[sendmail] mail komt niet aan :(
hey allemaal,
ik zit met het volgende probleem mail versturen is geen probleem dit gaat hele te goed. Alleen het ontvangen van mail wil niet :(
dit is een stukje van /var/log/maillog
Jun 25 18:35:06 localhost sm-mta[32458]: i5PGZ6Dx032458: from=<littleb@b0ng.nl>, size=1591, class=0, nrcpts=1, msgid=<200406251635.i5PGZ6GL032457@b0ng.nl>, proto=ESMTP, daemon=MTA, relay=localhost [127.0.0.1]
Jun 25 18:35:07 localhost amavisd[32460]: starting. amavis 0.3.12 Fri Jun 25 15:42:31 CEST 2004
Jun 25 18:35:08 localhost sm-mta[32458]: i5PGZ6Dx032458: to=<littleb@b0ng.nl>, delay=00:00:02, mailer=local, pri=31591, stat=queued
Jun 25 18:35:08 localhost sendmail[32457]: i5PGZ6GL032457: to=littleb, ctladdr=littleb (1001/100), delay=00:00:02, xdelay=00:00:02, mailer=relay, pri=31349, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (i5PGZ6Dx032458 Message accepted for delivery)
Jun 25 18:40:06 localhost sendmail[471]: i5PGe6H3000471: from=littleb, size=1349, class=0, nrcpts=1, msgid=<200406251640.i5PGe6H3000471@b0ng.nl>, relay=littleb@localhost
Jun 25 18:40:06 localhost sm-mta[472]: i5PGe6fo000472: from=<littleb@b0ng.nl>, size=1591, class=0, nrcpts=1, msgid=<200406251640.i5PGe6H3000471@b0ng.nl>, proto=ESMTP, daemon=MTA, relay=localhost [127.0.0.1]
Jun 25 18:40:07 localhost amavisd[474]: starting. amavis 0.3.12 Fri Jun 25 15:42:31 CEST 2004
Jun 25 18:40:08 localhost sm-mta[472]: i5PGe6fo000472: to=<littleb@b0ng.nl>, delay=00:00:02, mailer=local, pri=31591, stat=queued
Jun 25 18:40:08 localhost sendmail[471]: i5PGe6H3000471: to=littleb, ctladdr=littleb (1001/100), delay=00:00:02, xdelay=00:00:02, mailer=relay, pri=31349, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (i5PGe6fo000472 Message accepted for delivery)
Jun 25 18:45:06 localhost sendmail[933]: i5PGj61u000933: from=littleb, size=1349, class=0, nrcpts=1, msgid=<200406251645.i5PGj61u000933@b0ng.nl>, relay=littleb@localhost
en dit gaat zo de heletijd door
dit is mijn sendmail.mc
include(`../m4/cf.m4')
VERSIONID(`default setup for Slackware Linux')dnl
OSTYPE(`linux')dnl
define(`confPRIVACY_FLAGS', `authwarnings,novrfy,noexpn,restrictqrun')dnl
define(`confTO_IDENT', `0')dnl
FEATURE(`local_procmail',`',`procmail -t -Y -a $h -d $u')dnl
EXPOSED_USER(`root')dnl
LOCAL_DOMAIN(`b0ng.nl')dnl
MAILER(local)dnl
MAILER(smtp)dnl
MAILER(procmail)dnl
# AMaViS Milter
define(`_FFR_MILTER', `1')dnl
INPUT_MAIL_FILTER(`milter-amavis', `S=local:/var/amavis/amavis-milter.sock, T=S:10m;R:10m;E:10m')dnl
  • igmar
  • Laatst online: 29-06 18:56
igmar
ISO20022
2 opties :
1) Je DNS config is niet goed. Controleer dat met nslookup
2) Je milter weigert de mail. Zie de logfile van het milter.
Verhoog eventueel LogLevel in sendmail.cf om meer loginfo te genereren.
Je kan ook tijdelijk amavis 'uitzetten' natuurlijk.
nslookup is trouwens deprecated, dig (Domain Internet Gropher) is de opvolger/vervanger.
