[Debian woody][Apache 1.3] Server wil niet starten.
  • 1.115 views sinds 30-01-2008
Ik heb via apt-get install apache geprobeert apache te installeren.
Dat ging zo:
29
30
31
32
33
34
35
36
37
38
boom:/# apt-get install apache
Reading Package Lists... Done
Building Dependency Tree... Done
The following NEW packages will be installed:
  apache
0 packages upgraded, 1 newly installed, 0 to remove and 0  not upgraded.
Need to get 0B/353kB of archives. After unpacking 770kB will be used.
Selecting previously deselected package apache.
(Reading database ... 18313 files and directories currently installed.)
Unpacking apache (from .../apache_1.3.26-0woody3_i386.deb) ...
Setting up apache (1.3.26-0woody3) ...
Installing new configuration file /etc/apache/httpd.conf ...
An Apache configuration exists, but needs some tweaking.
Your config files will not be modified until you select Y at "save changes."
The ServerAdmin is set to webmaster@boom.
The DocumentRoot is set to /var/www.
Leaving existing site /var/www/index.php untouched.
Finding DSO mods.found.
Pondering. done.
Save these changes to the configuration files? [Y/n] Y
Rotated `/etc/apache/httpd.conf' at Fri Jun 11 15:49:01 CEST 2004.
Rotated `/etc/apache/srm.conf' at Fri Jun 11 15:49:01 CEST 2004.
Restart Apache now? [Y/n] Y
Syntax error on line 211 of /etc/apache/httpd.conf:
Invalid command 'ExtendedStatus', perhaps mis-spelled or defined by a module not included in the server configuration
/usr/sbin/apachectl start: httpd could not be started
Configuration failed!  Run "apacheconfig" to try this again later.
Reloading apache modulesNo process in pidfile `/var/run/apache.pid' found running; none killed.
failed
Daarna heb ik in httpd.conf ServerAdmin ge-edit ( mijn email adres er achter gezet) en bij ServerName m'n IP.
Daarna nog eens /usr/sbin/apachectl configtest
response:
boom:/var/log/apache# /usr/sbin/apachectl configtest
Syntax error on line 212 of /etc/apache/httpd.conf:
bij ExtendedStatus staat On (ExtendedStatus On)
Ik geloof dat het tijdens de installatie al fout gaat maar ik snap niet waarom, ik haal apache gelijk van debian dus zou volgens mij moeten werken.
Wie snapt hier meer van dan ik.. ben aardig nieuw in linux.
  • IceM
  • Laatst online: 22-08 14:31
Maak van
ExtendedStatus On
eens
#ExtendedStatus On
Bij mij staat hij uit, en werkt alles naar behoren. Als hij nu nog een syntax error geeft hier is er inderdaad iets goed mis.
Als ik dat doe dan gaat een paar regels later weer zeuren:
Syntax error on line 326 of /etc/apache/httpd.conf:
Invalid command 'Order', perhaps mis-spelled or defined by a module not included in the server configuration
en als ik daar een # voor zet gaatie weer verder, ik denk de hele code door :S
  • Robert
  • Laatst online: 21-08 22:04
Robert
You have your answer..
laat httpd.conf dan eens zien, w.s. zit er een foutje vlak boven ExtendedStatus
Just 'cause I'm paranoid doesn't mean they're not after me | The only operating system that does what you want: LFS
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
## httpd.conf -- Apache HTTP server configuration file
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://www.apache.org/docs/> for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# After this file is processed, the server will look for and process
# /etc/apache/srm.conf and then /etc/apache/access.conf
# unless you have overridden these with ResourceConfig and/or
# AccessConfig directives here.
# The configuration directives are grouped into three basic sections:
#  1. Directives that control the operation of the Apache server process as a
#     whole (the 'global environment').
#  2. Directives that define the parameters of the 'main' or 'default' server,
#     which responds to requests that aren't handled by a virtual host.
#     These directives also provide default values for the settings
#     of all virtual hosts.
#  3. Settings for virtual hosts, which allow Web requests to be sent to
#     different IP addresses or hostnames and have them handled by the
#     same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
# with ServerRoot set to "/usr/local/apache" will be interpreted by the
# server as "/usr/local/apache/logs/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerType is either inetd, or standalone.  Inetd mode is only supported on
# Unix platforms.
ServerType standalone
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept, unless they are specified
# with an absolute path.
# NOTE!  If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation
# (available at <URL:http://www.apache.org/docs/mod/core.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
ServerRoot /etc/apache
# The LockFile directive sets the path to the lockfile used when Apache
# is compiled with either USE_FCNTL_SERIALIZED_ACCEPT or
# USE_FLOCK_SERIALIZED_ACCEPT. This directive should normally be left at
# its default value. The main reason for changing it is if the logs
# directory is NFS mounted, since the lockfile MUST BE STORED ON A LOCAL
# DISK. The PID of the main server process is automatically appended to
# the filename.
LockFile /var/lock/apache.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
PidFile /var/run/apache.pid
# ScoreBoardFile: File used to store internal server process information.
# Not all architectures require this.  But if yours does (you'll know because
# this file will be  created when you run Apache) then you *must* ensure that
# no two invocations of Apache share the same scoreboard file.
ScoreBoardFile /var/run/apache.scoreboard
# In the standard configuration, the server will process this file,
# srm.conf, and access.conf in that order.  The latter two files are
# now distributed empty, as it is recommended that all directives
# be kept in a single file for simplicity.  The commented-out values
# below are the built-in defaults.  You can have the server ignore
# these files altogether by using "/dev/null" (for Unix) or
# "nul" (for Win32) for the arguments to the directives.
#ResourceConfig /etc/apache/srm.conf
#AccessConfig /etc/apache/access.conf
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
# Server-pool size regulation.  Rather than making you guess how many
# server processes you need, Apache dynamically adapts to the load it
# sees --- that is, it tries to maintain enough server processes to
# handle the current load, plus a few spare servers to handle transient
# load spikes (e.g., multiple simultaneous requests from a single
# Netscape browser).
# It does this by periodically checking how many servers are waiting
# for a request.  If there are fewer than MinSpareServers, it creates
# a new spare.  If there are more than MaxSpareServers, some of the
# spares die off.  The default values are probably OK for most sites.
MinSpareServers 5
MaxSpareServers 10
# Number of servers to start initially --- should be a reasonable ballpark
# figure.
StartServers 5
# Limit on total number of servers running, i.e., limit on the number
# of clients who can simultaneously connect --- if this limit is ever
# reached, clients will be LOCKED OUT, so it should NOT BE SET TOO LOW.
# It is intended mainly as a brake to keep a runaway server from taking
# the system with it as it spirals down...
MaxClients 150
# MaxRequestsPerChild: the number of requests each child process is
# allowed to process before the child dies.  The child will exit so
# as to avoid problems after prolonged use when Apache (and maybe the
# libraries it uses) leak memory or other resources.  On most systems, this
# isn't really needed, but a few (such as Solaris) do have notable leaks
# in the libraries. For these platforms, set to something like 10000
# or so; a setting of 0 means unlimited.
# NOTE: This value does not include keepalive requests after the initial
#       request per connection. For example, if a child process handles
#       an initial request and 10 subsequent "keptalive" requests, it
#       would only count as 1 request towards this limit.
MaxRequestsPerChild 100
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, in addition to the default. See also the <VirtualHost>
# directive.
#Listen 3000
#Listen 12.34.56.78:80
# BindAddress: You can support virtual hosts with this option. This directive
# is used to tell the server which IP address to listen to. It can either
# contain "*", an IP address, or a fully qualified Internet domain name.
# See also the <VirtualHost> and Listen directives.
#BindAddress *
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Please read the file README.DSO in the Apache 1.3 distribution for more
# details about the DSO mechanism and run `apache -l' for the list of already
# built-in (statically linked and thus always available) modules in your apache
# binary.
# Please keep this LoadModule: line here, it is needed for installation.
# ExtendedStatus: controls whether Apache will generate "full" status
# information (ExtendedStatus On) or just basic information (ExtendedStatus
# Off) when the "server-status" handler is called. The default is Off.
#ExtendedStatus On
### Section 2: 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# If your ServerType directive (set earlier in the 'Global Environment'
# section) is set to "inetd", the next few directives don't have any
# effect since their settings are defined by the inetd configuration.
# Skip ahead to the ServerAdmin directive.
# Port: The port to which the standalone server listens. For
# ports < 1023, you will need apache to be run as root initially.
Port 80
# If you wish apache to run as a different user or group, you must run
# apacheas root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run apache as.
#  . On SCO (ODT 3) use "User nouser" and "Group nogroup".
#  . On HPUX you may not be able to use shared memory as nobody, and the
#    suggested workaround is to create a user www and use that user.
#  NOTE that some kernels refuse to setgid(Group) or semctl(IPC_SET)
#  when the value of (unsigned)Group is above 60000;
#  don't use Group nobody on these systems!
User www-data
Group www-data
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.
ServerAdmin blablabla
# ServerName: allows you to set a host name which is sent back to clients for
# your server if it's different than the one the program would get (i.e., use
# "www" instead of the host's real name).
# Note: You cannot just invent host names and hope they work. The name you
# define here must be a valid DNS name for your host. If you don't understand
# this, ask your network administrator.
# If your host doesn't have a registered DNS name, enter its IP address here.
# You will have to access it by its address (e.g., http://123.45.67.89/)
# anyway, and this will make redirections work in a sensible way.
ServerName ip-adres
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot /var/www
# Each directory to which Apache has access, can be configured with respect
# to which services and features are allowed and/or disabled in that
# directory (and its subdirectories).
# First, we configure the "default" to be a very restrictive set of
# permissions.
<Directory />
    Options SymLinksIfOwnerMatch
    AllowOverride None
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# This should be changed to whatever you set DocumentRoot to.
<Directory /var/www/>
# This may also be "None", "All", or any combination of "Indexes",
# "Includes", "FollowSymLinks", "ExecCGI", or "MultiViews".
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
    Options Indexes Includes FollowSymLinks MultiViews
# This controls which options the .htaccess files in directories can
# override. Can also be "All", or any combination of "Options", "FileInfo",
# "AuthConfig", and "Limit"
    AllowOverride None
# Controls who can get stuff from this server.
    Order allow,deny
    Allow from all
</Directory>
# UserDir: The name of the directory which is appended onto a user's home
# directory if a ~user request is received.
<IfModule mod_userdir.c>
    UserDir public_html
</IfModule>
# Control access to UserDir directories.  The following is an example
# for a site where these directories are restricted to read-only.
<Directory /home/*/public_html>
    AllowOverride FileInfo AuthConfig Limit
    Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
    <Limit GET POST OPTIONS PROPFIND>
        Order allow,deny
        Allow from all
    </Limit>
    <Limit PUT DELETE PATCH PROPPATCH MKCOL COPY MOVE LOCK UNLOCK>
        Order deny,allow
        Deny from all
    </Limit>
</Directory>
# DirectoryIndex: Name of the file or files to use as a pre-written HTML
# directory index.  Separate multiple entries with spaces.
<IfModule mod_dir.c>
    DirectoryIndex index.html index.htm index.shtml index.cgi
</IfModule>
# AccessFileName: The name of the file to look for in each directory
# for access control information.
AccessFileName .htaccess
# The following lines prevent .htaccess files from being viewed by
# Web clients.  Since .htaccess files often contain authorization
# information, access is disallowed for security reasons.  Comment
# these lines out if you want Web visitors to see the contents of
# .htaccess files.  If you change the AccessFileName directive above,
# be sure to make the corresponding changes here.
# Also, folks tend to use names such as .htpasswd for password
# files, so this will protect those as well.
<Files ~ "^\.ht">
    Order allow,deny
    Deny from all
</Files>
# CacheNegotiatedDocs: By default, Apache sends "Pragma: no-cache" with each
# document that was negotiated on the basis of content. This asks proxy
# servers not to cache the document. Uncommenting the following line disables
# this behavior, and proxies will be allowed to cache the documents.
#CacheNegotiatedDocs
# UseCanonicalName:  (new for 1.3)  With this setting turned on, whenever
# Apache needs to construct a self-referencing URL (a URL that refers back
# to the server the response is coming from) it will use ServerName and
# Port to form a "canonical" name.  With this setting off, Apache will
# use the hostname:port that the client supplied, when possible.  This
# also affects SERVER_NAME and SERVER_PORT in CGI scripts.
UseCanonicalName On
# TypesConfig describes where the mime.types file (or equivalent) is
# to be found.
TypesConfig /etc/mime.types
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value.  If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
# mod_mime_magic is not part of the default server (you have to add
# it yourself with a LoadModule [see the DSO paragraph in the 'Global
# Environment' section], or recompile the server and include mod_mime_magic
# as part of the configuration), so it's enclosed in an <IfModule> container.
# This means that the MIMEMagicFile directive will only be processed if the
# module is part of the server.
<IfModule mod_mime_magic.c>
    MIMEMagicFile share/magic
</IfModule>
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# Note that Log files are now rotated by logrotate, not by apache itself.
# This means that apache no longer attempts to magically determine
# where your log files are kept; you have to fill out stanzas in
# /etc/logrotate.d/apache yourself.
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog /var/log/apache/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %T %v" full
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %P %T" debug
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here.  Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
#CustomLog /var/log/apache/access.log common
# If you would like to have agent and referer logfiles, uncomment the
# following directives.
#CustomLog /var/log/apache/referer.log referer
#CustomLog /var/log/apache/agent.log agent
# If you prefer a single logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
CustomLog /var/log/apache/access.log combined
# Optionally add a line containing the server version and virtual host
# name to server-generated pages (error documents, FTP directory listings,
# mod_status and mod_info output etc., but not CGI generated documents).
# Set to "EMail" to also include a mailto: link to the ServerAdmin.
# Set to one of:  On | Off | EMail
ServerSignature On
# Aliases: Add here as many aliases as you need (with no limit). The format is
# Alias fakename realname
# Note that if you include a trailing / on fakename then the server will
# require it to be present in the URL.  So "/icons" isn't aliased in this
# example, only "/icons/"..
Alias /icons/ /usr/share/apache/icons/
<Directory /usr/share/apache/icons>
    Options Indexes MultiViews
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the realname directory are treated as applications and
# run by the server when requested rather than as documents sent to the client.
# The same rules about trailing "/" apply to ScriptAlias directives as to
# Alias.
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
# "/usr/lib/cgi-bin" could be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory /usr/lib/cgi-bin/>
    AllowOverride None
    Options ExecCGI
    Order allow,deny
    Allow from all
</Directory>
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Format: Redirect old-URI new-URL
# Directives controlling the display of server-generated directory listings.
<IfModule mod_autoindex.c>
    # FancyIndexing: whether you want fancy directory indexing or standard
    IndexOptions FancyIndexing NameWidth=*
    # AddIcon* directives tell the server which icon to show for different
    # files or filename extensions.  These are only displayed for
    # FancyIndexed directories.
    AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
    AddIconByType (TXT,/icons/text.gif) text/*
    AddIconByType (IMG,/icons/image2.gif) image/*
    AddIconByType (SND,/icons/sound2.gif) audio/*
    AddIconByType (VID,/icons/movie.gif) video/*
    AddIcon /icons/binary.gif .bin .exe
    AddIcon /icons/binhex.gif .hqx
    AddIcon /icons/tar.gif .tar
    AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
    AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
    AddIcon /icons/a.gif .ps .ai .eps
    AddIcon /icons/layout.gif .html .shtml .htm .pdf
    AddIcon /icons/text.gif .txt
    AddIcon /icons/c.gif .c
    AddIcon /icons/p.gif .pl .py
    AddIcon /icons/f.gif .for
    AddIcon /icons/dvi.gif .dvi
    AddIcon /icons/uuencoded.gif .uu
    AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
    AddIcon /icons/tex.gif .tex
    AddIcon /icons/bomb.gif core
    AddIcon /icons/deb.gif .deb
    AddIcon /icons/back.gif ..
    AddIcon /icons/hand.right.gif README
    AddIcon /icons/folder.gif ^^DIRECTORY^^
    AddIcon /icons/blank.gif ^^BLANKICON^^
    # DefaultIcon: which icon to show for files which do not have an icon
    # explicitly set.
    DefaultIcon /icons/unknown.gif
    # AddDescription: allows you to place a short description after a file in
    # server-generated indexes.  These are only displayed for FancyIndexed
    # directories.
    # Format: AddDescription "description" filename
    #AddDescription "GZIP compressed document" .gz
    #AddDescription "tar archive" .tar
    #AddDescription "GZIP compressed tar archive" .tgz
    # ReadmeName: the name of the README file the server will look for by
    # default, and append to directory listings.
    # HeaderName: the name of a file which should be prepended to
    # directory indexes.
    # The server will first look for name.html and include it if found.
    # If name.html doesn't exist, the server will then look for name.txt
    # and include it as plaintext if found.
    ReadmeName README
    HeaderName HEADER
    # IndexIgnore: a set of filenames which directory indexing should ignore
    # and not include in the listing.  Shell-style wildcarding is permitted.
    IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
</IfModule>
# Document types.
<IfModule mod_mime.c>
    # AddEncoding allows you to have certain browsers (Mosaic/X 2.1+)
    # uncompress information on the fly. Note: Not all browsers support
    # this.  Despite the name similarity, the following Add* directives
    # have nothing to do with the FancyIndexing customization
    # directives above.
    AddEncoding x-compress Z
    AddEncoding x-gzip gz tgz
    # AddLanguage: allows you to specify the language of a document. You can
    # then use content negotiation to give a browser a file in a language
    # it can understand.
    # Note 1: The suffix does not have to be the same as the language
    # keyword --- those with documents in Polish (whose net-standard
    # language code is pl) may wish to use "AddLanguage pl .po" to
    # avoid the ambiguity with the common suffix for perl scripts.
    # Note 2: The example entries below illustrate that in quite
    # some cases the two character 'Language' abbriviation is not
    # identical to the two character 'Country' code for its country,
    # E.g. 'Danmark/dk' versus 'Danish/da'.
    # Note 3: In the case of 'ltz' we violate the RFC by using a three char
    # specifier. But there is 'work in progress' to fix this and get
    # the reference data for rfc1766 cleaned up.
    # Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
    # French (fr) - German (de) - Greek-Modern (el)
    # Italian (it) - Portugese (pt) - Luxembourgeois* (ltz)
    # Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cz)
    # Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
    AddLanguage da .dk
    AddLanguage nl .nl
    AddLanguage en .en
    AddLanguage et .ee
    AddLanguage fr .fr
    AddLanguage de .de
    AddLanguage el .el
    AddLanguage it .it
    AddLanguage ja .ja
    AddCharset ISO-2022-JP .jis
    AddLanguage pl .po
    AddCharset ISO-8859-2 .iso-pl
    AddLanguage pt .pt
    AddLanguage pt-br .pt-br
    AddLanguage ltz .lu
    AddLanguage ca .ca
    AddLanguage es .es
    AddLanguage sv .se
    AddLanguage cz .cz
    # LanguagePriority: allows you to give precedence to some languages
    # in case of a tie during content negotiation.
    # Just list the languages in decreasing order of preference. We have
    # more or less alphabetized them here. You probably want to change
    # this.
    <IfModule mod_negotiation.c>
        LanguagePriority en da nl et fr de el it ja pl pt pt-br ltz ca es sv
    </IfModule>
    # AddType allows you to tweak mime.types without actually editing
    # it, or to make certain files to be certain types.
    # For example, the PHP 3.x module (not part of the Apache
    # distribution - see http://www.php.net) will typically use:
    #AddType application/x-httpd-php3 .php3
    #AddType application/x-httpd-php3-source .phps
    # And for PHP 4.x, use:
    #AddType application/x-httpd-php .php
    #AddType application/x-httpd-php-source .phps
    AddType application/x-tar .tgz
    AddType image/bmp .bmp
    # hdml
    AddType text/x-hdml .hdml
    # AddHandler allows you to map certain file extensions to "handlers",
    # actions unrelated to filetype. These can be either built into
    # the server or added with the Action command (see below).
    # If you want to use server side includes, or CGI outside
    # ScriptAliased directories, uncomment the following lines.
    # To use CGI scripts:
    #AddHandler cgi-script .cgi .sh .pl
    # To use server-parsed HTML files
    #AddType text/html .shtml
    #AddHandler server-parsed .shtml
    # Uncomment the following line to enable Apache's send-asis HTTP
    # file feature.
    #AddHandler send-as-is asis
    # If you wish to use server-parsed imagemap files, use
    #AddHandler imap-file map
    # To enable type maps, you might want to use
    #AddHandler type-map var
</IfModule>
# End of document types.
# Default charset to iso-8859-1 (ttp://www.apache.org/info/css-security/).
AddDefaultCharset on
# Action: lets you define media types that will execute a script whenever
# a matching file is called. This eliminates the need for repeated URL
# pathnames for oft-used CGI file processors.
# Format: Action media/type /cgi-script/location
# Format: Action handler-name /cgi-script/location
# MetaDir: specifies the name of the directory in which Apache can find
# meta information files. These files contain additional HTTP headers
# to include when sending the document
#MetaDir .web
# MetaSuffix: specifies the file name suffix for the file containing the
# meta information.
#MetaSuffix .meta
# Customizable error response (Apache style)
#  these come in three flavors
#    1) plain text
#ErrorDocument 500 "The server made a boo boo.
#  n.b.  the (") marks it as text, it does not get output
#    2) local redirects
#ErrorDocument 404 /missing.html
#  to redirect to local URL /missing.html
#ErrorDocument 404 /cgi-bin/missing_handler.pl
#  N.B.: You can redirect to a script or a document using server-side-includes.
#    3) external redirects
#ErrorDocument 402 http://some.other_server.com/subscription_info.html
#  N.B.: Many of the environment variables associated with the original
#  request will *not* be available to such a script.
<IfModule mod_setenvif.c>
    # The following directives modify normal HTTP response behavior.
    # The first directive disables keepalive for Netscape 2.x and browsers that
    # spoof it. There are known problems with these browser implementations.
    # The second directive is for Microsoft Internet Explorer 4.0b2
    # which has a broken HTTP/1.1 implementation and does not properly
    # support keepalive when it is used on 301 or 302 (redirect) responses.
    BrowserMatch "Mozilla/2" nokeepalive
    BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
    # The following directive disables HTTP/1.1 responses to browsers which
    # are in violation of the HTTP/1.0 spec by not being able to grok a
    # basic 1.1 response.
    BrowserMatch "RealPlayer 4\.0" force-response-1.0
    BrowserMatch "Java/1\.0" force-response-1.0
    BrowserMatch "JDK/1\.0" force-response-1.0
</IfModule>
# If the perl module is installed, this will be enabled.
<IfModule mod_perl.c>
  Alias /perl/ /var/www/perl/
  <Location /perl>
    SetHandler perl-script
    PerlHandler Apache::Registry
    Options +ExecCGI
  </Location>
</IfModule>
# Allow http put (such as Netscape Gold's publish feature)
# Use htpasswd to generate /etc/apache/passwd.
# You must unremark these two lines at the top of this file as well:
#LoadModule put_module      modules/mod_put.so
#AddModule mod_put.c
#Alias /upload /tmp
#<Location /upload>
#    EnablePut On
#    AuthType Basic
#    AuthName Temporary
#    AuthUserFile /etc/apache/passwd
#    EnableDelete Off
#    umask 007
#    <Limit PUT>
#   require valid-user
#    </Limit>
#</Location>
# Allow server status reports, with the URL of http://servername/server-status
# Change the ".your_domain.com" to match your domain to enable.
#<Location /server-status>
#    SetHandler server-status
#    Order deny,allow
#    Deny from all
#    Allow from .your_domain.com
#</Location>
# Allow remote server configuration reports, with the URL of
#  http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
#    SetHandler server-info
#    Order deny,allow
#    Deny from all
#</Location>
# Allow access to local system documentation from localhost.
# (Debian Policy assumes /usr/share/doc is "/doc/", at least from the localhost.)
Alias /doc/ /usr/share/doc/
<Location /doc>
  order deny,allow
  deny from all
  allow from 127.0.0.0/255.0.0.0
  Options Indexes FollowSymLinks MultiViews
</Location>
# There have been reports of people trying to abuse an old bug from pre-1.1
# days.  This bug involved a CGI script distributed as a part of Apache.
# By uncommenting these lines you can redirect these attacks to a logging
# script on phf.apache.org.  Or, you can record them yourself, using the script
# support/phf_abuse_log.cgi.
#<Location /cgi-bin/phf*>
#    Deny from all
#    ErrorDocument 403 http://phf.apache.org/phf_abuse_log.cgi
#</Location>
<IfModule mod_proxy.c>
    # Proxy Server directives. Uncomment the following lines to
    # enable the proxy server:
    #<IfModule mod_proxy.c>
    #ProxyRequests On
    #<Directory proxy:*>
    #    Order deny,allow
    #    Deny from all
    #</Directory>
</IfModule>
# Enable/disable the handling of HTTP/1.1 "Via:" headers.
# ("Full" adds the server version; "Block" removes all outgoing Via: headers)
# Set to one of: Off | On | Full | Block
#ProxyVia On
# To enable the cache as well, edit and uncomment the following lines:
# (no cacheing without CacheRoot)
#CacheRoot "/var/cache/apache"
#CacheSize 5
#CacheGcInterval 4
#CacheMaxExpire 24
#CacheLastModifiedFactor 0.1
#CacheDefaultExpire 1
#NoCache a_domain.com another_domain.edu joes.garage_sale.com
#</IfModule>
# End of proxy directives.
### Section 3: Virtual Hosts
# VirtualHost: If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them.
# Please see the documentation at <URL:http://www.apache.org/docs/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# If you want to use name-based virtual hosts you need to define at
# least one IP address (and port number) for them.
#NameVirtualHost 12.34.56.78:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
#<VirtualHost ip.address.of.host.some_domain.com>
#    ServerAdmin webmaster@host.some_domain.com
#    DocumentRoot /www/docs/host.some_domain.com
#    ServerName host.some_domain.com
#    ErrorLog logs/host.some_domain.com-error.log
#    CustomLog logs/host.some_domain.com-access.log common
#</VirtualHost>
#<VirtualHost _default_:*>
#</VirtualHost>
  • knijnsel
  • Laatst online: 21-08 14:32
knijnsel
dus...
probeer eens
apache -S voor diag
<knijnsel> De nederlandstalige GuildWars site
  • knijnsel
knijnsel
dus...
en mis je niet onder
al je loadmodules?
/usr/sbin/apache -S
bedoel je ?
Ik krijg de zelfde foutmelding dan.
Ik zal nog een kleine voorgeschiedenis geven voor zover ik het me kan herinneren.
Ik had eerst (gister) een werkende apache webserver kant en klaar zo ingebakken in debian woody. Toen dacht ik, laat ik apache 2 eens installeren en ging naar apache.org, download apache 2 en install het volgens de site. Dit werkte niet want als ik apache starte kwam er geen output en als ik het vervolgens weer stopte zei die dat het niet eens draaide.
Toen heb ik de source van apache 1.3 gedownload (apt-get source apache) en geinstalled waarbij ik de zelfde foutmeldingen krijg als nu. Deze weer geuninstalled (apt-get uninstal apache) en toen dus geprobeerd weer te installen maar dan met apt-get install apache (zie eerste post).
knijnsel schreef op 11 juni 2004 @ 17:40:
al je loadmodules?
Ja dat denk ik wel. Toen ik apache 2 zelf gecompiled had stonden ze er wel in, maar via het installeren via apt-get install apache niet...
  • IceM
Wat je fout hebt gedaan bij jou gecompilede sources is waarschijnlijk
User www-data
Group www-data
Niet veranderd. In de standaard httpd.conf staan deze namenlijk fout ingesteld, en start hij niet op. (je krijgt inderdaad geen foutmelding tijdens het opstarten, maar hij draait niet).
Ik zie dat je bij apt-get install apache de melding kreeg dat er al een httpd.conf bestond.
Doe eens:
apt-get remove apache
rm /etc/apache/httpd.conf
[ Voor 26% gewijzigd door IceM op 11-06-2004 18:28 ]
Doe eens:
apt-get uninstall apache
[/quote]
is apt-get remove apache ook goed als eerste?
Tijdens remove opdracht:
dpkg - warning: while removing apache, directory `/etc/apache' not empty so not removed.
[ Voor 28% gewijzigd door Verwijderd op 11-06-2004 18:29 ]
  • IceM
Verwijderd schreef op 11 juni 2004 @ 18:27:
Ja, inderdaad. Kwam er net achter dat ik een typo had gemaakt, sorry :)
En een reactie op je warning:
rm -R /etc/apache
Er stonden denk ik nog logfiles in.
[ Voor 23% gewijzigd door IceM op 11-06-2004 18:30 ]
Nudan, nog maar eens apt-get install apache na rm /etc/apache/httpd.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
boom:/var/log/apache# apt-get install apache
  apache
shell-init: could not get current directory: getcwd: cannot access parent directories: No such file or directory
(Reading database ... 18312 files and directories currently installed.)
Pondering. done.
Rotated `/etc/apache/httpd.conf' at Fri Jun 11 18:20:42 CEST 2004.
Rotated `/etc/apache/srm.conf' at Fri Jun 11 18:20:42 CEST 2004.
failed
interesant vind ik nou wel deze regels:
  • Zwerver
Dat komt omdat je in /var/log/apache staat, en die is er niet meer ;)
Doe eens:
apt-get remove --purge apache
apt-get update
Dan zou die alle config files verwijderd en herinstalleerd moeten hebben. Daar hebben we de purge optie voor, het verwijderen met rm -R /etc/apache zou ik gewoon niet doen, mede omdat er dan vast wel ergens in debian bijgehouden wordt dat die config file er nog is, terwijl jij die verwijderd hebt.
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
boom:/# apt-get remove --purge apache
The following packages will be REMOVED:
  apache*
0 packages upgraded, 0 newly installed, 1 to remove and 0  not upgraded.
Need to get 0B of archives. After unpacking 770kB will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 18342 files and directories currently installed.)
Removing apache ...
Stopping web server: apacheNo /usr/sbin/apache found running; none killed.
Purging configuration files for apache ...
Website at /var/www has NOT been deleted.
en
29
30
31
32
33
  apache
(Reading database ... 18309 files and directories currently installed.)
Initializing apache config for immediate operation.
Installing new configuration file /etc/apache/access.conf ...
Installing new configuration file /etc/apache/srm.conf ...
Pondering. done.
failed
Gezien dit regeltje : dpkg - warning: while removing apache, directory `/etc/apache' not empty so not removed.
zal die httpd.conf dan ook wel niet gedelete zijn, wat als ik jullie oplossingen nou eens combineer:
apt-get update
of is dat een beetje overbodig?
  • IceM
Opzich is er aan die httpd.conf die je gepost hebt niets fout, dus ik denk dat het eerder aan je apache ligt.
Je gebruikt neem ik aan een stable apt-get source?
Als je /etc/apt/sources.list nou eens veranderd in unstable (de stable daarin veranderen in unstable is genoeg, dan bestand gewoon overschrijven).
Als je dat gedaan hebt:
apt-get update
Je kunt je /etc/apt/sources.list hierna weer terugzetten als je wilt.
  • Olaf van der Spek
IceM schreef op 11 juni 2004 @ 19:45:
Is testing niet iets veiliger?
  • Zwerver
apt-get update
Argh... doe dat nou NIET!!!!!!! Geef mensen nou niet het advies om een halve upgrade te doen!!!!!!!!! Hoe vaak moet het nou nog gezegd worden, in de unstable/testing worden nieuwere libs gebruikt die vaak niet werken met de stable packages. Het resultaat: je systeem om zeep. Wat je beter kan doen is zoeken naar:
• een backport
• pinning
en het feit dat die de melding geeft dat ie het niet doet, dat heeft te maken met de remove, daarna purge die ze alsnog, dus zijn je conf files weg.
Overigens, dit heeft nix te maken met de apache in stable. Die is gewoon goed... Als ik jou was zou ik maar eens gaan kijken of er niet toevallig 2 apaches geinstalleerd staan, en dat bij het starten de goede wel gestart wordt.
[ Voor 1% gewijzigd door Zwerver op 11-06-2004 20:55 . Reden: typo ]
  • active2
  • Laatst online: 17-07 21:56
active2
Google is your friend
apt-get update
Heb je enig idee wat voor onnozele reactie je geeft ?
Unstable -> onstabiel -> misschien zegt Nederlands je wat.
Maar om even een onderbouwde reactie te geven:
Hier boven geef je aan dat je je sources.list moet veranderen naar unstable. Resultaat is dat je een aantal libs hebt geupgrade bijvoorbeeld libssl9.7.0 <- is de vervanger van libssl9.6.0 -> nadeel daarvan is dat je ssh niet meer goed werkt.
Kun je niet meer remote inloggen -> Stel dat het een remote bak is. Dan ben je zwaar de lul.
Ik kan me voorstellen dat je het advies geeft. Om de dood eenvoudige reden dat je dan nieuwer spul hebt. Inderdaad maar denk er bij na als het een stable box is.
Ik hoop dat de topic starter het volgende uitvoert: (wat Zwerver ook al gezegd heeft)
^^ als het boven staande commando een error geeft in de trant van het package is niet geinstalleerd dan het volgende commando:
dpkg --purge apache
En vervolgens opnieuw installeren:
Hiermee krijg je een schone nieuwe standaard config die werkt. Hier kun je je aanpassingen makkelijk in maken :)
Google, Het mirakel van de 21e eeuw!!!!
  • _JGC_
  • Laatst online: 09:58
Misschien is het handig om ook apache-common weg te flikkeren, dit zijn de generieke dingen waar apache gebruik van maakt bij het configureren.
Waar het bij jou fout gaat, is het genereren van een lijst met te laden DSO's. Dit doet mij denken aan een httpd.conf van een oudere versie van apache die je ooit zelf gebouwd hebt, aangezien die dat niet nodig hadden. Moderne versies van apache hebben die lijst nodig als ze met DSO gebouwd zijn (een debian package is dat).
  • Zwerver
waarom zie ik hier ineens half #anti-rpm langskomen?
