[SBS2003] Krijg Outlook Web Access niet aan de praat *
ik heb sinds een tijdje Small Business Server 2003 Standard op onze server draaien. nu wil ik dat medewerkers gebruik kunnen maken van de Outlook Web Access.
Na het draaien van de configure remote access wizard in
server management krijg ik de volgende foutmelding:
an error occurred while creating the Connection Manager
configuration package file. For details, see C:\program
files\microsoft small business server\support\rraslog.txt,
and then return the Remote Access Wizard.
in de betreffende log staat het volgende:
18-6-2004 13:18
C:\Program Files\Microsoft Windows Small Business
Server\Networking\RRASWiz\wizrras.dll, version 5.2.2651.0
Calling CRRASCommit::CommitEx
Calling CRRASCommit::ValidatePropertyBag
pdispPPPBag->QueryInterface returned OK
PropertyBag 267090
Reading property value for enabling Remote Access returned
OK
bRemoteAccess = 1
Reading property value for VPN returned OK
bVPN = 1
Reading property value for RAS returned OK
bRAS = 0
Calling CRRASCommit::ValidateVPNProperties
Reading VPN Server Name returned OK
VPN Server Name is duve100.duvedec.com
Calling CRRASCommit::ValidateDHCPProperties
DHCP server is installed on the box
CRRASCommit::ValidateDHCPProperties returned OK
CRRASCommit::ValidateVPNProperties returned OK
CRRASCommit::ValidatePropertyBag returned OK
Pointer to the property bag 267090
Calling CRRASCommit::CommitRRAS
Arguments:
PropertyBag 267090
bRAS 0
bVPN 1
Getting the GUID of the private NIC returned OK
Private NIC Guid is {11B141A8-BE30-4A3A-A0D0-2E5AD3E3FFB7}
Checking whether RRAS is already running returned OK
RRAS already running
Stopping RRAS returned OK
Installing RRAS returned OK
Dhcp server is installed and running on this box
Enabling DHCP client addressing returned OK
Configuring ports returned OK
Identifying the private NIC for RAS returned OK
Setting the default authentication methods returned OK
Disabling NETBIOS for RAS returned OK
Changing RRAS startup type to automatic returned OK
Configuring Remote Access Policy returned OK
Starting RRAS service returned OK
Saving RRAS method returned OK
Method is 2
Where 1 = RAS, 2 = VPN 3 = both
Saving Dhcp Server IP returned OK
CRRASCommit::CommitRRAS returned OK
Calling CRRASCommit::CommitCMAK
Arguments:
PropertyBag 267090
bRAS 0
bVPN 1
Template file name is sbsvpn
Reading VPN Server name returned OK
Reading VPN Server name is duve100.duvedec.com
Created temp directory CMPCCB.tmp
Copying required template files to the temp directory
returned OK
Updating CMP template returned OK
Updating CMS template returned OK
Updating SED template returned OK
Creating proxy configuration file returned OK
Running IExpress to build the package returned OK
Specifying error location (in CMAK) returned OK
*** CRRASCommit::CommitCMAK returned ERROR 80004005
*** CRRASCommit::CommitEx returned ERROR 80004005
wie kan mij helpen de fout op te lossen?
Ik heb twee NIC's (een voor het interne netwerk op IP 192.168.100.x en een voor de connectie naar de router op IP 192.168.1.x)
  • Spider.007
Spider.007
* Tetragrammaton
rdeschrijver,
Welkom op GoT :)
Op dit forum hebben we een aantal regels opgesteld waar een topic aan hoort te voldoen. Deze regels maken het jou makkelijker om te onthouden wat je in je topicstart moet zetten, en zijn voor je lezers handig omdat ze weten welke informatie ze kunnen verwachten.
Deze regels worden wat uitgebreider toegelicht in de policy. Ik zal de drie belangrijkste punten er even uitlichten omdat je topic niet helemaal voldoet aan de eisen die we hiervoor opgesteld hebben:
• Probeer eerst je probleem zelf op te lossen. Lukt het niet om je probleem op te lossen dan kun je een topic openen op GoT. Zorg dat je duidelijk verteld waar je al op gezocht hebt en waarom het resultaat daarvan jou niet verder heeft geholpen. Hierdoor voorkom je dat we je tips gaan geven die je allang geprobeerd hebt; en dat is natuurlijk niet handig :)
• Zorg voor een duidelijke topicstart. Zet hierin duidelijke foutmeldingen die je krijgt en informatie die voor ons handig is om je probleem op te lossen. Zorg er ook voor dat je zinnen in duidelijk Nederlands en goed leesbaar zijn opgesteld.
• Kies een duidelijke titel. Dit kan vaak erg lastig zijn; maar kijk toch eerst even naar de rest van de topictitels op het forum. Je zult zien dat je meestal het beste het OS of programma tussen blokhaken kunt zetten en daarachter wat er fout gaat. Een goede topictitel moet jouw probleem meteen duidelijk maken.
Kun je ons in ieder geval even vertellen wat je zelf al had ontdekt mbt dit probleem? Dan verplaats ik dit Outlook probleem even naar SA, met een titeledit :)
WOS > SA
owa op sbs2003 > [SBS2003] Krijg Outlook Web Access niet aan de praat *
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
Bedankt voor de terechtwijzing :)
Ik heb via de KB van Microsoft een aantal troubleshooting guides gelezen en instellingen in IIS en Exchange geprobeerd (met name op het gebied van authenticatie) zonder succes.
De foutmelding die ik krijg kan ik totaal niet plaatsen (ik snap er geen hout van). Misschien kan iemand mij in de juiste richting helpen?
heeft niemand een suggestie?
bedankt voor de hulp :s
  • Spider.007
Spider.007
* Tetragrammaton
Kun je hier iets mee?
If you receive errors during synchronization, this might be because your database contains standard SQL Server logins instead of Windows NT user logins. Using a standard SQL Server login might result in an error saying "Exceptions occurred while invoking method SynchronizeUserList Error(80004005) in Microsoft Cursor Engine." If you receive this error during synchronization, remove any standard, non-Windows NT user logins from your database and try again.
in hoeverre heeft outlook web access met sql server te maken dan?
  • Spider.007
Spider.007
* Tetragrammaton
Verwijderd schreef op 06 juli 2004 @ 08:28:
Het was een van de weinige errors die overeenkwam met het foutnummer dat je krijgt. Ik geloof dat er niet direct een verband is tussen beiden producten; mocht je er toch gebruik van maken kun je wellicht iets met de gegeven oplossing; en anders niet. Ik kon helaas ook erg weinig over de foutmelding die jij krijgt..
heeft iemand enig idee hoe ik de default instellingen van outlook web acces terug kan krijgen?
