Traffic monitoring
  • 93 views sinds 30-01-2008
Hi all,
I need some monitrong-software that monitors and logs the traffic-usage from the windows user on that machine.
The situation is like this:
We get billed for the traffic of a machine.
more users are on that machine.
I need to know which users are using the most traffic to make sure i bill the right users. Thanks for any tips on this!
  • UltraSub
  • Laatst online: 24-10 06:03
DU-meter does the job.
Although it doesnt do totals for all users. It totals per user. But if that is what you are looking for......
Do You have a proxy server supplying the connection, or is the machine directly connected to the internet?
By the way, welcome to the GoT forum.
Nah it needs to be a service that is constantly running. Multiple users can work on that machine at the same time. they need terminal services and the machine is directly connected to the internet. So a user logs on using terminal services and then he starts using an application and then generates traffic that i need to monitor.... i cannot find anything to do that job ....
Waarom praat je niet gewoon nederlands zoals in je andere post? :?
  • Xandrios
This is a Dutch forum, so we communicate in Dutch here.
Try google, there are lots of bandwith monitoring programs. And probably also some that can do the job. Just try some.
