[XP] Pc reboot bij gebruik bittorent
Sorry voor het onduidelijke topic van daarnet.
Als ik met bittorent iets download reboot me pc na een tijdje.
Ik heb dat opnieuwstarten bij fout uitgevinkt.
Wat ik ervoor terug kreeg was een blauwscherm met de melding:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
feand5.sys sys-adress f9ce36c7 base at f9ce1000 Datestamp 2a2b3a10.
Dit staat in het logboek:
Foutcode; 000000d1, parameter1: 00000002, parameter2: 00000002, parameter3: 00000000, parameter4: f9ce36c7.
Toen ik fouten rapport weergeven aanvinkte ging windows naar een pagina waar staat dat het door mijn graphics driver komt.
Error Caused by Graphics Device Driver
Thank you for submitting an error report. Unfortunately, we cannot provide you with specific information about how to resolve this problem at this time. The information that you and other users submit will be used to investigate this problem.
Analysis
A device driver installed on your system caused the problem, but we cannot determine the precise cause.
Getting Help
Depending on which situation is applicable to you, do one of the following:
If you are running Windows Server 2003 you may experience crashes if you have adjusted the Hardware Acceleration setting. Microsoft recommends that the Hardware Acceleration setting be set to None for server systems. To check your Hardware Acceleration setting, go to the advanced section of the display properties dialog box.
If you know the manufacturer of the device, contact the manufacturer's product support service for assistance.
If you don't know the driver's manufacturer and need help diagnosing and resolving this problem, contact your computer manufacturer's product support service.
Updated drivers might be available on the Microsoft Windows Update Web site. At Windows Update, you can have your computer scanned and, if there are updated drivers available, Windows Update will offer a selection of drivers that you might be able to use. To learn more about updated drivers that might be available, visit Microsoft Windows Update.
For information about Microsoft support options, visit Microsoft Product Support Services.
You can track this error report by clicking the Track this error report link. If you choose to track your error report, you will be notified of resolutions to this problem as they are identified.
Ik snap er de ballen van, ik vind het heel raar.
Mijn systeem:
Windows xp sp 1
40 gb hd
mobo: ehm weenie ><
256mb ram
Geforce 2 mx 400
[ Voor 3% gewijzigd door Verwijderd op 18-07-2004 23:10 ]
  • Dr Pro
  • Laatst online: 29-08 22:11
gokje...ATI kaart? hier heb ik ook last van :'( , maar dan niet met bitorrent. soms gewoon na het afsluiten van een browser.
heb jij dit btw, alleen met bittorrent? --> al een andere client geprobeert?
Ik heb een geforce 2 mx(vergeten erbij te zetten)
  • iets
  • Laatst online: 09:05
Andere videokaart driver?
tvw
maakt nix uit had et vroeger ook en heb nu de nieuwste eropstaan
  • Raku
  • Laatst online: 23-09-2022
Raku
Mental Aid
Raku
thnx verklaard het wel een beetje ik opende et topic omdat ik verschillende foutmeldingen bij elkaar kreeg.
