) @ 0x00000000
ACPI: PM-Timer IO Port: 0x8008
ACPI: Subsystem revision 20040326
ACPI: IRQ9 SCI: Level Trigger.
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs *9)
ACPI: PCI Interrupt Link [LNKB] (IRQs 9) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 5 6 7 *10)
ACPI: PCI Interrupt Link [LNKD] (IRQs *9)
ACPI: PCI Root Bridge [PCI0] (00:00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Embedded Controller [EC0] (gpe 9)
ACPI: Power Resource [PFAN] (off)
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
PCI: Using ACPI for IRQ routing
acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.4
ACPI: AC Adapter [AC] (on-line)
ACPI: Battery Slot [BAT0] (battery present)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
ACPI: Fan [FAN] (off)
ACPI: Processor [CPU0] (supports C1 C2, 8 throttling states)
ACPI: Thermal Zone [THRM] (36 C)
Asus Laptop ACPI Extras version 0.28
ACPI: (supports S0 S1 S3 S4 S5)
wat kan het probleem zijn :? :?
  • AlterEgo
Da's niet goed, als het klopt: die laptop moet lopen als een slak bij T7. Als ie normaal loopt, kan het een lees/acpi/whatever fout zijn.
Test eens wat er gebeurt als je handmatig de throttling aanpast:
echo <waarde> > /proc/acpi/processor/cpu1/throttling
Alternatief: kijk eens of je een acpid hebt draaien met een foute configuratie-optie.
Ik vraag me trouwens af of acpi-throttling wel stroom spaart: ik heb nooit gezien dat een processor koeler wordt door trhottling, het vergroot vooral latency.
[ Voor 15% gewijzigd door AlterEgo op 20-07-2004 19:32 ]
  • technocow
AlterEgo schreef op 20 juli 2004 @ 19:30:
het probleem is dat dat hij direct UBER traag word ... dus de throtteling werkt wel :)
en dat met echoen naar /proc wist ik al en dat werkt ook wel maar om nou iedere keer dat te doen....
de cpu blijft dan rond de 40 graden als hij op T7 staat terwijl als ik hem op T0 zet hij rond de 62~65 zit (bij 65 gaat hij coolen tot 40 graden)
dus het probleem is dat hij geen tussen stappen neemt maar meteen de processor min of meer "uit" gooit :(
ongeveer alles uit de apt-list met acpi is geinstalleerd en acpid ook :) ik heb er ook al aardig op gegoogled maar dat leverde niets op..
iemand die ik ken met een ander type laptop heeft hetzelfde probleem
[ Voor 12% gewijzigd door technocow op 20-07-2004 21:31 ]
  • XTerm
  • Laatst online: 10-06-2025
Wat ik bij mijn Asus heb gedaan en ubercool is is hetvolgende :
Je zet alle automatische throtteling af, en bij het opstarten kijk je via script of je op net of op batterij werkt. Op basis daarvan ga naar T0 ofT4 ofzo.
Verder hebik op mijn sleurdoos controleknopjes voor CD's af te spelen. Skip forward verhoogt mijn CPU snleheid en skip backward verlaagt ze. Werkt beestig leuk :)
  • decramy
  • Laatst online: 01-11 10:36
decramy
root@birdie:~#
/me zwaait naar technocow :w
20*375Wp met Enphase IQ7+ micro's | Stiebel Eltron HGE Water/Water WP 9kW | Tesla M3, powered by SmartEVSE | Servertje @ www.coloclue.net
