cdrecord/mkisofs: multisessie DVD's
  • DriesA
  • Laatst online: 31-10 18:02
Hey,
Heeft er iemand ervaring met het maken van multi-sessie DVD's met mkisofs en cdrecord? Ik krijg 'm niet aan de praat!!
Ik maak eerst een ISO met mkisofs 2.01a32 (i686-pc-cygwin)
C:\Aendeker\backup>mkisofs -J -L -R -o temp.iso c:\moment\
mkisofs: The option '-L' is reserved by POSIX.1-2001.
mkisofs: The option '-L' means 'follow all symbolic links'.
mkisofs: Mkisofs-2.01 will introduce POSIX semantics for '-L'.
mkisofs: Use -allow-leading-dots in future to get old mkisofs behavior.
Warning: creating filesystem that does not conform to ISO-9660.
Using BEVA_000.AMB;1 for c:\moment\/Aendeker/SAVE/BEVA_WindowsXP.AMB (BEVA_Wind
ows9x.AMB)
Using 2003_02D.ZIP;1 for c:\moment\/data/2003-09-09.zip (2003-09-08.zip)
2.80% done, estimate finish Fri Jun 25 18:59:16 2004
5.59% done, estimate finish Fri Jun 25 18:59:33 2004
97.82% done, estimate finish Fri Jun 25 18:59:49 2004
Total translation table size: 0
Total rockridge attributes bytes: 22654
Total directory bytes: 49626
Path table size(bytes): 166
Max brk space used 34000
178910 extents written (349 MB)
Dan wil ik deze ISO schrijven met Cdrecord-ProDVD-Clone 2.01a23-2 (i686-pc-cygwin).
C:\Aendeker\backup>cdrecord -v -multi -data speed=2 dev=1,0,0 temp.iso
Cdrecord-ProDVD-Clone 2.01a23-2 (i686-pc-cygwin) Copyright (C) 1995-2003 Jörg Schilling
Unlocked features:
Limited features:
TOC Type: 1 = CD-ROM
scsidev: '1,0,0'
scsibus: 1 target: 0 lun: 0
Using libscg version 'schily-0.7'.
SCSI buffer size: 64512
atapi: -1
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : '_NEC '
Identifikation : 'DVD+RW ND-1100A '
Revision : '1iH0'
Device seems to be: Generic mmc2 DVD-ROM.
Current: DVD+RW
Profile: DVD+R
Profile: DVD+RW (current)
Profile: DVD-ROM
Profile: CD-RW
Profile: CD-R
Profile: CD-ROM
Using generic SCSI-3/mmc-3 DVD+RW driver (mmc_dvdplusrw).
Driver flags : DVD MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 1605632 = 1568 KB
FIFO size : 4194304 = 4096 KB
Track 01: data 349 MB
Total size: 349 MB = 178910 sectors
Current Secsize: 2048
Trying to clear drive status.
Blocks total: 2295104 Blocks current: 2295104 Blocks remaining: 2116194
Starting to write CD/DVD at speed 2 in real TAO mode for multi session.
Last chance to quit, starting real write 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Starting new track at sector: 0
Track 02: 349 of 349 MB written (fifo 100%) [buf 100%] 2.5x.
Track 02: Total bytes read/written: 366407680/366407680 (178910 sectors).
Writing time: 128.469s
Average write speed 2.1x.
Min drive buffer fill was 100%
Fixating...
Fixating time: 2.003s
cdrecord: fifo had 5772 puts and 5772 gets.
cdrecord: fifo was 0 times empty and 5274 times full, min fill was 89%.
Tenslotte kijk ik wanneer de zojuist geschreven sessie 'eindigt' op de DVD. Deze informatie heb ik nodig als ik met cdrecord een tweede sessie wil schrijven op de DVD.
C:\Aendeker\backup>cdrecord -msinfo dev=1,0,0
0,0
Dit is onmogelijk! De eerste sessie kan niet eindigen op plaats '0' (dan zou er geen sessie mogen zijn). Hierdoor kan ik dus onmogelijk een tweede sessie schrijven (mislukt ook als ik het probeer). De eerste sessie is wel leesbaar.
Ik gebruik cygwin1.dll DLL ver. 1.5.10-3. OS is Windows XP.
Weet iemand wat ik verkeerd doe? Ik zou heel graag multi-sessie DVD's maken op een command-line basis!
