[Gentoo]Radio in mplayer --> alleen mms:// ?
  • Jack Flushell
  • Laatst online: 02-08 07:34
Ik luister graag naar 3FM, maar nu valt het me op dat ik in mijn mplayer (met kmplayer frontend) alleen streams kan afspelen die beginnen met mms://iets.
Als ik als url invoer http://www.omroep.nl/radio3/live64.asx gebeurd er niets..
In de colsole zie ik:
29
30
31
32
33
34
35
36
37
woftor@Thor woftor $ mplayer http://www.omroep.nl/radio3/live64.asx
MPlayer 1.0pre4-3.3.3 (C) 2000-2004 MPlayer Team
CPU: Advanced Micro Devices Athlon Thunderbird 1400 MHz (Family: 6, Stepping: 4
Detected cache-line size is 64 bytes
CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx
Reading config file /usr/share/mplayer/mplayer.conf
Reading config file /home/woftor/.mplayer/config
Reading /home/woftor/.mplayer/codecs.conf: Can't open '/home/woftor/.mplayer/co
decs.conf': No such file or directory
Reading /usr/share/mplayer/codecs.conf: 66 audio & 176 video codecs
font: can't open file: /home/woftor/.mplayer/font/font.desc
Font /usr/share/mplayer/font/font.desc loaded successfully! (206 chars)
Failed to open /dev/rtc: No such file or directory (/dev/rtc should be readable        by the user.)
Using usleep() timing
Can't open input config file /home/woftor/.mplayer/input.conf: No such file or        directory
Input config file /usr/share/mplayer/input.conf parsed: 53 binds
Playing http://www.omroep.nl/radio3/live64.asx.
Resolving www.omroep.nl for AF_INET...
Connecting to server www.omroep.nl[145.58.30.2]:80 ...
size_confirm mismatch!: 22611 28271
Error while parsing chunk header
Used protocol http
asf_streaming_start failed
Check if this is a playlist which requires -playlist option
Example: mplayer -playlist <url>
Unable to open URL: http://www.omroep.nl/radio3/live64.asx
Exiting... (End of file)
Volgens mij moet mplayer asx wel ondersteunen. Uit de console foutmelding wordt ik niet echt wijzer. Mis ik dan een codec? Uit de mplayer documentatie blijkt dat er voor wma en asx wel ondersteuning is...
  • Zwerver
Ik zou zeggen controleer je codecs eerst even voordat je de vraag hier neerzet?
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • Jack Flushell
*knip*
Bezig te kijken in /usr/share/mplayer/codecs.conf
[ Voor 88% gewijzigd door Jack Flushell op 30-06-2004 12:24 ]
  • _JGC_
Lees jij je foutmeldingen wel?
  • WHiZZi
  • Laatst online: 22-08 12:23
WHiZZi
Museumdirecteurtje
_JGC_ schreef op 30 juni 2004 @ 12:33:
Dat werkt ook niet, gelukkig komt er dan wel een bruikbare URL tevoorschijn.
Playing http://www.omroep.nl/radio3/<ASX version = "3.0">.
Server returned 404: Not Found
Unable to open URL: http://www.omroep.nl/radio3/<ASX version = "3.0">
Playing http://www.omroep.nl/radio3/<Title>Radio 3FM</Title>.
Unable to open URL: http://www.omroep.nl/radio3/<Title>Radio 3FM</Title>
Playing <ENTRYREF href = "http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=46&a=.asx" />.
Unable to open URL: <ENTRYREF href = "http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=46&a=.asx" />
Playing <ENTRYREF href = "http://www.omroep.nl/radio3/radio3-breed.asx" />.
Unable to open URL: <ENTRYREF href = "http://www.omroep.nl/radio3/radio3-breed.asx" />
Playing http://www.omroep.nl/radio3/</ASX>.
Unable to open URL: http://www.omroep.nl/radio3/</ASX>
Vervolgens is het de juiste URL opzoeken en afspelen :D
mplayer -playlist -cache 256 http://www.omroep.nl/radio3/radio3-breed.asx
En voila, het werkt! :D
Zorg dat de cache een redelijk aantal is. Standaard wordt er 8MB gecached alvorens af te spelen :o
Met @Home kreeg ik met deze instellingen een redelijk synchroon lopende audiostream (iig weinig vertraging).
EDIT: ipv -cache 256 kun je ook -nocache toevoegen, dan werkt het ook :P
B)
[ Voor 35% gewijzigd door WHiZZi op 30-06-2004 13:02 ]
HomeComputerMuseum - Interactief computermuseum waar wij de geschiedenis van de thuiscomputer preserveren. Centraal gelegen in de Benelux.
  • Wilke
  • Laatst online: 22:58
Volgens mij stond er al een script in het 'handige scriptjes topic' wat dit automatisch doet ;)
  • WHiZZi
WHiZZi
Museumdirecteurtje
Deze dus
Helaas staat daar ook de verkeerde URL in :+
EDIT:
Sterker nog, alleen de Veronica-stream-URL is nog de enige die werkt... 8)7
[ Voor 25% gewijzigd door WHiZZi op 30-06-2004 13:20 ]
  • Jack Flushell
WHiZZi schreef op 30 juni 2004 @ 12:45:
B)
Het moet zijn:
mplayer -playlist http://www.omroep.nl/radio3/radio3-breed.asx -cache 256
Dus de -cache erachter, anders werkt het niet (bij mij althans)
@Whizzi
Natuurlijk had ik die foutmelding wel gelezen ;) En uiteraard geprobeerd :)
Thnx! allemaal
