itcl op Slackware 10
  • 52 views sinds 30-01-2008
Ik probeer itcl te installeren omdat ik Open Sound World wil installeren en daar is itcl voor nodig, maar het lukt me maar niet.
Ik heb de laatste versie van itcl gedownload, uitgepakt, toen ./configure --with-tcl=/usr/lib --with-tk=/usr/lib, daarna doe ik `make all` en dan krijg ik het volgende:
for dir in itcl itk ; do \
if test -d $dir ; then \
echo "$dir: make all" ;\
if (cd $dir; make all) ; then true ; else exit 1 ; fi ; \
else \
exit 1; \
fi \
done;
itcl: make all
make[1]: Entering directory `/home/senorsnor/packages/itcl3.2.1/itcl'
cc -DVERSION=\"3.2\" -DUSE_TCL_STUBS=1 -DITCL_LIBRARY=\"/usr/local/lib/itcl3.2\" -I/tmp/tcl8.4.6/generic -I/tmp/tcl8.4.6/unix -I"./generic" -I"./unix" -O -D__NO_STRING_INLINES -D__NO_MATH_INLINES -fPIC -c `echo ./generic/itclStubInit.c` -o itclStubInit.o
make[1]: Leaving directory `/home/senorsnor/packages/itcl3.2.1/itcl'
:53:20: tclInt.h: No such file or directory
In file included from generic/itclStubInit.c:14:
generic/itclInt.h:135: error: parse error before "Var"
generic/itclInt.h:135: warning: no semicolon at end of struct or union
generic/itclInt.h:138: error: parse error before '}' token
generic/itclInt.h:138: warning: data definition has no type or storage class
generic/itclInt.h:147: error: parse error before "CompiledLocal"
generic/itclInt.h:147: warning: no semicolon at end of struct or union
generic/itclInt.h:149: error: parse error before '*' token
generic/itclInt.h:149: warning: data definition has no type or storage class
generic/itclInt.h:158: error: parse error before '}' token
generic/itclInt.h:158: warning: data definition has no type or storage class
generic/itclInt.h:170: error: parse error before "ItclMemberCode"
generic/itclInt.h:170: warning: no semicolon at end of struct or union
generic/itclInt.h:171: warning: data definition has no type or storage class
<<nog een hele hoop vergelijkbare foutmeldingen>>
generic/itclInt.h:238: warning: data definition has no type or storage class
generic/itclInt.h:239: error: parse error before '}' token
generic/itclInt.h:239: warning: data definition has no type or storage class
In file included from generic/itclInt.h:249,
generic/itclIntDecls.h:41: error: parse error before "ItclObject"
generic/itclIntDecls.h:46: error: parse error before '*' token
generic/itclIntDecls.h:54: error: parse error before '*' token
generic/itclIntDecls.h:57: error: parse error before '*' token
generic/itclIntDecls.h:79: error: parse error before "ItclMember"
generic/itclIntDecls.h:85: error: parse error before "ItclContext"
generic/itclIntDecls.h:88: error: parse error before "ItclObject"
generic/itclIntDecls.h:162: error: parse error before "Tcl_ResolvedVarInfo"
generic/itclIntDecls.h:170: error: parse error before "ItclVarDefn"
generic/itclIntDecls.h:174: error: parse error before '*' token
generic/itclIntDecls.h:179: error: parse error before '*' token
generic/itclIntDecls.h:179: warning: data definition has no type or storage class
generic/itclIntDecls.h:182: error: parse error before '*' token
generic/itclIntDecls.h:184: error: parse error before "ItclObject"
generic/itclIntDecls.h:574: error: parse error before '*' token
generic/itclIntDecls.h:574: warning: data definition has no type or storage class
generic/itclStubInit.c:29: error: parse error before "itclIntStubs"
generic/itclStubInit.c:31: warning: excess elements in scalar initializer
generic/itclStubInit.c:31: warning: (near initialization for `itclIntStubs')
generic/itclStubInit.c:32: warning: excess elements in scalar initializer
generic/itclStubInit.c:32: warning: (near initialization for `itclIntStubs')
generic/itclStubInit.c:33: warning: excess elements in scalar initializer
generic/itclStubInit.c:147: warning: excess elements in scalar initializer
generic/itclStubInit.c:147: warning: (near initialization for `itclIntStubs')
generic/itclStubInit.c:148: warning: data definition has no type or storage class
generic/itclStubInit.c:152: warning: initialization from incompatible pointer type
make[1]: *** [itclStubInit.o] Error 1
make: *** [all] Error 1
Iemand een idee?? Want ik kom er niet uit...
  • Wilke
Je hebt waarschijnlijk de tcl/tk development packages niet geinstalleerd.
[ Voor 5% gewijzigd door Wilke op 09-07-2004 15:08 ]
nevermind, heb source van tcl gedownload en daar de missende header-files uitgeplukt; dat werkte :-)
  • Wilke
De juiste development packages installeren zal ook wel helpen zoals ook te lezen is in de NOS FAQ: Ik probeer een programma zelf te compileren, maar hij kan sommige libraries niet vinden?.
Dat was het blijkbaar inderdaad, dus dan kan dit topic ook wel dicht aangezien dit in de FAQ al uitgelegd wordt.
