• willem7q
Dit lijkt mij de ideale mp3-speler door de combinatie van usb 2.0 en uitbreidbaar geheugen met SD, maar ik kan er maar weinig informatie over vinden, vandaar dit topic:
PDP 2325
Afbeeldingslocatie: http://www.thomson-europe.be/images/TNE/pdfcontent/images/l_pdp2325.jpg
* mp3 / mp3PRO* / WMA Playback : Plays back mp3, mp3PRO* and Windows Microsoft Audio (WMA) files
* 128 MB Flash Memory : Stores up to 4hours of mp3PRO* music encoded @64 kbps as well as being a data storage device. No moving parts for skipless audio playback
* Digital FM Tuner with FM Record : Record while listening to a FM station in mp3 format. At a later date you can upload your mp3 file to a PC for personal use
* High Speed USB 2.0* : Up to 40x faster than standard USB
* Extended battery life : Up to 50 hours continuous playback on one "AA" battery
* External SD/MMC Slot for Expandable Memory : Expandable memory with the use of additional memory cards (SD/MMC - cards not included)
* Backlit Multi-line LCD Display : Multi-line display lists name of artist, song, elapsed time, volume level, and battery level indicator when in playback mode. Backlit display enhances visibility in low lighting
* Full Accessory Kit included Includes: CD-ROM Music Management Software, USB cable, sports armband, and e.clipz Clip-on headphones, 1 "AAA" Alkaline battery
Family: mp3 Player
Tuner: Stereo FM
Digitale/Analogic Tuner: mp3 encoding
Stations voorkeuren: 10
Hoofdtelefoonaansluiting: 3,5 mm
Batterij indicator: Yes
Knoppen vergrendeling: Yes
Speelduur batterijen in uren: up to 50 hours
Draagbare MP3 Audiospeler: Yes
Sub Brand: THOMSON LYRA
Software: MusicMatch
Music Transfer: USB cable PC / Pocket Lyra
Headphones: e.clipz earphones
External memory format: MMC, SD
On board memory format: 128
USB port: Yes
Hard disk space: 50 MB for software only
Required OS PC/MAC: Win 98SE, Me, 2000 & XP / Mac OSX ver 10.1.5 or higher
Sound card: Yes
DSP: 5 modes
Compatibility: mp3 + mp3Pro + WMA
Display Type : Large LCD
Backlight: yes
Computer connection: USB cable
Computer compatibility: PC + Mac
De PDP 2335 is hetzelfde met 256 Mb en andere kleurtjes
PDP 2444
Afbeeldingslocatie: http://www.thomson-europe.be/images/TNE/pdfcontent/images/m_pdp2444.jpg
* Ultra compact size
* On-board 64 MB flash memory and external slot for removable memory card (not supplied)
* Combines internal and external flash memory to expand the storage capacity
* mp3, mp3PRO and WMA playback to get more than 2 hour of music with the 64 MB on-board flash memory
* Can store any type of computer files (Word, Excel, jpeg ...). This can also be used as an external data storage
* "Plug and play" : the player is automatically recognized by the PC
* Large alphanumeric display : user friendly display with an easy reading
Family: mp3 Player
Afmetingen : hoogte / breedte / diepte in mm: 55 x 50 x 20
Stroomvoorziening: batteries
On board memory format: 64
Gewicht (Net/Gross) in kg: 0,05 / 0,7
USB port: Yes
Hard disk space: 6 MB
Required OS PC/MAC: Windows 98, Me, 2000 & XP
Sound card: Yes
DSP: 5 modes
Computer connection: USB direct
Batteries: 1 x AAA Duracell
De PDP 2448 is hetzelfde met 128 Mb en andere kleurtjes
De grootste verschillen zijn dus radio+direct encoding / geen radio en geen direct encoding, usb1.1/2.0 (?), hoeveelheid geheugen.
Wat mij nog niet helemaal duidelijk is:
  • (1) Is de PDP 23X5 plug and play? (staat er niet in die woorden bij, er staat wel "as well as being a data storage device"). (2) Heeft de PDP 244X usb 2.0? (ik denk het niet, anders zou het er wel bij staan) (3) Zit er een maximum op die uitbreiding met SD? Stel dat ze ooit een kaartje van 2GB maken, kan dat er dan in?
En verder: heeft iemand ze al (getest)? Of algemene ervaringen over Thomson?
meer info
http://www.thomson-europe.nl/ > producten > Hifi-Audio > Family = mp3 Player - Draagbare mp3 Audiospeler = yes > toepassen
  • willem7q
Mailtje gestuurd naar Thomson:
vragen
  • (1) Is the PDP23X5 automatically detected as an external storage device in WinXP? (2) Can the PDP244X transfer files at USB 2.0 speed? (3) Is there a maximum capacity for the SD-slots? For example, when there are 2GB SD-cards in the futere, can I use them with the PDP23X5 / PDP244X ? (4) What version of ID3-tags is supported?
antwoorden
  • 1) Both pdp2325/35 are automatically detected as an external storage device in WinXP? 2) Only the PDP2444 3) Max size is 256Mo 4) It is version 2 for ID3-tags.
Die 256Mb is wel weinig...
Ik geloof dat ik eens gelezen heb dat dat bij CF-kaartjes anders is: daar zit er een soort processor in het kaartje waardoor de maximumcapaciteit niet afhankelijk is van het toestel, maar enkel van het kaartje. Weet iemand daar meer over?
