[Bitdefender] Command Line Parameters gebruiken *
  • 854 views sinds 30-01-2008
Ik zou graag mijn Bitdefender Free gebruiken om bestanden na het downloaden automatisch te scannen.
Het is mogelijk, na wat googlen vond ik dit:
Please note that you can scan your system from BitDefender's user interface and that the Virus Shield scans all downloaded/archived/uncompressed files as it is a disk-access operation. However, you can run a command line scan on your system or integrate BitDefender with the download managers or with the archivers using our scanning executable (bdc.exe). You can run the scan following the steps presented below:
1. Open a command prompt session (Start > Run... ; type cmd and then hit OK);
2. Change the directory to \Program Files\Common Files\SOFTWIN\BitDefender Scan Server\;
e.g.(if BitDefender is installed on C:\ - if not you will need to replace C:\ with the drive's letter):
cd "C:\Program Files\Common Files\SOFTWIN\BitDefender Scan Server\"
3. Run the scan with bdc; for all scanning parameters please type:
bdc /?
e.g.(a good command line scan would be - the scanning log will be c:\log.txt):
bdc.exe c:\ /files /arc /all /list /log=C:\log.txt /mail /debug
You can integrate BitDefender's scanning executable with your download manager or your archiving program by setting the scanning executable (use the Browse button and navigate to \Program Files\Common Files\SOFTWIN\BitDefender Scan Server\); the parameters chosen by you to set the scan are available by following steps 1 and 2 from the above procedure.
Toch begrijp ik nog niet hoe ik dat instel.
Internet Download Manager vraagt:
Virus scanner programma = C:\Program Files\Common Files\Softwin\BitDefender Scan Server\bdc.exe
Commando lijn parameters = ???
Ik weet niet welke parameters ik hie rmoet gebruiken en vooral hoe ik deze lijn van formuleer, want gewoon /files /arc /all / list werkte niet. Dit zijn de beschikbare:
Usage: bdc.exe path[s] [parameters]
Parameters:
/f, /files scan files *
/m, /mem scan memory
/b, /boot scan boot sector and mbr
/r, /arc scan archives
/i, /mail scan mail databases
/k, /nopack don't scan packed programs
/h, /nohed no heuristics
/E, /ext=ext1;ext2; scan only this extensions
/X, /xcl=ext1;ext2; exclude from scan this extensions
/G, /log[=file] create log file
/S, /cd scan cd-rom
/N, /fixed scan all fixed drives
/M, /floppy scan floppy
/I, /list display all files
/a, /all scan all files
/e, /app append to log file
/T, /tmp=path set temporary path
/F, /infp=path set infected quarantine folder
/U, /susp=path set suspected quarantine folder
/R, /nor do not recurse into folders
/p, /prompt prompt for action
/O, /info information
/W, /nowarn no warnings
/V, /vlist display virus list
/d, /dis disinfect files
/o, /copy copy infected files in quarantine folder
/y, /copys copy suspect files in quarantine folder
/l, /del delete infected files
/noclean don't display clean files
/noc don't log clean files
/move move infected files in quarantine folder
/moves move suspect files in quarantine folder
/ren rename infected files
/infext=ext set rename extension
/alev[=n] set maximum archive depth level
/flev[=n] set maximum folder depth level
/hed[=n] set heuristics level
/update update
/?, /help this help
* = default option
Zelfde geldt voor MSN je kan invullen:
Bestanden op virussen controleren met: ":\Program Files\Common Files\Softwin\BitDefender Scan Server\bdc.exe" ???
Maar ook hier moeten nog parameters achter, maar hoe lukt me niet.
Kan iemand me hier een helder antwoord op geven?
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Titel aangepast: Het helpt als je de naam van het programma er in zet; een algemene cursus commandline kan je beter zelf opzoeken & volgen ;)
In dit geval: zo'n programma verwacht ongetwijfelt dat alleen het specifieke gedownloade bestand wordt gescanned. /list zal niet helpen want je wilt geen lijst van bestanden, /all wil je niet want de hele HDD scannen per bestand gedownload is wat overdone. Wat je wel wilt, is specifiek het gedownloade bestand.
Hoe het gedownloade bestand wordt meegegeven als paramater hangt van je downloadprog af, zie de handleiding daarvan. Maar als parameter alleen %1 zou ik niet vreemd vinden.
Dat is het nou juist, het is een gratis tooltje en dit is alles uit de handleiding dat ik kon vinden, ik heb al %1 en gewoon /files gebruikt, maar er gebeurde niks.
Ik heb ook echt geen idee hoe zo'n command lijn er dan uit zou moeten zien.
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Hoe de betsandsnaam / lokatie wordt doorgegeven staat in de handleiding van juist je downloadprogramma.
De rest: probeer het vanaf de commandline en je ziet wat er gebeurt: doe eens bdc c:\bla\bfoo.exe en je weet of dat wat doet, eventueel herhalen met aanhalingstekens om c:\bla\foo.exe als er een spatie in de naam staat. En natuurlijk een echt bestand voor foo.exe gebruiken :+
Het gaat vooruit, ik ben ff aan MSN begonnen en na wat aanrommelen kreeg ik de goede command lijn aan de praat.
Deze is het:
"C:\Program Files\Common Files\SOFTWIN\BitDefender Scan Server\bdc.exe" -files %1 -log=c:\avlog.txt -all -arc -boot -prompt
Hij scant het bestand dat binnenkomt, logt de gegevens in avlog.txt, scant alle bestanden (dus niet alleen exe bat com, ook jpg txt), scant IN zip/rar/etc-bestanden, het mbr en vraagt wat te doen als hij een virus vindt.
Dat is precies zoals ik het wil...
Ok, maar nu Internet Download Manager, dat lukt dus niet.
Hij heeft 2 vakken.
- Virus scanner programma
- Command lijn parameters
Hoe vul ik dit hier in?
