[apt-get] geeft allemaal foutmeldingen..
  • Sa1
  • Laatst online: 07:40
Gisteren heb ik een aantal zaken geinstalleerd via apt-get, allemaal vlekkeloos verloopen tot op een gegeven moment.. toen kreeg ik dit:
root@server-01:/home/saib# apt-get install bind
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
  bind9: Depends: libdns11 (= 1:9.2.3+9.2.4-rc2-1) but 1:9.2.3+9.2.4-rc5-1 is to be installed
         Depends: libisccfg0 (= 1:9.2.3+9.2.4-rc2-1) but 1:9.2.3+9.2.4-rc5-1 is to be installed
         Depends: libisc7 (= 1:9.2.3+9.2.4-rc2-1) but 1:9.2.3+9.2.4-rc5-1 is to be installed
         Depends: libisccc0 (= 1:9.2.3+9.2.4-rc2-1) but 1:9.2.3+9.2.4-rc5-1 is to be installed
         Conflicts: bind but 1:8.4.4-1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
dus tjah.. dan denk je .. apt-get -f install
dan komt het volgende:
root@server-01:/home/saib# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  bind9
The following packages will be upgraded:
  bind9
1 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
40 not fully installed or removed.
Need to get 0B/266kB of archives.
After unpacking 0B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 26516 files and directories currently installed.)
Preparing to replace bind9 1:9.2.3+9.2.4-rc2-1 (using .../bind9_1%3a9.2.3+9.2.4-rc5-1_i386.deb) ...
Stopping DNS Server: Bind9.2.4.rc2invoke-rc.d: initscript bind9, action "stop" failed.
dpkg: warning - old pre-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/bind9_1%3a9.2.3+9.2.4-rc5-1_i386.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
Starting DNS Server: Bind9.2.4.rc2.
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
ik weet me geen raad meer, ik heb op got al een paar topics gezien die het ook hadden, maar die hebben debian opnieuw geinstalleerd... het lijkt me niet echt nodig maar .. wil het liever dus ook niet doen..
debian 3.0r2 op kernel 2.4.26 .. bind werkt nog wel perfect..
ps, ook wanneer ik bind handmatig stop, blijf ik de foutmeldingen houden., dit omdat ie "stop failed" zegt.
[ Voor 4% gewijzigd door Sa1 op 17-07-2004 20:18 ]
Niet echt een oplossing, maar wat ik soms doe is een pakket helemaal verwijderen en dan weer installeren. Misschien werkt dat.
  • Rac-On
je bind install is brak, waardoor ie niet goed op het stop commando reageerd.
Probeer:
killall -9 bind
apt-get remove bind
apt-get update
Wat liquidos zegt dus eigenlijk.
[ Voor 56% gewijzigd door Rac-On op 17-07-2004 22:40 . Reden: niet goed gelezen ]
doet niet aan icons, usertitels of signatures
  • Sa1
rac-on schreef op 17 juli 2004 @ 22:35:
Probeer:
killall -9 bind
apt-get remove bind
apt-get update
kijk, dit is nu net het probleem.. hij doet echt nix..
root@server-01:/home/saib# apt-get remove bind
Package bind is not installed, so not removed
na killall -9 named (bind heeft geen processen, named is de process van bind zeg maar).
  • terabyte
  • Laatst online: 28-06 12:53
terabyte
kan denken als een computer
post je /etc/apt/sources.list eens.
en de output van apt-cache policy bind9
  • Creepy
  • Laatst online: 00:45
Creepy
Tactical Espionage Splatterer
Note: bind en bind9 zijn twee verschilende pakketten ;)
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
  • blaataaps
"bind" deinstallen gaat niet werken als de package "bind9" heet lijkt mij.
wat creepy dus net zegt :)
[ Voor 22% gewijzigd door blaataaps op 18-07-2004 00:36 ]
  • Sa1
terabyte schreef op 18 juli 2004 @ 00:33:
Sources.list:
deb ftp://ftp.debian.nl/debian/ testing main
deb-src ftp://ftp.debian.nl/debian/ testing main
deb http://security.debian.org/ stable/updates main
en apt-ache policy bind9:
bind9:
  Installed: 1:9.2.3+9.2.4-rc2-1
  Candidate: 1:9.2.3+9.2.4-rc5-1
  Version Table:
     1:9.2.3+9.2.4-rc5-1 0
        500 ftp://ftp.debian.nl testing/main Packages
 *** 1:9.2.3+9.2.4-rc2-1 0
        100 /var/lib/dpkg/status
     1:9.2.1-2.woody.1 0
        500 http://security.debian.org stable/updates/main Packages
Creepy schreef op 18 juli 2004 @ 00:35:
Ik snap waar je op doelt, maar ook apt-get remove bind9 werkt niet.. komt ie met dezelfde errors..
[ Voor 15% gewijzigd door Sa1 op 18-07-2004 14:01 ]
  • Warbringer
  • Laatst online: 08:11
İk zit momenteel in turkije dus ik kan het niet op mijn bak thius testen maar er was toch ook een mogelijkheid tot purgen van pakketten ? of in ieder geval.. van half geinstalleerde paketten?
I want to live forever, so far.. so good.
  • siknu
  • Laatst online: 26-06 23:14
dpkg --get-selections
Kan je even je geinstalleerde packages doorzoeken naar de juiste.
dpkg --purge <package>
lees anders ook even dit door:
http://panic.et.tudelft.n...dleiding/debian22hdl.html
5.7.2 Pakketjes installeren en verwijderen
[ Voor 85% gewijzigd door siknu op 18-07-2004 15:13 ]
  • Sa1
siknu schreef op 18 juli 2004 @ 15:10:
dpkg --purge bind9 werkt ook niet, hij geeft wederom de melding dat bind niet gestopt kant worden (der stond ook nog een ander packetje die wel weg kon, die werd perfect verwijderd).
foutmelding:
root@server-01:/etc/bind# dpkg --purge bind9
(Reading database ... 26515 files and directories currently installed.)
Removing bind9 ...
Stopping DNS Server: Bind9invoke-rc.d: initscript bind9, action "stop" failed.
dpkg: error processing bind9 (--purge):
 subprocess pre-removal script returned error exit status 1
 bind9
Als ik handmatig bind stop, dus /etc/init.d/bind9 stop doe, blijft dus named ook gewoon draaien..
vrij strange...
bind9 start ding is gemaakt uit het skeleton ding.. misschien staat dat niet goed..
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/usr/sbin/named
NAME=Bind9
DESC="DNS Server"
en het stop ding van de skeleton:
  stop)
        echo -n "Stopping $DESC: $NAME"
        start-stop-daemon --stop --quiet --pidfile $PIDFILE \
                --exec $DAEMON
        echo "."
[ Voor 45% gewijzigd door Sa1 op 18-07-2004 16:33 ]
  • terabyte
terabyte
Sa1 schreef op 18 juli 2004 @ 16:30:
Mja. Anders moet je een hele dirty hack uitvoeren en dat is exit 0 aan de bovenkant van /etc/init.d/bind9 zetten...
  • Sa1
terabyte schreef op 18 juli 2004 @ 17:45:
ha..
dat idd in /etc/init.d/bind9 gekletst, dpkg --purge bind9, apt-get install bind9 en draaien weer
tnx..
