Games sluiten zich zelf af
Hallo
Hier eerst mijn config
Physical Memory - 1024MB Total, 766MB Available
[Processor Information]
CPU Vendor - Intel
CPU Type - Pentium 4
CPU Identity - Family: 15 Model: 2 Step: 9
Socket Type - Socket 478
Frequency - 2600MHz = 100MHz * 26.0
Core Voltage - 2.67V
[Mortherboard]
Vendor - AOpen Inc.
Model - AX4SPE-UN
BIOS Ver - R1.11
Release Date - Mar.30.2004
ROM Size - 4Mb
ROM Ver - 6.00 PG
[PCI Devices List]
PCI0 - 00, 00, 00, Intel(R) 82865G\PE\P Processor to I/O Controller - 2570
PCI1 - 00, 01, 00, Intel(R) 82865G\PE\P Processor to AGP Controller - 2571
PCI2 - 00, 1D, 00, Intel(R) 82801EB USB Universal Host Controller - 24D2
PCI3 - 00, 1D, 01, Intel(R) 82801EB USB Universal Host Controller - 24D4
PCI4 - 00, 1D, 02, Intel(R) 82801EB USB Universal Host Controller - 24D7
PCI5 - 00, 1D, 03, Intel(R) 82801EB USB Universal Host Controller - 24DE
PCI6 - 00, 1D, 07, Standaard Enhanced PCI naar USB-hostcontroller
PCI7 - 00, 1E, 00, Intel(R) 82801EB PCI Bridge - 244E
PCI8 - 00, 1F, 00, Intel(R) 82801EB LPC Interface Controller - 24D0
PCI9 - 00, 1F, 01, Intel(R) 82801EB Ultra ATA Storage Controllers
PCI10 - 00, 1F, 02, Intel(R) 82801EB Ultra ATA Storage Controllers
PCI11 - 00, 1F, 03, Intel(R) 82801EB SMBus Controller - 24D3
PCI12 - 00, 1F, 05, Realtek AC'97 Audio
PCI13 - 01, 00, 00, NVIDIA GeForce FX 5200
PCI14 - 02, 04, 00, Sitecom PCI Fast 10/100 Ethernet Adapter LN-020
PCI15 - 02, 05, 00, VIA USB Universal Host Controller
PCI16 - 02, 05, 01, VIA USB Universal Host Controller
PCI17 - 02, 05, 02, VIA PCI to USB Enhanced Host Controller
PCI18 - 02, 07, 00, Realtek RTL8139(A)-based PCI Fast Ethernet Adapter
PCI19 - 02, 09, 00, Eicon DIVA 2.01 S/T (PCI)
PCI20 - 02, 0A, 00, Hercules Gamesurround Fortissimo(tm) II
[IDE Devices List]
[IDE1(MASTER)]
Serial No. - Y2E0XB9E
Model No. - Maxtor 6Y060P0
Firmware - YAR41BW0
DMA mode - Ultra DMA 6
PIO mode - PIO mode 4
Capacity - 61492 Mb
[IDE1(SLAVE)]
Serial No. - 664223914422
Model No. - MAXTOR 6L080J4
Firmware - A93.0500
Capacity - 80054 Mb
[IDE2(MASTER)]
Serial No. - 552831
Model No. - PLEXTOR CD-R PX-W4012A
Firmware - 1.02
DMA mode - Ultra DMA 2
Capacity - -
[IDE2(SLAVE)]
Serial No. -
Model No. - HL-DT-STDVD-ROM GDR8161B
Firmware - 0100
Capacity - -
Het probleem is dat als ik een spel opstart hij tot het spel starten komt en dan terug klapt naar de desktop.
Dit gebeurt onder XPpro en win 2000 en het gaat om Max payne 1, Far cry, en Deus ex.
Heb de patches van microsoft geinstaleerd en de nieuwst directx.
Tevens heb ik alles wat overgeklokt stond terug gezet en bij max payne de 05patch er op gezet.
De video kaart wordt niet te heet en het is 47 graden in de pc.
Heb op internet gezocht en vond verschilende oplosingen ook op dit forum maar niks werkt.
Moet ik nu echt terug naar win 9x of me dat is toch waanzin of niet dan.
Begrijp vooral niet hoe dit zo maar kan er is niks veranderd aan de pc en hij loopt al een half jaar stabiel.
Ben voor alles in momenteel als het maar werkt.
  • janklp
  • Laatst online: 06-10 14:56
janklp
FortyTwo Capital
Dat probleem heb ik bij colin macrae 4
Zal ik er ook eens op zetten kijken wat hij dan doet
  • SouLmaN
  • Laatst online: 19-10 18:20
Met kast open en ventilator erop nog hetzelfde probleem ?
Probeer anders ff wat hardware (zoveel mogelijk) afkoppelen en kijken of ie het nog doet.
[ Voor 45% gewijzigd door SouLmaN op 06-07-2004 10:16 ]
Bij colin macrae 4 slaat hij ook uit naar de desktop, En aan de temp kan het niet ligen volgens mij. De kast heeft het bij de CPU en agp slot maat 47 graden.
Lijkt me niet echt te hoog.
Maar ben overal voor in dus stap nu op de fiets voor een koeler.
Nieuwe titan cooler er bij gezet, en alles wat pci is er uit.
En hij doet het nog niet..........
Wordt hier toch echt even niet goed van.
Mijn zoon en ik willen graag max payne doen, heeft er nog iemand een tip!!!!
Verwijderd schreef op 06 juli 2004 @ 16:09:
Ik heb daar probleem ook gehad met spellen. Ik heb toen heel lang zitten kutten met de drivers, (sommige deden het niet goed op mijn PC en flipte dus ook steeds met gamen |:( )
Ik denk dat het aan de driver's ligt. Probeer de driver's van de 3dkaart te updaten!
Denk dat het daar aan ligt.
Check deze website maar. Staat wat info over drivers:
meuktracker: DNA-Driver 2.6.4.7
Voor de rest denk ik altijd. Als je genoeg geprobeerd hebt. backup branden en alles er af halen en compleet nieuwe instal. Ben je van al het gezeur af en het is sneller gedaan dan oplossingen opzoeken je ergeren als het niet werkt. })
Helaas het lukt zelfs niet met nieuwe drivers heb zelfs oude drivers geprobeerd (Oude Datonator).
Ale pci de uit ook niks, vermoed dat het de agp drivers van intel zijn.
Ben nu linux partition aan het verplaatsen naar de slave schijf en dan op de vrije ruimte Me of 98 kijken of dat werkt
Draai nu Me en Max payne werkt.
Ik blijf dit vreemd vinden.
Toch eens het systeem schoon maken.(format c:)
Win me, XP pro, Win 2003, en Linux op 1 bak vind ik toch een beetje overflow.
Leuk voor in de vakantie.
