CRC errors bij verschillende bestanden
  • 118 views sinds 30-01-2008
ok mensen.. dit was mijn probleem...;
1e keer
1 flt-cbun.001: Packed data CRC failed in flt-undie.bin. The volume is corrupt *
2 flt-cbun.016: Packed data CRC failed in flt-undie.bin. The volume is corrupt *
3 flt-cbun.018: Packed data CRC failed in flt-undie.bin. The volume is corrupt *
4 flt-cbun.019: Packed data CRC failed in flt-undie.bin. The volume is corrupt
5 flt-cbun.027: Packed data CRC failed in flt-undie.bin. The volume is corrupt
6 flt-cbun.041: Packed data CRC failed in flt-undie.bin. The volume is corrupt
7 CRC failed in flt-undie.bin. The file is corrupt
2e keer
1 flt-cbun.007: Packed data CRC failed in flt-undie.bin. The volume is corrupt
2 flt-cbun.009: Packed data CRC failed in flt-undie.bin. The volume is corrupt
3 flt-cbun.022: Packed data CRC failed in flt-undie.bin. The volume is corrupt
4 flt-cbun.024: Packed data CRC failed in flt-undie.bin. The volume is corrupt
5 flt-cbun.037: Packed data CRC failed in flt-undie.bin. The volume is corrupt
6 flt-cbun.039: Packed data CRC failed in flt-undie.bin. The volume is corrupt
3e keer
1 flt-cbun.015: Packed data CRC failed in flt-undie.bin. The volume is corrupt
2 flt-cbun.029: Packed data CRC failed in flt-undie.bin. The volume is corrupt
3 CRC failed in flt-undie.bin. The file is corrupt
4e keer
1 flt-cbun.011: Packed data CRC failed in flt-undie.bin. The volume is corrupt
2 flt-cbun.014: Packed data CRC failed in flt-undie.bin. The volume is corrupt
3 flt-cbun.015: Packed data CRC failed in flt-undie.bin. The volume is corrupt
4 flt-cbun.027: Packed data CRC failed in flt-undie.bin. The volume is corrupt
5 flt-cbun.029: Packed data CRC failed in flt-undie.bin. The volume is corrupt
6 CRC failed in flt-undie.bin. The file is corrupt
5e keer
1 flt-cbun.005: Packed data CRC failed in flt-undie.bin. The volume is corrupt
2 flt-cbun.020: Packed data CRC failed in flt-undie.bin. The volume is corrupt
4 flt-cbun.035: Packed data CRC failed in flt-undie.bin. The volume is corrupt
5 CRC failed in flt-undie.bin. The file is corrupt
bij elke check hadden andere file's crc error..
wat heb ik toen gedaan...
ik heb 2 pc's.. op allebei de pc's dezelfde bestanden vanaf dezelfde source gedownload...
op 1 pc was alles ok,, de andere niet.. dus daaraan kon ik aan zien dat het i.i.g niet aan de inet connectie en aan de modem lag...
netwerk kaart vervangen... -nog steeds error's
utp kabel vervangen -nog steeds error's
geheugen vervangen -nog steeds error's
win xp opnieuw geinstalleerd -nog steeds error's
vervolgens ;omdat ik 6 schijven in me server heb zitten, waarvan 1 systeem schijf , 4 in een striped raid, en 1 ide schijf, de zelfde filez op alle schijven gedownload, en op iederre schijf de bestanden uitgepakt...
ik kwam tot de conclusie dat op de raid schijven crc error's voorkwamen, en op de systeem schijf, en de andere losse schijf de filez wel normaal (zonder crc error's) uitgepakt konden worden...
ik heb hierna nog een update van de raid gedaan, maar de filez waren nog steeds corrupt..
nu ben ik dus genoodzaakt om me striped raid met 4 x 120 gb compleet te
formatteren en hoop hiermee dan van dit vreemd verschijnsel verlost te zijn hehehehe.
voordat ik dit ga doen, wacht ik nog eventuele reacties af.. misschien isser nog wel een andere oplossing.....
umh.... ik zou zo niet de oplossing weten.
Maar vind je niet dat je overdreven veel doet om het op te lossen? terwijl je hem nu al kan uitpakken op je pc. (Kan aan mij liggen hoor)
  • Janoz
  • Laatst online: 30-10 09:22
Janoz
Moderator Devschuur®
!litemod
Nou, het ziet er duidelijk naar uit dat de raid opstelling fouten veroorzaakt. Dat lijkt me een groter probleem dan een download die het niet doet ;).
quote; Maar vind je niet dat je overdreven veel doet om het op te lossen? terwijl je hem nu al kan uitpakken op je pc. (Kan aan mij liggen hoor)
ik kan nu alleen maar op de losse ide schijf uitpakken,, en kan verder niks met de hele raid doen, want alles is dan toch corrupt daarna...
  • H!GHGuY
H!GHGuY
Try and take over the world...
check voeding/ide kabeltjes voltagelijnen enz
check met een tooltje je SMART waarden, misschien zit er 1 rotte schijf tussen.
welke overige hardware bevind er zich in je systeem??? types HD, RAID controller...
check ook je RAM!! memtest86 bvb
[ Voor 8% gewijzigd door H!GHGuY op 08-07-2004 21:00 ]
ASSUME makes an ASS out of U and ME
Als je in windows een schijfcontrole uitvoert, wat is het resultaat? Bakken vol met errors?
Overigens.. het is 'files' niet 'filez'..
@rafe: excuses, het ging mij niet eens over de topictitel.. ik stel hierboven een serieuze vraag in een poging te helpen, en geef daarbij gelijk aan dat 'filez' niet echt klopt.
@Xint: 'files' is een op GoT geaccepteerd woord, 'filez' niet.
[ Voor 54% gewijzigd door Verwijderd op 08-07-2004 21:48 ]
  • Xlnt
  • Laatst online: 04-10 21:56
Verwijderd schreef op 08 juli 2004 @ 21:03:
Het is 'bestanden', niet 'files' noch 'filez'.
"It's not that I'm lazy. It's that I just don't care."
  • Rafe
  • Laatst online: 27-06-2025
En we zitten op GoT, waar we een topic report functie (Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/icons/icon_hand.gif-knop) hebben om fouten in de topictitel te melden. Volgende keer even doen graag, ipv zoiets in het topic te melden.
Topictitel aangepast. :)
[ Voor 14% gewijzigd door Rafe op 08-07-2004 21:47 ]
  • James_Watt
  • Laatst online: 15-08 15:56
Als je een VIA (686) chipset hebt i.c.m. een Soundblaster dan
zou je wel eens last kunnen hebben van een VIA bug,,,
Even de hyperion drivers installen... B)
Iwill KK266 R | Amd 1333 266 | Global win wbk38 | 512 Mb M-Tec | 2 x Seagate U 5 40 Gb raid 0 + 2 x Barracuda IV 80 GB raid 0 | Liteon 48x12x48 | Cyberdrive 52 | Radeon 8500 | 3com509 |
es effe wa dingetjes uit gaan proberen...alvast bedankt voor de reply's
