[Windows Update] font aangepast?
Was net een critical update aan 't downloaden toen ik pas las waar hij voor was...
Afbeeldingslocatie: http://www.erno.demon.nl/temp/critical.jpg
Weet iemand waar dit over gaat?
Ik zou zeggen, laad charmap.exe, vergelijk de 2 fonts en vertel het ons ;)
http://support.microsoft.com/?id=833407
"Wanneer u het lettertype Bssym7.ttf verwijdert van een computer waarop een Japanse versie van Office 2003 is geïnstalleerd, worden sommige fonetische symbolen mogelijk niet meer correct weergegeven."
http://support.microsoft.com/default.aspx?kbid=833404
http://typographi.ca/000755.php
http://abcnews.go.com/sec...ka_font_pcmag_040217.html
http://forums.winxpcentral.com/showthread.php?t=8767
The unacceptable symbols were a Swastika and a Star of David.
Description
This update will remove two swastikas included in the Bookshelf Symbol 7 font. From the Microsoft support document, it is hard to guess why this patch is needed. Here is what they say: 'This item updates the Bookshelf Symbol 7 font included in some Microsoft products. The font has been found to contain unacceptable symbols. After you install this item, you may have to restart your computer.'
In case you missed the news or had trouble understanding the issue thanks to the vague language in the support document, this problem lead to a statement and apology from Microsoft Senior Vice President, Steven Sinofsky (December 2003): 'Microsoft has learned of a mistake in the Bookshelf Symbol 7 font included in the Microsoft Office System client applications. Due to an unintentional oversight, we failed to identify, prior to the release, the presence of two swastikas within the font. We apologize for this and for any offense caused.'
Here is the image the upate will fix (the patch turns it around the opposite way):Afbeeldingslocatie: http://www.softwarepatch.com/pics/swat.jpg
Bron: http://www.softwarepatch.com/windows/bookshelf.html
[ Voor 159% gewijzigd door Verwijderd op 20-06-2004 00:41 ]
  • job
  • Laatst online: 29-08 17:13
job
daar zit volgens google een swastika in.
[ Voor 42% gewijzigd door job op 20-06-2004 00:38 ]
  • sjink
  • Laatst online: 03-02-2025
zat daar niet een hakenkruisje in ofzo waar mensen over hadden geklaagd?
*blup*
  • job
job
Beetje raar trouwens dat men die update bij de critical updates neer plempt..
In veel landen is de swastika een teken van geluk...
zal wel weer een bekrompen amerikaan hebben zitten klagen.
damster schreef op 20 juni 2004 @ 00:40:
Denk eerder dat het een Jood was...
Maar goed, inderdaad voordat Hitler het tot "zijn" symbool om doopte was dit een symbool van een of andere gemeenschap uit 't oostblok gedeelte.
Iets oostelijker ;)
(of wat wereldwijder als je wat breder kijkt)
Al zeker 3000 jaar lang.
Maak daar maar ouder dan 5000 jaar vóór Christus van :)
The swasticka has thus appeared in different forms, in different places and for different reasons, in human culture since pre-historic times.
http://www.locksley.com/6696/swastick.htm
http://www.swastika-info.com/en/bedeutung-missbrauch.php
De 'originele' Duitse swastika was ontworpen door de tandarts Dr. Friedich Krohn uit Starnberg op een zwart-wit-rode achtergrond. Hitler heeft in 1920 alleen de achtergrond vervangen voor rood als vlammend symbool en ter competitie met de communistisische vlag.
[ Voor 77% gewijzigd door Verwijderd op 20-06-2004 00:55 ]
  • job
job
niet een of andere gemeenschap :)
Dit teken werd en wordt nog steeds veel gebruik in veel aziatische landen.
