Samba3 PDC HOWTO SuSE [office]
Ooh nee nog een samba3 PDC HOWTO...
Nou een aantal van de pdc howto's op GoT waren op dusdanig niveau dat ik het niet kon laten.
Hier is mijn samba3 PDC HOWTO voor office gebruik (SuSE GNU/linux)
Download/install packeges
Download and install the samba3 packages for SuSE at:
ftp.suse.com /pub/projects/samba/3.0
rpm -Uvh package.rpm
start the samba (smb) and nmb server
rcsmb start|restart
rcnmb start|restart
Configure your smb.conf
example
edit for your situation (check file/program/vars locations)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
[global]
        ; Global settings...
                workgroup = DOMAIN
                netbios name = SERVERNAME
                server string = on %L
                log file = /var/log/samba.log
                log level = 2
        ; Domain settings...
                domain logons = yes
                os level = 65
                preferred master = yes
                domain master = yes
                wins support = yes
        ; Authoristation settings...
                ; passdb backend = smbpasswd
                passdb backend = tdbsam
                encrypt passwords = yes
                unix password sync = Yes
                passwd program = /usr/bin/passwd %u
                passwd chat = *New*password* %n\n *Retype*new*password* %n\n \
                *password:*all*authentication*tokens*updated*successfully
                Pam password change = yes
                username map = /etc/samba/smbusers
                add user script = /usr/sbin/useradd -m %u -c "domain users" -g users
                delete user script = /usr/sbin/userdel -r %u
                add group script = /usr/sbin/groupadd %g
                set primary group script = /usr/sbin/usermod -g %g %u
                delete group script = /usr/sbin/groupdel %g
                add user to group script = /usr/sbin/usermod -G %g %u
                delete user from group script = /var/lib/samba/bin/gpasswd -d %u %g
                add machine script = /usr/sbin/useradd -r -c "machineaccount" -g machines -s /bin/false \
                -d /var/tmp/ %u
                ; template homedir = /home/%D/%U
                logon script = scripts\%g.bat
                logon path = \\%L\profiles\%U
                logon drive = H:
                logon home = \\%L\%U
        ; Security settings...
                bind interfaces only = yes
                interfaces = 10.1.0.15/24
                hosts allow = 10.1.0.0/24 127.0.0.1
                ; hosts deny =
                max connections = 10
                security = user
                ; security = domain
                null passwords = no
                guest account = nobody
                map to guest = Bad User
                admin users = admin
                ; invalid users =
        ; File settings
                hide dot files = yes
                hide unreadable = yes
                hide files = /desktop.ini/
                ; max disk size = 1000
        ; Other...
                time server = yes
                idmap uid = 15000-20000
                idmap gid = 15000-20000
        ; Printing settings...
                printing = cups
                printcap name = cups
                printcap cache time = 750
                cups options = raw
                printer admin = username
; Default Shares...
[homes]
        comment = Home Directories
        valid users = %S
        read only = No
        browseable = No
        inherit permissions = yes
        ; veto files =
[profiles]
        comment = Roaming Profile Share
        path = /home/profiles/.winprofiles
        read only = No
        profile acls = yes
        browseable = No
[netlogon]
        comment = Network Logon Service
        path = /var/lib/samba/netlogon
        max connections = 15
        ; admin users = admin
        invalid users = root
        guest ok = no
        browseable = no
[users]
        comment = All users
        path = /home
        read only = no
        veto files = /aquota.user/groups/shares/
        valid users = username
[pdf]
        comment = PDF creator
        path = /var/tmp
        printable = Yes
        print command = /usr/bin/smbprngenpdf -J '%J' -c %c -s %s -u '%u' -z %z
        create mask = 0600
[printers]
        comment = All Printers
        path = /var/tmp
        printable = Yes
        create mask = 0600
        browseable = Yes
[print$]
        comment = Printer Drivers
        path = /var/lib/samba/drivers
        write list = @ntadmin root
        force group = ntadmin
        create mask = 0664
        directory mask = 0775
; Organisation shares...
[documents]
        comment = Users Data
        browseable = yes
        read only = no
        create mode = 0775
        force create mode = 0775
        force directory mode = 0775
        path = /files/data
        users = @groupname
[software]
        comment = Software
        browseable = yes
        read only = yes
        path = /files/software
        valid users = @groupname
[root]
        comment = Servers root
        browseable = no
        read only = no
        create mode = 0664
        path = /
Check your smb.conf
testparm
restart both smb and nmb demons
rcsmb restart
rcnmb restart
Create groups/users with your favorite tool (eg. YAST)
create group for the Domain Admin user(s) eg. ntadmins
create custom group(s) eg. organisationname
map unix groups to nt groups (users -> (Domain Users) and ntadmins -> (Domain Admins), etc)
net groupmap modify ntgroup="Domain Admins" unixgroup=ntadmins
net groupmap modify ntgroup="Domain Users"  unixgroup=users
net groupmap modify ntgroup="Domain Guests" unixgroup=nobody
net groupmap add ntgroup="organisationname" unixgroup=organistationname
check config
net groupmap list
create linux and smb root/admin user
create admin users with ntadmin group gid (default group)
eg. user: admin with default group: ntadmin (wich is mapped to Domain admin)
create root entry in your smbpasswd database (smbpasswd/tdbsam) needed to add machines to join domain. (use differend pwd for securtry reasons)
smbpasswd -a root or pdbedit -a -u root
to convert your smbpasswd file to and tdbsam backend execute
pdbedit -i smbpasswd -e tdbsam
edit yout smbusers (map to unix users)
root = administrator
nobody = guest pcguest smbguest
Make directory for the location of the login script and create directory for the roaming profiles (eg. /home/profiles/.winprofile)
mkdir -p /var/lib/samba/netlogon/scripts
mkdir -p /home/profiles/.winprofile (be sure it's writeable for the Domain User group (users(linuxgroup))
Create logon script
users.bat (/var/lib/samba/netlogon/scripts/users.bat)
echo Mapping Network Drives to Server...
net use f: \\netbiosname\documents
net time \\netbiosname /SET /YES
Add windows box to the domain
First excecute a registry hack (winxp) click
Its windows so reboot..
Network settings
Check your tcp/ip settings!
if you are using wins support add the serverip to the wins server list
Join domain
When the loginbox pops up login with the user root and its pwd
If sucseeded reboot again
login with your admin user (Domain Admin) for creating users and group (srvtools)
login with a normal user for normal operation
Windows/samba network management
download nt4 domain management tool (srvtools)
login as your domain admin users install the tool (srvtools.exe), now you can create/assign users and groups
Toelichting...
Met het bovenstaande voorbeeld heb je bij een succesvolle afronding een domein. een domein admin user, en een aanmelding procedure met roaming profiles en beheer functionalitied doormiddlen van de srvtools (server en user management).
todo
policies
note
for SuSE 9.1 find an older version of the gpasswd program. Since 9.1 gpasswd can only be used tot changen a group password. So 9.1 users edit your delete user from group scripts, download and point it to an older version op gpasswd (eg /var/lib/samba/bin/gpasswd
References
The Official Samba-3 HOWTO and Reference Guide
man smb.conf
[ Voor 10% gewijzigd door Verwijderd op 17-06-2004 12:29 . Reden: machine worden nu toegevoegd als system users ]
Bug/probleem:
Bij het toevoegen van een user via usrmng (User Management (srvtools)) via de "new user" optie wordt er geen login script en profile locatie ect aangemaakt.
Copieer je echter een user dan neem usermng netjes deze settings over en vervangt hij de vars met %USERNAME% (je kriijgt wel een melding dan je de home dir handmatig moet aanmaken naar dat gaat wel goed)
Weet iemand of is het uberhaubt mogelijk het aanmaken van een profile dir en een login scriipt referentie af te vangen in smb.conf voor het aanmaken van nieuwe users vie usrmng?
  • Zym0tiC
  • Laatst online: 26-10 18:58
Zym0tiC
^_^
Voor een beginnende gebruiker zal dit vaak nog zeer verwarrend zijn. In principe is het niet meer dan je smb.conf posten. Voor een echt goede howto verwijs ik mensen liever naar:
http://www-106.ibm.com/de...utorials/samba/index.html waar een hoop uitleg bij de commando's staat gegeven. Aan de hand van deze tut had ik binnen 30 minuten een draaiende PDC
niet kwaad bedoeld ofzo :)
[ Voor 7% gewijzigd door Zym0tiC op 14-06-2004 13:15 ]
There is no such thing as innocence, only degrees of guilt | Flickr!
Zym0tiC schreef op 14 juni 2004 @ 13:14:
De howto van IBM is idd vrij ok, ibm heeft veel goede howto (unix rechten ect)
Ik heb deze howto ook niet geschreven voor de beginnende users. het is eingelijk meer een checklist voor een wat gevordere gebruiker. (no offence voor de beginnnede gebruiker maar ik zou me in hun geval eerste verdiepen in samba shares/workgroups)
Ik hoopte alleen het niveau een beetje op te krikken door niet stap voor stap alles uit te leggen (unix users en groups aanmaken ect) maar gewoon de basis stappen voor een PDC met een uitgebreide smb.conf.
Het voordeel van mijn config is dat er wat praktische gedrag en voorbeelden in zitten. Denk aan de add user/group/machine regels
Even een vraag voor de windows admin;
Is het mogelijk via een domain, een user local admin rechten te geven. Nu geeft je iemand Domain admin rechten. maar ik zoek eingelijk een manier om via smb een users op de machine waar deze inlog locaal admin rechten te geven.
Wie kan mij dit vertellen?
  • CH4OS
CH4OS
It's a kind of magic
Verwijderd schreef op 16 juni 2004 @ 10:53:
Dit kan. Dat moet je wel aangeven als je je de eerste keer aanmeld op het domein. Dan staat de gebruiker lokaal als administrator, en in het domein als gebruiker :)
Weet alleen niet hoe het moet in SMB
Maar waarom is de howto in het Engels? O+
GJ-tje schreef op 16 juni 2004 @ 11:00:
Nou het is eingelijk een stappenplan wat ik heb gemaakt en gedocumenteerd. Dit heb ik voor een klant gedaan (smb pdc) en vervolgens in onze online docmentatie gehangen wat we dus weer in engels doen.
Maar de meeste nederlanders kunnen een woordje engels niet..... ;)
dus waarom niet.. :*)
Maar thanks voor je reactie, dus als ik een gebruiker die al admin is aanmeld in het domain voor de eerste keer dan heeft deze locaal nog steeds de admin rechten.. Klinkt logische inderdaad.
(kick)
kan iemand mij verstellen hoe ik een domein gebruiker locaal admin rechten geeft in de bovenstaande cominatie
Thanks!
  • Bas!
  • Laatst online: 26-07 22:06
Waarom er niet geantwoord wordt heeft denk ik te maken met het feit dat je niet de enige bent die dit wil en dus dat google je vriend is.
Bovendien is dit heel eenvoudig als je dit op het locale workstation doet.
  • _JGC_
Verwijderd schreef op 17 juni 2004 @ 13:40:
(kick)
Thanks!
Je voegt op je lokale machine de domain user toe aan de Administrators groep van die machine, is nix moeilijks aan toch? Deed ik ook altijd om domain admins ook admin te maken op win2k machines, mn groupmappings zijn nooit goed geweest, totdat ik migratie heb gedaan naar samba 3.0 :)
_JGC_ schreef op 17 juni 2004 @ 16:35:
Oke, dit is vrij duidelijk misschien was ik wat onduidelijker met;
Wat ik dus zoek een een mogelijkheid dit globaal te beheren. Kijk bij een thuis netwerk met 3 pc is dit geen probleem. Maar zakelijk heb ik geen behoefte dit soort dingen locaal per machine te regelen.
Het wat ook al weer een tijdje geleden dat ik me in windows domein rechten/pols heb zitten spelen.
windos |:( doe bij maar ietst met unix ;)
  • _JGC_
Mja, daar is je domain administrators group voor. Andere mogelijkheid is er ook nog: je maakt een extra groep aan, en deze groep wijs je op elke PC toe. Vervolgens kan je centraal users aan de groep toevoegen.
Ik kan begrijpen dat je niet wilt dat een domain administrator die wel op een workstation dingen mag installeren, niet dingen op een server aan mag passen. Volgens mij kan je dat op die server ook wel instellen, dat je zo iemand niet in je server wilt.
