Ide driving strength, wasda?
  • 71 views sinds 30-01-2008
  • mace
  • Laatst online: 25-10 20:25
mace
Sapere Aude
Hoi, ik heb laatst mijn bios geupdate van mijn asrock k7s8xe plankje, naar versie 1,9
en nu staat er een optie extra over IDE driving strength, nu was mijn vraag, wat is dat eigenlijk. Ik heb de search al gebruikt en al gegoogled, maar wat het doet :?
Iemand een idee wat het is?
  • Microkid
Microkid
Smile
Eerste hit op Google:
Driving strength on busses, is adjusted according to the load
on the bus and attempting to best match the impedance of the
line. This is done to give the best signal quality. As end
users, we aren't able to guess as to what such a setting
should be adjusted to, especially as we have no way of
observing how well the interconnect on the computer is
actually working.
I would stick with "Normal", unless you are seeing some problem
with the disk. Mixing a setting of "Strong" while using a
40 wire, instead of 80 wire IDE cable, would be asking for
trouble. (That is because the 40 wire IDE cable has inferior
transmission properties, higher crosstalk etc, and a setting
of "Strong" would only make it worse.)
  • dion_b
  • Laatst online: 10:04
dion_b
say Baah
Zoeckt ende gij zult vinden duidelijk :z
Oslik, blyat! Oslik!
