Ik heb al rond gezocht hier op GOT maar kon er niets over vinden.
Heb de IDE kabels al omgewisseld maar mocht ook niet helpen
Ik heb net deze pc in elkaar gezet en het branden op de DVD brander en op de CD brander werkt niet meer..
DVD brander: NEC ND 2500
CD brander: Lite-on 52X32X52
PC specs:
Mainboard AMD ABIT NF7-S NFORCE2
512 DDR 400
HD 120 GB Serial ATA
ATI Radeon 9600 XT
HDF 80 GB seagate Baracuda ATA 7200
WIN XP PRO Corporate edition.
Dit zegt Nero ervan:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23-12-1997 3:23:24
ahead WinASPI: File 'C:\PROGRA~1\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17-6-2003 16:25:04
Nero version: 6.0.0.15
Recorder: <LITE-ON LTR-52327S> Version: QS03 - HA 1 TA 0 - 6.0.0.15
Adapter driver: <nvidesm> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 2 TA 0 - 6.0.0.15
Adapter driver: <d346prt> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120M0 YAR5 si3112r Port 0 ID 0 DMA: Off
CdRomPeripheral : LITE-ON LTR-52327S QS03 nvidesm Port 1 ID 0 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-2500A 1.06 nvidesm Port 1 ID 1 DMA: Off
DiskPeripheral : ST380021A 3.19 nvidesm Port 1 ID 1 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d346prt Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d346prt Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON LTR-52327S D: CDRom0
Generic DVD-ROM H: CDRom2
Generic DVD-ROM I: CDRom3
_NEC DVD_RW ND-2500A E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 204MB (209620kB)
Memory in use : 59 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.7.2004
CD-ROM (ISO)
12:49:58 #1 Text 0 File Isodoc.cpp, Line 5878
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:49:58 #2 Phase 90 File dlgbrnst.cpp, Line 1843
Buffer Underrun Protection activated
12:49:58 #3 Text 0 File Reader.cpp, Line 118
Reader running
12:49:58 #4 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-52327S running
12:49:58 #5 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
12:49:58 #6 Text 0 File Burncd.cpp, Line 3169
Turn on Disc-at-once, using CD-R/RW media
12:49:59 #7 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 293343 (65:13.18)
12:49:59 #8 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
12:49:59 #9 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: LITE-ON LTR-52327S;
CDRW code: 00 97 26 65; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: B3 00 CE, 2: 61 1A 41 (LI 97:26.65), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 24 1A BC, 2: 26 B2 26, 3: 00 80 80 (invalid)
12:49:59 #10 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
12:49:59 #11 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 293344 (293344) = #293344/65:11.19
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 293344 blocks [LITE-ON LTR-52327S ]
12:49:59 #12 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [LITE-ON LTR-52327S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 601075712, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
293344 | lead-out | 1 | 0x00 | 0x41
12:49:59 #13 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
12:50:00 #14 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
12:50:00 #15 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 12x (1.800 KB/s)
12:50:00 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:50:00 #17 Text 0 File Mmc.cpp, Line 14512
StartDAO : CD-Text - Off
12:50:00 #18 Text 0 File Mmc.cpp, Line 19000
Set BUFE: supported -> ON , SMART-BURN : ON
12:50:00 #19 Text 0 File Mmc.cpp, Line 14832
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 41 0d 13
12:50:28 #20 SCSI -500 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04260000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
12:50:28 #21 Text 0 File Writer.cpp, Line 455
12:50:28.671 LITE-ON LTR-52327S : WriteBuffer reduced to 32768 Bytes
12:50:28 #22 Text 0 File Writer.cpp, Line 318
12:50:28.703 - LITE-ON LTR-52327S : Queue again later (Intervall : 36msec)
12:50:37 #23 SCSI -1076 File Cdrdrv.cpp, Line 1411
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x28
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x28 0x00
12:50:37 #24 CDR -1076 File Writer.cpp, Line 335
Disc changed
12:50:37 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:50:37 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:50:37 #27 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
12:50:37 #28 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 12x (1.800 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23-12-1997 4:02:46
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0307 built by: WinDDK, size=20224 bytes, created 13-11-2002 9:10:00 (Adapter driver for rec)
File 'Drivers\d346prt.sys': Ver=3.46.0.0 built by: WinDDK, size=5248 bytes, created 12-3-2004 23:41:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
PC specs:
512 DDR 400
ATI Radeon 9600 XT
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
15.7.2004
CD-ROM (ISO)
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
ATIP Data:
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
CueData, Len=32
Sense Code: 0x26
Sense Qual: 0x02
Sense Code: 0x28
Sense Qual: 0x00
Disc changed
Existing drivers:
Registry Keys:
respect tha DON Don's SPECS
