Ik heb net een nieuw laptop gekocht en probeer nu het internet te bereiken via bluetooth... Ik heb op google een howto kunnen vinden maar bij stap 12 loopt het verkeerd... Ik zie namelijk als service geen LAN staan, weet iemand waar dit aan kan liggen? Ik heb alle stappen gevolgd in de howto maar er stonden misschien al enkele settings anders aangezien we met een router werken thuis.
3.2. Network sharing setting for Windows
The Network Access service permits a Bluetooth enabled PC (client) to access the Internet via another Bluetooth enabled PC (Server) that already has Ethernet connection.
Windows network sharing setting
PC to PC (Windows 2000 or Windows XP)
1. To enable Internet Connection Sharing on the server PC
2. Click on Start menu-->Settings -->Network and Dial-up Connections and find your Local Area Connection (LAN) that is connected to the Internet.
3. Right click the active LAN connection to open the "Properties" dialog box.
Select “Show icon in notifcation area when connected” if you want to see if you have got an network connection or not.
4. Click on "Advanced" tab and select the "Internet Connection Sharing" checkbox to enable Internet sharing.
5. Click on "Settings..." button and select the services you wish to provide other Bluetooth devices. Click "OK" to save the changes.
6. Go back to the "Network and Dial-up Connections" window, right click the "Bluetooth LAN Access Server Driver" and select "Properties"..
7. Under "General" tab, click on "Internet Protocol (TCP/IP)" and "Properties".
8. Under "General" tab, assign a virtual IP as shown in the picture below. Then click "OK" to save the changes.
9. This allows the server PC to act as a DHCP server towards the client PCs.
NOTE: For Win98SE and WinMe, please download and install WinRoute (or similar program) on the Server PC to allow DHCP service.
10. On the client PC, launch the Bluetooth software stack by clicking the "My Bluetooth Places" icon located on the desktop.
11. Double click the "Entire Bluetooth Neighborhood" icon to search for other Bluetooth devices nearby.
12. After searching is completed, locate the computer name of the server PC and double click it to discover the Bluetooth services it has to offer. (i.e. Bluetooth Serial Port, Dial-up Networking, File Transfer, Network Access, etc.).
13. Click on the "Network Access" icon to connect to the shared Internet connection on the server PC.
Bedankt!
Bedankt!
