Cisco 2610XM + Uitbellen
Beste mensen,
Ik ben enige tijd bezig met de configuratie van de Cisco 2610XM router, maar helaas ben ik ergens wat vergeten, of heb ergens een foutje gemaakt. Met de onderstaande configuratie neemt deze machine niet eens de moeite om uit-te-bellen. De vraag is of jullie mijn mis-configuratie zien.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Building configuration...
Current configuration : 1726 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname TEST0
enable secret 5
username TEST0 password 7
username TEST1_801 password 7
username TEST2_801 password 7
ip subnet-zero
no ip domain-lookup
ip name-server 192.168.1.254
isdn switch-type basic-net3
interface Loopback1
 ip address 192.168.3.1 255.255.255.192
interface FastEthernet0/0
 ip address 192.168.0.151 255.255.255.0
 no ip proxy-arp
 duplex auto
 speed auto
interface BRI0/0
 ip unnumbered Loopback1
 encapsulation ppp
 dialer rotary-group 1
 dialer-group 1
 ppp authentication chap
interface BRI0/1
 encapsulation ppp
 dialer-group 1
interface Dialer1
 encapsulation ppp
 dialer in-band
 dialer map ip 192.168.3.2 name TEST1_801 1234567890
 dialer map ip 192.168.3.3 name TEST2_801 0987654321
 ppp multilink
 ppp timeout multilink link add 30
 multilink load-threshold 1 outbound
router rip
 network 192.168.0.0
 network 192.168.3.0
 no auto-summary
ip default-gateway 192.168.0.5
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.5
ip route 192.168.3.2 255.255.255.255 Dialer1
ip route 192.168.3.3 255.255.255.255 Dialer1
ip route 192.168.3.64 255.255.255.240 192.168.3.2
ip route 192.168.3.80 255.255.255.240 192.168.3.3
ip http server
ip pim bidir-enable
line con 0
 password 7
 login
line aux 0
 password 7
 login
line vty 0 4
 password 7
 login
end
Alvast bedankt!
  • igmar
  • Laatst online: 23-08 16:57
igmar
ISO20022
belt ie wel uit als je een remote Ip pingt ? RIP werkt met broadcasts, en indien je ook wil uitbellen op broadcasts dien te dat aan te geven (in de dialer map ip regels).
Nee, dan belt ie ook niet. Hij geeft overigens ook niet aan in de "sh dialer" dat er een failure is. Hij probeert niet eens te bellen, de vraag is of dat ding het wel snapt dat ie moet bellen....
  • joopv
Hoe weet de dialer welke BRI's hij kan gebruiken?
  • TrailBlazer
  • Laatst online: 24-08 21:59
TrailBlazer
Karnemelk FTW
je mist je dialer pool member en je dialer list. Exacte commando's weet ik zo 123 niet
  • it0
  • Laatst online: 27-12-2025
it0
Mijn mening is een feit.
Je bent een beetje in de war, je kan bij cisco op 2 manieren dial on demand configuren
-legacy DDR
-dialer maps
Bij legacy maak je een map op de intercace (je BRI dus)
bij een dialer map, maak je dialers aan die verwijzen naar de interface en vice versa (dat is waar joopv en trailblazer het over hebben)
Als je googled op "legacy dialer configuration cisco" oid dan vind je vast wel goede voorbeelden..
Ook helpt debug dialer en term mon om te debuggen en het probleem te achterhalen..
Ik ga het allemaal even proberen, ik dank u in iedergeval vriendelijk voor alle hulp. Mocht iemand nog enigzinds wat concreters hebben hoor ik dat heel graag. Alvast bedankt! :)
Ja, je dialer moet ook lid worden van rotary group 1 anders weet je dialer niet welke fysieke interfaces hij mag gebruiken
[ Voor 4% gewijzigd door Verwijderd op 30-06-2004 15:18 ]
